Flint 3 (BE-9300) RNR missing from 5GHz Probe Responses which brakes 6GHz discovery on linux
I am seeing a 6 GHz discovery issue with Flint 3 that appears to be caused by how Reduced Neighbor Report (RNR) is advertised.
The 5 GHz beacon correctly contains an RNR advertising the colocated 6 GHz BSS:
Tag: Reduced Neighbor Report
    Operating Class: 134
    Channel Number: 37
    BSSID: <6 GHz BSSID>
    Same SSID: True
    Co-Located AP: True
    MLD Link ID: 2
However, the corresponding 5 GHz Probe Response does not contain an RNR.
I confirmed this with monitor-mode packet captures.
This causes a practical interoperability issue with a Linux/iwd Wi-Fi 6E client.
From a cold state, the client only discovers/connects to the 5 GHz BSS.
If I explicitly perform a directed scan for the SSID on the known 6 GHz channel, the 6 GHz BSS is immediately discovered and works normally:
iw dev wlan0 scan freq 6135 ssid <SSID>
After that, association to 6 GHz works without any issue.
The behavior therefore looks like:
5 GHz beacon
  → RNR correctly advertises 6 GHz
  → RNR missing
normal 6 GHz discovery
  → fails
directed 6 GHz SSID probe
  → succeeds
Could you check whether Flint 3 is supposed to include the 6 GHz RNR in both the 5 GHz Beacon and Probe Response?
It looks like adding the same RNR information to the Probe Response may fix 6 GHz discovery for clients that use the probe-response information during colocated-6-GHz scanning.
This is all happening with a 5+6GHz MLO AP and 4.10.1 firmware.
BTW the “fix“ is having the connection set as hidden, so the networkmanager discovers 6GHz without relying on RNR.
Thank you for the detailed report.
Please SSH into the router and run the following commands to see whether they enable RNR in the 5 GHz Probe Response:
cfg80211tool wlan12 rnr 1
hostapd_cli -p /var/run/hostapd-wifi1 -i wlan12 update_beacon
If the issue persists, could you please send us a private message with a complete over-the-air packet capture of a connection attempt so that we can investigate further?
If possible, please also include:
  1. The Linux device model, OS distribution and version, Wi-Fi adapter model, and Wi-Fi driver version.
  2. The MAC addresses of the BE9300 and the Wi-Fi adapter, so we can identify them in the capture.
