Flint 3 - Downstream router issue
2 issues:
  • Downstream router to Home Assistant Public Custom domain doesn’t work unless I stop the service referred here: GL-B3000 (Marble) NAT hairpin/loopback troubles - Routers - GL.iNet Official Forum. My setup is Home Private LAN (downstream) → IOT LAN (GL-BE3900) → Internet
  • LAN clients sometimes can’t connect to HomeAssistant using Public DNS. To resolve: From my Phone, turn off Wifi. Connect to Home assistant, then turn on wifi and connect, then it works. Seems a routing from LAN.
For potential NAT hairpin/loopback issues, you can first test whether bridge netfilter is the cause by running the following via SSH into router:
sysctl -w net.bridge.bridge-nf-call-iptables=0
sysctl -w net.bridge.bridge-nf-call-ip6tables=0
If this resolves the issue, make the change persistent:
echo "net.bridge.bridge-nf-call-iptables=0
net.bridge.bridge-nf-call-ip6tables=0" >> /etc/sysctl.conf
reboot
For possible DNS issues, during the time the problem is occurring, please run the following on a client device:
# Windows (CMD)
nslookup <your_homeassistant_domain>
tracert <your_homeassistant_domain>
# macOS/Linux
traceroute <your_homeassistant_domain>
Thanks @will. Resetting the iptable seems to have fixed the downstream issue.
