Flint 3 firmware 4.8.3 possible issue
I found a potential minor issue with Flint 3.
NOTE: Tested on a reset Flint 3 (firmware version 4.8.3) with guest wireless network turned on.
Issue: It seems bridge "br-guest" is not correctly setup.
Steps to replicate:
  • Go to "Network > Interfaces > Interfaces", under "guest" you it shows "br-guest".
  • Go to "Network > Interfaces > Devices", there is no "br-guest" but if you try to create "br-guest" then it says: The device name "br-guest" is already taken.
Possible fix: Also, if you look at /etc/config/network, there is a "config device" section for "br-lan" but no similar section for "br-guest". If you add the following to /etc/config/network it seems to resolve the issue:
config device
option name 'br-guest'
option type 'bridge'
Thank you for your feedback.
We'll check with our R&D team.
Any feedback?
We are still internally discussing a viable solution for this, so a firmware fix might not be released in the immediate future.
For the time being, please continue to use the workaround you mentioned to resolve the issue.
