Flint 3 (GL-BE9300) Repository Package Request
Just wondering if there was a method to request packages to be added to the GL iNet repo for the flint 3 or a method to build them ourselves with a build env. I am specificly looking to add the following 3 packages so I can have stats from my Flint 3 sent to mqtt to later flow into Home Assistant. Thank you for any help anyone or GLiNet can provide!
collectd-mod-mqtt
collectd-mod-uptime
collectd-mod-ping
Will try to compile these plugins if it is compatible with Flint3 arch.
Please wait.
Same request , looking for the collectd-mod-mqtt plugin
Added. Please update again.
bruce you are my hero! thank you very much!
if anyone does drop in here and the LUCI config doesnt work for you, you can go custom with it via cli.
uci set collectd.globals.alt_config_file='/etc/collectd-custom.conf'
uci commit collectd
and put your manual config in /etc/collectd-custom.conf and restart collectd, example of my config:
BaseDir "/var/run/collectd"
PIDFile "/var/run/collectd.pid"
PluginDir "/usr/lib/collectd"
TypesDB "/usr/share/collectd/types.db"
Interval 15
ReadThreads 2
WriteThreads 2
CollectInternalStats false
Hostname "Hostname"
#Include "/etc/collectd/conf.d"
LoadPlugin cpu
<Plugin cpu>
	ValuesPercentage true
	ReportByCpu true
	ReportByState true
</Plugin>
LoadPlugin memory
<Plugin memory>
	ValuesPercentage false
	ValuesAbsolute true
</Plugin>
LoadPlugin mqtt
<Plugin mqtt>
	<Publish "hostname">
		Host "192.168.0.0"
		Port 0000
		User "USER"
		Password "PASSWORD"
		Qos 1
		Retain true
	</Publish>
</Plugin>
LoadPlugin ping
<Plugin ping>
	TTL 127
	Interval 240
	AddressFamily "ipv4"
	Host "192.168.0.0"
	Host "8.8.8.8"
</Plugin>
LoadPlugin rrdtool
<Plugin rrdtool>
	DataDir "/tmp/rrd"
	RRARows 288
	RRASingle true
	RRATimespan 7200
	RRATimespan 86400
	RRATimespan 604800
	RRATimespan 2678400
	RRATimespan 31622400
</Plugin>
LoadPlugin interface
<Plugin interface>
	Interface "br-lan"
	Interface "eth0"
	Interface "eth1"
	Interface "br-iot"
</Plugin>
LoadPlugin uptime
