Flint 3 - How much power on USB?
Looking to use an SSD in an enclosure with the Fint 3 USB. Does it have enough power to handle this or should I look for an enclosure with an external PS?
The USB port on the Flint 3 has a maximum output of 5V/2A/10W. Therefore, if the hard drive you plan to use exceeds this limit, you’ll need a hard drive enclosure with an external power supply.
Thanks!
