The router not pass the IPV6 in AP Mode. But my banana pi working with openwrt. You have any config to rely the ipv6 with flint 3 in AP mode.
Please try changing the Router mode to enable IPv6 and Passthrough mode.
Then, change back to AP mode to see if the clients now have IPv6.
It working big thanks. But it's a good idea to get that parameter in AP mode.
Yes, we have already relayed this feedback to the product team to explore whether we can show this menu bar in non-router mode in a future version.
Thanks for considering fixing this. I have encountered the same problem with my GL.iNet GL-BE9300, which I use in AP mode only. There was no IPv6 on the device itself or on any of the wireless clients. IPv6 settings should definitely be shown, as the AP couldn't work in an IPv6-only network. And the current solution of switching to Router mode and then back to AP, while it works, is a bit unconvenient (the device change its IP address, starts its DHCP server, etc.).
Thank you for your feedback.
We will share this feedback with the product team as well so they can better understand the relevant requirements.
Just went through this exact issue! Ill update the ticket. Thanks. This worked. Was driving me nuts! Firewalla Gold SE > Flint 3 AP Mode/Switch now getting public routed ipv6 from my /48 block.
