Flint 3 v4.10 VLANs
I previously set up vlans on the ethernet side (port-based and tagged) via LuCi and cli. Everything was working well under v4.8. I took the change and upgraded to v4.10 and kept settings and it actually preserved the VLANs perfectly. I was happily surprised by this.
Now I know you can set up VLANs in the GL gui and I am wonder a few things.
  1. None of my VLANs are showing up in the gui. Since I did not use it, it is not surprising to me.
  2. Can I reset my router and then build the VLANs using the GL gui?
  3. Can I add more than 2 WAN connections this way and will additional WAN connections be configurable in kmwan3?
Thanks for any information. Worst case I will back it up, wipe it, and see what happens, but wondered if there would be some guidance here first.
Regarding your questions:
  1. VLANs created manually through LuCI or the CLI generally do not automatically appear in the GL.iNet Admin Panel.
  2. Yes, you can reset the router and create your VLAN networks through NETWORK → Subnet, then configure the Ethernet port assignments under NETWORK → Ethernet Port.
    Please back up your current configuration before resetting, and refer to these guides:
  1. You can refer to the following methods to add a third wired WAN.
    The following example uses physical LAN1 as the second WAN and physical LAN2 as the third WAN, with IPv4 failover priority WAN → Second WAN → WAN3.
  • Step A: Separate the port in LuCI.
    Go to Network → Switch and configure switch1 as shown below.
    On the Flint 3 switch page shown here, the LAN labels are reversed relative to the physical ports: LuCI LAN3 corresponds to physical LAN2, and LuCI LAN4 corresponds to physical LAN1.
  • Step B: Create the WAN3 interface.
    Go to Network → Interfaces → Add new interface, name it wan3, select device eth1.3, and choose DHCP client if the upstream connection assigns an IP address automatically.
  • Step C: Register WAN3 in kmwan.
    Run the following commands over SSH to add wan3 and set the wired failover priority.
cp /etc/config/kmwan "/etc/config/kmwan.bak.$(date +%Y%m%d-%H%M%S)"
uci set kmwan.global.enable='1'
uci set kmwan.global.mode='failover'
uci set kmwan.wan.metric='2'
uci set kmwan.secondwan.metric='3'
uci set kmwan.wan3='member'
uci set kmwan.wan3.interface='wan3'
uci set kmwan.wan3.addr_type='4'
uci set kmwan.wan3.track_mode='force'
uci set kmwan.wan3.weight='1'
uci set kmwan.wan3.disabled='0'
uci set kmwan.wan3.check='1'
uci set kmwan.wan3.metric='4'
uci -q delete kmwan.wan3.tracks
uci add_list kmwan.wan3.tracks='ping,1.1.1.1'
uci add_list kmwan.wan3.tracks='ping,8.8.8.8'
uci add_list kmwan.wan3.tracks='ping,208.67.222.222'
uci add_list kmwan.wan3.tracks='ping,208.67.220.220'
uci commit kmwan
/etc/init.d/kmwan restart
The interface='wan3' setting must match the interface name in LuCI exactly.
Once this configuration is complete, the router will set the wired priority as follows: WAN → SecondWAN → WAN3.
Regarding the display of LAN2 (wan3), the Multi-WAN page will show it as another “Ethernet 1” entry because the page assigns this label to interface names beginning with wan.
Thank you!
