Flint 3 Vlan
I am struggling to create a vlan off one of the ports on the Flint 3.
following this guide: [OpenWrt Wiki] Guest Wi-Fi using LuCI
Device keeps pulling getting assigned an ip from the main DHCP. I dont see an option to exclude the bridged Lan, but alas...
Please refer to this post:
So resolved the issue, the Ethernet ports are numbered in reverse, so port 4 on the physical device is actually port 1 on LuCi interface. So all is well. Managed to setup my Vlan in bridge mode correctly and gets the new dhcp assigned correctly :slight_smile:
This is specific to the Flint 3, BE9300
It's true. I just tested it, and let me show here:
LAN ports in switch1:
switch1 port 1 port 2 port 3 port 4 port 5 port 6 port 7 port8
Number of 2.5G LAN / / / 4 3 2 1 /
Physical Order of Casing / / / 5 4 3 2 /
The 2.5G WAN is eth0, 1 in Physical Order in Casing.
If possible, could you please show us configure process and configuration?
Hi, I dont have access to the ports at the moment, but followed this tutorial. Instead of adding it to the wireless card, I went to "switch" section and added a new VLAN where CPU1 was tagged (as it needs to be tagged on all VLANS, and then made 1 untagged and the rest off. You will need to update the previous VLAN entry to "off" for the port you are using in the new VLAN as you cant have a port assigned untagged on multiple VLAN entries.
and voila!
