NOTE: Made with AI, it helped me troubleshoot this issue and explains better then I would.
Firmware: 4.9.1 · Hardware: one GL-BE14000, no switch
Topology: PC on the 10GE RJ45 port (eth2, 10G FD) and NAS on the SFP+ cage (eth1, 10G FD), both in br-lan. PPPoE WAN on eth1.3. Traffic below never leaves the bridge — no WAN, no NAT, no routing.
iperf3 -P 4 -t 10, zero retransmits, all ethtool -S error counters at zero:
| Path | Throughput |
| PC → router (CPU terminates) | 5.96 Gbps |
| NAS → router (CPU terminates) | 4.85 Gbps |
| PC → NAS (bridged, accel off) | 1.89–2.22 Gbps |
| PC → NAS (bridged, accel on) | ~9.2 Gbps |
Each port pushes 5–6 Gbps into the CPU alone, so endpoints, cables (Cat5e→Cat6), NIC/driver, MTU and NAS-side bridge are all ruled out — only switching between the two 10G ports collapses without the offload engine, with the CPU idle. mtkhnat.global.enable is the only knob that moves the number.
Suspected factor — interface mapping. The SFP+ port ships as WAN, so eth1 trunks a LAN and a WAN VLAN at the same time:
eth1 (10G SFP+) ├── eth1.1 → br-lan (LAN, untagged VLAN 1 — the NAS)
└── eth1.3 → pppoe-wan (VLAN 3 — PPPoE WAN)
eth2 (10GE RJ45) ─── br-lan
So every 10G↔10G L2 flow is VLAN-tagged on one side by construction, and a host in the SFP+ cage must be VLAN-aware to be bridged normally. If the PPE/offload path keys tagged vs. untagged ingress differently on the same netdev, that would also explain the "forwarded client ~2.4 Gbps, router itself ~5 Gbps, both together 7.8 Gbps" asymmetry reported elsewhere here.
