Flint 4 BE-14000 Discussion Thread
Hey Miles, not that I`m aware of :frowning:
Ok, thanks :slight_smile:
If the GL Team come here, please, gave us the changelog between versions...
I think the snapshot build changelog for mt6000 is tracking all the gl-inet MTK based devices development changes. It likely gives hints to what is changing.
I have just updated to Beta 6 - Disaster - I cannot install Dockerd
Nor can I install luci-app-dockerman
I have a warning on timezone after time switch last weekend on my beta rom. But set time and timezone is right.
The time zone of the router is different from that of your browser.
I
I have this problem from the beginning - no matter if time was switched or not.
FWIW my time zone is correct in Aust.
We checked with the R&D team, and this version has only one minor improvement:
  • Fixed an issue where mobile devices could occasionally fail to connect to Wi-Fi using WPA3.
Thank you for your feedback.
Could you let us know your time zone and which OS/browser you're using?
We'll check whether we can reproduce the issue locally & try to fix it.
Thanks for your feedback. We’ll ask our development team to look into it.
Mine as well
Opera browser based on chromium, Windows 11. Firefox same problem.
On mobile opera there is no warning.
Does the Flint 4 with beta firmware already support mesh with another flint 4?
Yes, i am doing it. However you can't use the SFP+ port for the backhaul.
Other than the Dockerd issue, how is beta 6 working out for you?
For me?
It works. No real issues that I am aware of. Meh..... I am about to decommission the Fritz!Box and use the Flint as the house router.
I have simple needs. I do not check that devices are roaming between nodes - I do see I have 5 (WiFi) devices connected to the node - 10 gig ethernet backhaul to the main router.
SFP 2.5 gig module for my 500/50 FTTP internet.
MLO enable and being used.
I am using the IoT VLAN - works OK. I can get to the IoT devices web admin page once I set and ACL rule.
I do not fuss about pings. I have no idea what the WiFi throughput is - that is of no concern to me.
AdGuard Beta works very well - I am blocking 72% of useless DNS. I am blocking 27,269 useless content (filtering) just for today already - it is now 09:10 in the morning for me and I can still use the internet the way I want to.
The docker issue is not die in a ditch situation - I have the App that I want to use running in docker on a RasPi with other containers anyway.
I really would like to set a fixed IP on the node if I use docker on the node - the SearXNG App I use needs to have a fixed IP to work consistently.
I did see a post talking about fixing the IP of the node on a Flint 2 - I suppose it would be the same for the F4 but I am very cautious of using LUCI as I do not really understand it at any competent level.
sorry for the long post i found some bugs and issues in the beta 6 firmware i have been trying to self fix and patch and some of the work arounds that i was able to get to work. some issues i am not able to patch my way out of.(ai was used to summarise for me so i didn't have to do it apologies for the output) more data can be provided if needed.
Model: GL-BE14000 (Flint 4)
Firmware Version: 4.11.0 Beta 6 (OpenWrt 25.12-SNAPSHOT r32295+917-c25265953b, target mediatek/filogic)
Country / Region: Australia (AU)
Client Devices Tested: Pixel 10 Pro XL, Pixel 10 Pro, Windows 11 26H2 Desktop (MediaTek Wi-Fi 6E MT7922 / RZ616 160MHz, driver 3.6.0.1425)
After upgrading to 4.11.0 Beta 6 and running a 5-day stability/log audit (Oct 30 – Nov 4, 2026), we isolated the root causes of the downstream client stalls (where the router's built-in Network Quality scores 100 Rock Solid at 2–3 ms, but LAN/Wi-Fi clients on both VPN and MAC-excluded novpn paths experience intermittent freezes and page/app load delays).
Below are 7 confirmed firmware/driver bugs in 4.11.0 Beta 6 along with sanitized logs and the local workarounds we verified.
Bug 1: /etc/hotplug.d/iface/99-vpn-client treats routine WAN DHCP renewals (ifupdate) as down (wiping nf_conntrack every 15 minutes) + stock eco typo
  1. Mechanism: In /etc/hotplug.d/iface/99-vpn-client, notify_if_status_change() sets action_type='down' for any hotplug event other than ifup:sh
    if [ "${action}" = "ifup" ] ;then
    action_type='up'
    else
    action_type='down'
    fi
    When VPN Policy Routing is enabled (`route_policy.global.enabled='1'`) and the upstream ISP uses a 30-minute DHCP lease (`lease time 1800`), `udhcpc` renews the WAN lease **every 15 minutes** (`11:46:34`, `12:01:34`, `12:16:33`, `12:31:34`). Without an `ifupdate` filter, `99-vpn-client` invokes `/usr/bin/rtp2.sh 'interface_status_change' "wan" "down"` every 15 minutes even though the WAN IP did not change—reloading the firewall and flushing `nf_conntrack` across all LAN clients (same bug reported on 4.10.1 in #71714).
    ```text
    Wed Nov  4 11:46:34 2026 daemon.notice netifd: wan (10005): udhcpc: sending renew to server 172.31.X.X
    Wed Nov  4 11:46:34 2026 daemon.notice netifd: wan (10005): udhcpc: lease of 202.XXX.XXX.XXX obtained from 172.31.X.X, lease time 1800
    Wed Nov  4 12:01:34 2026 daemon.notice netifd: wan (10005): udhcpc: sending renew to server 172.31.X.X
    Wed Nov  4 12:01:34 2026 daemon.notice netifd: wan (10005): udhcpc: lease of 202.XXX.XXX.XXX obtained from 172.31.X.X, lease time 1800
    Verified Fix: Insert the ifupdate address/data guard right after esac (after $if_type is assigned) in notify_if_status_change():
    Bash
    [ "$action" = ifupdate ] && [ "$if_type" = wan ] && [ -z "$IFUPDATE_ADDRESSES$IFUPDATE_DATA" ] && return 0
  2. Stock Syntax Typo: Line 54 of /etc/hotplug.d/iface/99-vpn-client has a typo (eco instead of executing /usr/bin/setup_autovpn_instance.lua):
    Bash
    [ ! "$exist" ] && {
        eco /usr/bin/setup_autovpn_instance.lua $tunnel_id &
Bug 2: MediaTek 7990 Wi-Fi 7 (802.11be) MLO pEntry Pointer Collision & INVALID setup_link_id(15) on Band Roam (Even With MLO SSID Disabled)
Even with the dedicated MLO network disabled in the UI, Wi-Fi 7 clients (Pixel 10 Pro / Pixel 10 Pro XL) associating to 5 GHz (BN1 / rai0) and 6 GHz (BN2 / rax0) in 802.11be mode still include an mlo_addr in their 802.11be Association Request (and trigger IE_WLAN_EXTENSION: no handler for extension_id:107/108/109). When a client roams between BN1 (link_id=1) and BN2 (link_id=2), the driver logs INVALID setup_link_id(15) and inserts a duplicate pEntry pointer (00000000255ebc55):
Plaintext
[  199.689013] 7990@WARN.MLME,BN1,PeerAssocReqCmmSanity() 1701: IE_WLAN_EXTENSION: no handler for extension_id:107
[  199.699124] 7990@WARN.MLME,BN1,PeerAssocReqCmmSanity() 1701: IE_WLAN_EXTENSION: no handler for extension_id:108
[  199.709201] 7990@WARN.MLME,BN1,PeerAssocReqCmmSanity() 1701: IE_WLAN_EXTENSION: no handler for extension_id:109
[  199.755620] WiFi@WARN.MLO,mld_entry_add_link() 4307: mld_sta_idx=0, mld_addr=d6:eb:cb:XX:XX:38, link_id=1 insert the same pEntry=00000000255ebc55
[  199.945720] 7990@WARN.FW,BN1,MtAsicGetTxTscByFw() 918: rai0: PN type mask is zero
[  199.978918] 7990@ERROR.CFG,BN1,sta_port_secure_event_to_daemon() 2594: assoc ie is null!
[  199.996675] 7990@ERROR.PROTO,BN1,CFG80211_RRM_BeaconReqHandler() 1222: Not RRM Radio Measure Request frame
[17863.446582] 7990@WARN.MLME,BN1,ap_peer_disassoc_action() 4687: ASSOC - 1 receive DIS-ASSOC request
[17863.499678] WiFi@ERROR.MLO,mld_entry_link_select() 4811: INVALID setup_link_id(15)
[17863.510526] WiFi@ERROR.MLO,mld_entry_link_select() 4811: INVALID setup_link_id(15)
[17864.063592] 7990@NOTICE.MLME,BN2,hostapd_auth_resp() 751: forward vendor_cache_msg to queue pkts for staaddr=c2:19:1f:XX:XX:01 mlo_addr=c2:19:1f:XX:XX:00 entry_mlo_addr=c2:19:1f:XX:XX:00
[17864.251558] WiFi@WARN.MLO,mld_entry_add_link() 4307: mld_sta_idx=0, mld_addr=c2:19:1f:XX:XX:00, link_id=2 insert the same pEntry=00000000255ebc55
Note on 6 GHz (rax0) Stability (Thread #72016): With MLO enabled + 320 MHz Auto channel + HNAT (mtkhnat) enabled, rax0 suffered massive RX drops and contd_fail_cnt 369 TX stalls. Disabling MLO, setting 6 GHz to 160 MHz on a fixed PSC channel (37), and disabling HNAT (mtkhnat.global.actype='0') restored 100% hardware delivery (HTC_ICVErr:0) in mwctl rax0 show stainfo.
Bug 3: mtkhnat UCI Desync (enable='0' while actype='1') & Full Cone NAT Duplicate Masquerade on wgclient1
  1. When Network Acceleration is disabled or VPN Policy Routing is active, uci show mtkhnat.global sets mtkhnat.global.enable='0' but leaves mtkhnat.global.actype='1' active until manually zeroed via uci set mtkhnat.global.actype='0'.
  2. When Full Cone NAT is enabled alongside WireGuard client (wgclient1), network.set_netnat_config injects a legacy iptables-nft rule (-A POSTROUTING -o wgclient1 -j MASQUERADE --mode fullcone, appearing as oifname "wgclient1" counter xt target "MASQUERADE") inside chain srcnat_wgclient1 directly below fw4's native meta nfproto ipv4 masquerade rule, resulting in duplicate masquerade rules on wgclient1.
Bug 4: route_policy Rule 90022: from all iif lo lookup 1001 Forces Router dnsproxy (127.0.0.1#5453) Into VPN Tunnel + Hardcoded IPv6/Google Bootstrap
  1. With VPN Policy Routing enabled, ip rule show installs 90022: from all iif lo lookup 1001 (wgclient1). When MAC-excluded (novpn, fwmark 0x8000) LAN clients query the router (192.168.8.1) with Encrypted DNS (DoT) enabled, dnsmasq forwards to server=127.0.0.1#5453 (dnsproxy). Because dnsproxy egresses from iif lo without skgid 10000 (fwmark 0x8000), rule 90022 routes dnsproxy queries into table 1001 (wgclient1) instead of main.
  2. /etc/dnsproxy/dnsproxy.yaml hardcodes "8.8.8.8:53" and IPv6 "[2001:4860:4860::8888]:53" as bootstrap servers with timeout: '10s' even when IPv6 is disabled network-wide.
Bug 5: dnsmasq stop-dns-rebind Blocks dns.msftncsi.com Before filter-AAAA Strips IPv6 Records
With rebind_protection='1' and filter_aaaa='1' enabled, dnsmasq evaluates the upstream IPv6 ULA record (fd3e:4f5a:5b81::1) of dns.msftncsi.com before filter-AAAA strips the AAAA answer, dropping the packet as a DNS-rebind attack and breaking Windows 11 NCSI connectivity checks unless uci add_list dhcp.@dnsmasq[0].rebind_domain='dns.msftncsi.com' is manually added.
Bug 6: Unused EasyMesh Daemons (mapfilter & wappd) Drop IP Packets on Boot and Poll Down Repeater Interfaces Every 8s
Even when EasyMesh / Repeater is not used:
  1. On boot, mapfilter logs [ 197.683509] mapfilter:drop IP addr timeout! stop dropping IP addr.
  2. wappd logs load file(/etc/map/mapd_cfg) fail and repeatedly polls down interfaces (apclix0, apclii0, apcli0), logging cfg80211_drv_vndr_get_static_info() 4159: failed - [ERROR] Interface is down across BN0, BN1, and BN2.
Bug 7: Touchscreen WebSocket Drops Every 300s (session_timeout) & Daily 06:01 AM gl_clients.sock [crit] Errors in nginx.log
  1. Because session_timeout is 300, the local touchscreen WebSocket disconnects and reconnects every 5 minutes and 5 seconds in system.log:
    Plaintext
    Wed Nov  4 12:17:58 2026 user.err : [screen][ws_callback][error]ws closed
    Wed Nov  4 12:18:03 2026 user.info : [screen][ws_client_wait][info]ws reconnecting...
    Wed Nov  4 12:18:03 2026 user.info : [screen][ws_callback][info]ws connected
    Wed Nov  4 12:23:04 2026 user.err : [screen][ws_callback][error]ws closed
  2. On every boot—and at 06:01 AM every day (Oct 31, Nov 1, Nov 2, Nov 3, Nov 4)—nginx.log logs 5–7 critical socket failures for ~50 seconds while local RPC calls attempt to reach /tmp/gl_clients.sock:
    Plaintext
    2026/11/04 06:01:06 [crit] 10386#0: *183 connect() to unix:/tmp/gl_clients.sock failed (2: No such file or directory), client: 127.0.0.1, server: , request: "POST /rpc HTTP/1.1", host: "127.0.0.1"
    2026/11/04 06:01:58 [crit] 14478#0: *544 connect() to unix:/tmp/gl_clients.sock failed (2: No such file or directory), client: 127.0.0.1, server: , request: "POST /rpc HTTP/1.1", host: "127.0.0.1"
apologies if i have posted this in the wrong place or broken any rules this was done with the best intentions.
thanks and kind regards
I have no idea what that is all about. I connect to MLO on my desktop WIN 11 and do not notice any droputs or other problems but I do not go looking for problems.
On my phone sometimes it happens and for exhale website loads indefinitely.
I have it on Wifi 7 connections.
To overcome it I use MLO so the other bands can fill the gaps.
