Flint 4 BE-14000 Discussion Thread
Finally I received my Flint 4.
DHL refused to deliver it on Saturday (more than 90% of their shipments they won’t deliver in the weekend just saying I was not at home).
Package was a tiny bit damaged but the inside was fine.
Had some problems with the first setup because it refused to log in wired over ethernet.
Just did twice a reset and a “repair” and finally it booted normal.
Setting up the basic settings and VPN settings (Proton VPN).
It is running (1 Gbps symmetric fiber line) and my Wireguard VPN speed is:
Unfortunately over Wifi 7 with Proton VPN Wireguard active (I have 2 devices with a Qualcomm Snapdragon Gen 3 SOC) I only get half of that.
Also at first with the 6Ghz band set to 320 Mhz bandwith over Wifi 7 both devices were slow in response.
After setting the bandwith to 160Mhz that was solved.
How to improve the Wifi 7 speeds so it comes close to the wired Wireguard speeds posted in the picture?
By the way the throughput speeds without Wireguard over Wifi are excellent ( 1016/1060).
Thank you for sharing the detailed test results.
Some difference between wired and wireless throughput is normally expected.
However, since you can reach around 1 Gbps over Wi-Fi without WireGuard, while the throughput drops considerably when WireGuard is enabled.
Could you please check NETWORK → Network Acceleration and make sure Hardware Acceleration is enabled, then test the Wi-Fi + WireGuard speed again?
If possible, could you also test with a laptop/PC connected over Wi-Fi and compare the speed with WireGuard disabled and WireGuard enabled ?
During both tests, please run the following command through SSH and share the top output with us to compare the CPU usage with and without WireGuard:
top
If convenient, could you please export the system logs after reproducing the problem and send them to us via private message.
Thank you for your support and understanding.
CLI speedtest PC without wireguard over Wifi:
TOP output:
root@GL-BE14000:~# top
Mem: 885036K used, 1148960K free, 17700K shrd, 113100K buff, 140004K cached
CPU: 2% usr 0% sys 0% nic 97% idle 0% io 0% irq 0% sirq
Load average: 2.32 2.41 2.52 2/179 3910
PID PPID USER STAT VSZ %VSZ %CPU COMMAND
26489 1 root S 1406m 71% 0% /usr/bin/AdGuardHome --glinet -c /etc/AdGuardHome/config.yaml -w /etc/AdGuardHome -l syslog
24173 22520 root S 35432 2% 0% nginx: worker process
24170 22520 root S 33200 2% 0% nginx: worker process
24172 22520 root S 30656 2% 0% nginx: worker process
24171 22520 root S 30208 1% 0% nginx: worker process
12242 1 root S< 30096 1% 0% /usr/bin/gl_screen -c /tmp/gl_screen/config
22520 1 root S 17332 1% 0% nginx: master process /usr/sbin/nginx -c /etc/nginx/nginx.conf -g daemon off;
28518 1 root S 12320 1% 0% /usr/bin/lua /usr/bin/gl_clients_update
19441 1 root S 8952 0% 0% /usr/bin/cellular_manager
6765 1 root S 8312 0% 0% /usr/sbin/hostapd -g /var/run/hostapd/global -f /var/log/hostapd.log
6766 1 root S 7912 0% 0% /usr/sbin/wpa_supplicant -n -g /var/run/wpa_supplicant/global -f /var/log/wpa_supplicant.log
23812 1 root S 7748 0% 0% /usr/bin/sms_manager
3593 1 root S 6804 0% 0% wapp -d1 -v2 -cra0 -cra1 -cra2 -cra3 -cra4 -cra5 -cra6 -cra7 -cra8 -cra9 -cra10 -cra11 -cra12 -cra13 -cra14 -cra15 -
23139 1 root S 6336 0% 0% /usr/bin/eco /usr/bin/gl-dpi
5757 1 root S 5396 0% 0% /usr/sbin/uhttpd -f -h /www -r GL-BE14000 -x /cgi-bin -u /ubus -t 60 -T 30 -k 20 -A 1 -n 3 -N 100 -D -p 0.0.0.0:8080
6640 1 root S 4956 0% 0% eco /usr/sbin/gl-ngx-session
7331 1 chrony S 4564 0% 0% /usr/sbin/chronyd -n -l /dev/null
19039 1 root S 4040 0% 0% /usr/bin/eco /usr/sbin/gl-repeater
2941 1 dnsmasq S 2988 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.cfg01411c -k -x /var/run/dnsmasq/dnsmasq.cfg01411c.pid
2946 2941 root S 2984 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.cfg01411c -k -x /var/run/dnsmasq/dnsmasq.cfg01411c.pid
11837 1 nobody S 2304 0% 0% avahi-daemon: running [GL-BE14000.local]
21205 1 root S 2248 0% 0% /sbin/rpcd -s /var/run/ubus/ubus.sock -t 30
17187 1 root S 1996 0% 0% /sbin/netifd
1 0 root S 1760 0% 0% /sbin/procd
6834 1 logd S 1672 0% 0% /sbin/logd -S 512
11627 1 root S 1664 0% 0% /usr/bin/dbus-daemon --system
3884 21072 root S 1328 0% 0% /usr/sbin/dropbear -F -P /var/run/dropbear.main.pid -p 22 -K 300 -T 3 -W 262144 -2 9
14108 17187 root S 1308 0% 0% /usr/sbin/pppd nodetach ipparam wan ifname pppoe-wan lcp-echo-interval 1 lcp-echo-failure 5 lcp-echo-adaptive noipv6
21072 1 root S 1304 0% 0% /usr/sbin/dropbear -F -P /var/run/dropbear.main.pid -p 22 -K 300 -T 3 -W 262144
1604 1 ubus S 1292 0% 0% /sbin/ubusd
9113 1 root S 1276 0% 0% /usr/sbin/crond -f -c /tmp/gl_crontabs -l 10
3910 3885 root R 1276 0% 0% top
3885 3884 root S 1272 0% 0% -ash
8612 1 root S 1268 0% 0% /usr/sbin/crond -f -c /etc/crontabs -l 10
3868 3864 root S 1260 0% 0% sleep 20
3907 25506 root S 1260 0% 0% ping -c 3 -W 1 192.168.8.166
3870 3866 root S 1260 0% 0% sleep 40
18443 17187 root S 1260 0% 0% udhcpc -p /var/run/udhcpc-eth1.3.pid -s /lib/netifd/dhcp.script -f -t 0 -i eth1.3 -x hostname:GL-BE14000 -C -R
3866 9113 root S 1260 0% 0% /bin/ash -c sleep 40; /usr/bin/auto_timezone
3864 9113 root S 1260 0% 0% /bin/ash -c sleep 20; /usr/bin/auto_timezone
3865 9113 root S 1260 0% 0% /bin/ash -c sleep 30; /usr/bin/auto_timezone
3856 1 root S 1260 0% 0% /bin/login
3872 3865 root S 1260 0% 0% sleep 30
6662 6596 root S 1040 0% 0% /usr/bin/fcgiwrap -c 4 -s unix:/var/run/fcgiwrap.socket
6664 6596 root S 1040 0% 0% /usr/bin/fcgiwrap -c 4 -s unix:/var/run/fcgiwrap.socket
6663 6596 root S 1040 0% 0% /usr/bin/fcgiwrap -c 4 -s unix:/var/run/fcgiwrap.socket
6665 6596 root S 1040 0% 0% /usr/bin/fcgiwrap -c 4 -s unix:/var/run/fcgiwrap.socket
6596 1 root S 1040 0% 0% /usr/bin/fcgiwrap -c 4 -s unix:/var/run/fcgiwrap.socket
1705 1 root S 988 0% 0% /sbin/urngd
7981 1 root S 976 0% 0% /usr/bin/carrier-monitor
25506 1 root S 852 0% 0% /usr/bin/apcli_detectd 3 1
Mem: 879724K used, 1154272K free, 17700K shrd, 113100K buff, 140004K cached
CPU: 0% usr 0% sys 0% nic 98% idle 0% io 0% irq 0% sirq
Load average: 2.29 2.40 2.51 2/177 3918
28518 1 root S 11988 1% 1% /usr/bin/lua /usr/bin/gl_clients_update
578 2 root IW 0 0% 0% [kworker/1:5-eve]
17436 2 root SW 0 0% 0% [HwCtrlTask_0]
3916 25506 root S 1260 0% 0% ping -c 3 -W 1 10.53.175.133
CLI speedtest PC with Wireguard active over Wifi:
TOP Output:
23139 1 root S 6348 0% 0% /usr/bin/eco /usr/bin/gl-dpi
6640 1 root S 4964 0% 0% eco /usr/sbin/gl-ngx-session
29850 1 dnsmasq_ S 3080 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.wgclient2 -k -x /var/run/dnsmasq/dnsmasq.wgclient2.pid
29865 29850 root S 3076 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.wgclient2 -k -x /var/run/dnsmasq/dnsmasq.wgclient2.pid
29848 1 dnsmasq S 2988 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.cfg01411c -k -x /var/run/dnsmasq/dnsmasq.cfg01411c.pid
29857 29848 root S 2984 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.cfg01411c -k -x /var/run/dnsmasq/dnsmasq.cfg01411c.pid
422 21072 root S 1328 0% 0% /usr/sbin/dropbear -F -P /var/run/dropbear.main.pid -p 22 -K 300 -T 3 -W 262144 -2 9
423 422 root S 1272 0% 0% -ash
1283 25506 root S 1260 0% 0% ping -c 3 -W 1 192.168.8.166
1243 1239 root S 1260 0% 0% sleep 40
1241 1238 root S 1260 0% 0% sleep 30
1239 9113 root S 1260 0% 0% /bin/ash -c sleep 40; /usr/bin/auto_timezone
1237 9113 root S 1260 0% 0% /bin/ash -c sleep 20; /usr/bin/auto_timezone
1238 9113 root S 1260 0% 0% /bin/ash -c sleep 30; /usr/bin/auto_timezone
1213 1 root S 1260 0% 0% /bin/login
1244 1237 root S 1260 0% 0% sleep 20
Mem: 892424K used, 1141572K free, 17712K shrd, 113008K buff, 140016K cached
Load average: 2.29 2.63 2.62 3/190 1302
26489 1 root S 1406m 71% 1% /usr/bin/AdGuardHome --glinet -c /etc/AdGuardHome/config.yaml -w /etc/AdGuardHome -l syslog
28518 1 root S 12264 1% 0% /usr/bin/lua /usr/bin/gl_clients_update
578 2 root DW 0 0% 0% [kworker/1:5+eve]
27856 2 root IW 0 0% 0% [kworker/u8:2-ev]
24173 22520 root S 34952 2% 0% nginx: worker process
24170 22520 root S 32632 2% 0% nginx: worker process
24172 22520 root S 30624 2% 0% nginx: worker process
31108 1 root S 6812 0% 0% wapp -d1 -v2 -cra0 -cra1 -cra2 -cra3 -cra4 -cra5 -cra6 -cra7 -cra8 -cra9 -cra10 -cra11 -cra12 -cra13 -cra14 -cra15 -
514 423 root R 1276 0% 0% top
1302 25506 root S 1260 0% 0% ping -c 3 -W 1 10.53.175.133
CLI speedtest over MOBILE Phone with Wireguard NOT active over Wifi:
TOP Output:
OpenWrt 21.02-SNAPSHOT,
Mem: 884968K used, 1149028K free, 17700K shrd, 113192K buff, 140004K cached
CPU: 0% usr 2% sys 0% nic 97% idle 0% io 0% irq 0% sirq
Load average: 2.29 2.35 2.44 2/174 4633
24173 22520 root S 34512 2% 0% nginx: worker process
24170 22520 root S 32916 2% 0% nginx: worker process
24171 22520 root S 30228 1% 0% nginx: worker process
24172 22520 root S 30048 1% 0% nginx: worker process
28518 1 root S 12092 1% 0% /usr/bin/lua /usr/bin/gl_clients_update
23139 1 root S 6328 0% 0% /usr/bin/eco /usr/bin/gl-dpi
4614 21072 root S 1328 0% 0% /usr/sbin/dropbear -F -P /var/run/dropbear.main.pid -p 22 -K 300 -T 3 -W 262144 -2 9
4633 4615 root R 1276 0% 0% top
4615 4614 root S 1272 0% 0% -ash
4572 1 root S 1260 0% 0% /bin/login
4555 9113 root S 1260 0% 0% /bin/ash -c sleep 50; /usr/bin/auto_timezone
4559 4555 root S 1260 0% 0% sleep 50
4256 1 root S 852 0% 0% /usr/bin/gl_fan -T /sys/devices/virtual/thermal/thermal_zone0/temp -D 1000 -t 70
9 2 root SW 0 0% 0% [ksoftirqd/0]
17439 2 root SW 0 0% 0% [RtmpMlmeTask_00]
25 2 root SW 0 0% 0% [ksoftirqd/3]
Mem: 886792K used, 1147204K free, 17700K shrd, 113192K buff, 140004K cached
Load average: 2.26 2.34 2.44 2/175 4637
28518 1 root S 11788 1% 1% /usr/bin/lua /usr/bin/gl_clients_update
24173 22520 root S 34524 2% 0% nginx: worker process
24170 22520 root S 32944 2% 0% nginx: worker process
4315 2 root IW 0 0% 0% [kworker/1:1-eve]
4637 25506 root S 1260 0% 0% ping -c 3 -W 1 192.168.1.1
Load average: 2.24 2.33 2.44 2/173 4643
28518 1 root S 11708 1% 1% /usr/bin/lua /usr/bin/gl_clients_update
4643 25506 root S 1260 0% 0% ping -c 3 -W 1 192.168.8.106
Mem: 886600K used, 1147396K free, 17700K shrd, 113192K buff, 140004K cached
Load average: 2.30 2.35 2.44 2/173 4650
28518 1 root S 11736 1% 1% /usr/bin/lua /usr/bin/gl_clients_update
24170 22520 root S 32948 2% 0% nginx: worker process
32724 2 root IW 0 0% 0% [kworker/3:2-mm_]
24173 22520 root S 34556 2% 0% nginx: worker process
4648 25506 root S 1260 0% 0% ping -c 3 -W 1 192.168.1.1
CLI speedtest over MOBILE Phone with Wireguard ACTIVE over Wifi-7:
TOP output:
Xshell 8 (Build 0107)
Copyright (c) 2026 NetSarang Computer, Inc. All rights reserved.
Type `help' to learn how to use Xshell prompt.
[F:~]$
Connecting to 192.168.8.1:22...
Connection established.
To escape to local shell, press 'Ctrl+Alt+]'.
WARNING! The remote SSH server rejected X11 forwarding request.
BusyBox v1.33.2 (2025-10-10 07:14:26 UTC) built-in shell (ash)
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -| || | | || || |
_____|| |
||||___||| |____|
|| W I R E L E S S F R E E D O M
Mem: 888828K used, 1145168K free, 17716K shrd, 113292K buff, 140024K cached
CPU: 0% usr 0% sys 0% nic 100% idle 0% io 0% irq 0% sirq
Load average: 2.36 2.43 2.42 3/188 22571
24173 22520 root S 35320 2% 0% nginx: worker process
24170 22520 root S 32688 2% 0% nginx: worker process
24171 22520 root S 30144 1% 0% nginx: worker process
28518 1 root S 12384 1% 0% /usr/bin/lua /usr/bin/gl_clients_update
21721 1 root S 6804 0% 0% wapp -d1 -v2 -cra0 -cra1 -cra2 -cra3 -cra4 -cra5 -cra6 -cra7 -cra8 -cra9 -cra10 -cra11 -cra12 -cra13 -cra14 -cra15 -
23139 1 root S 6356 0% 0% /usr/bin/eco /usr/bin/gl-dpi
6640 1 root S 5056 0% 0% eco /usr/sbin/gl-ngx-session
19039 1 root S 4008 0% 0% /usr/bin/eco /usr/sbin/gl-repeater
21196 1 dnsmasq_ S 3080 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.wgclient1 -k -x /var/run/dnsmasq/dnsmasq.wgclient1.pid
21203 21196 root S 3076 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.wgclient1 -k -x /var/run/dnsmasq/dnsmasq.wgclient1.pid
21195 1 dnsmasq S 2988 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.cfg01411c -k -x /var/run/dnsmasq/dnsmasq.cfg01411c.pid
21200 21195 root S 2984 0% 0% /usr/sbin/dnsmasq -C /var/etc/dnsmasq.conf.cfg01411c -k -x /var/run/dnsmasq/dnsmasq.cfg01411c.pid
22523 21072 root S 1328 0% 0% /usr/sbin/dropbear -F -P /var/run/dropbear.main.pid -p 22 -K 300 -T 3 -W 262144 -2 9
22571 22524 root R 1300 0% 0% top
22524 22523 root S 1272 0% 0% -ash
22545 1 root S 1260 0% 0% /bin/login
22556 25506 root S 1260 0% 0% ping -c 3 -W 1 192.168.1.1
22499 9113 root S 1260 0% 0% /bin/ash -c sleep 30; /usr/bin/auto_timezone
22504 22500 root S 1260 0% 0% sleep 40
22498 9113 root S 1260 0% 0% /bin/ash -c sleep 20; /usr/bin/auto_timezone
22502 22499 root S 1260 0% 0% sleep 30
22503 22498 root S 1260 0% 0% sleep 20
22500 9113 root S 1260 0% 0% /bin/ash -c sleep 40; /usr/bin/auto_timezone
Mem: 892020K used, 1141976K free, 17716K shrd, 113292K buff, 140024K cached
CPU: 0% usr 5% sys 0% nic 85% idle 0% io 0% irq 8% sirq
Load average: 2.41 2.44 2.43 9/186 22576
22143 2 root IW 0 0% 1% [kworker/1:3-wg-]
21949 2 root IW 0 0% 1% [kworker/2:1-wg-]
4076 2 root IW 0 0% 1% [kworker/2:0-wg-]
578 2 root IW 0 0% 1% [kworker/1:5-wg-]
28518 1 root S 12612 1% 0% /usr/bin/lua /usr/bin/gl_clients_update
32724 2 root RW 0 0% 0% [kworker/3:2-wg-]
9 2 root RW 0 0% 0% [ksoftirqd/0]
25015 2 root RW 0 0% 0% [kworker/0:1+wg-]
4315 2 root IW 0 0% 0% [kworker/1:1-wg-]
21763 2 root RW 0 0% 0% [kworker/0:2-wg-]
21764 2 root RW 0 0% 0% [kworker/0:3+wg-]
22194 2 root IW 0 0% 0% [kworker/3:3-wg-]
11308 2 root IW 0 0% 0% [kworker/1:0-wg-]
Mem: 891860K used, 1142136K free, 17716K shrd, 113292K buff, 140024K cached
CPU: 0% usr 9% sys 0% nic 70% idle 0% io 0% irq 18% sirq
Load average: 2.62 2.49 2.44 2/186 22583
22143 2 root IW 0 0% 2% [kworker/1:3-mm_]
21949 2 root IW 0 0% 2% [kworker/2:1-wg-]
22127 2 root IW 0 0% 1% [kworker/2:2-dm_]
4347 2 root IW 0 0% 1% [kworker/1:2-eve]
25 2 root SW 0 0% 1% [ksoftirqd/3]
32724 2 root IW 0 0% 1% [kworker/3:2-mm_]
28518 1 root S 12348 1% 1% /usr/bin/lua /usr/bin/gl_clients_update
9 2 root SW 0 0% 1% [ksoftirqd/0]
21764 2 root IW 0 0% 0% [kworker/0:3-wg-]
25015 2 root IW 0 0% 0% [kworker/0:1-wg-]
31688 2 root IW 0 0% 0% [kworker/3:0-wg-]
21763 2 root IW 0 0% 0% [kworker/0:2-wg-]
20 2 root SW 0 0% 0% [ksoftirqd/2]
6640 1 root S 5064 0% 0% eco /usr/sbin/gl-ngx-session
Mem: 892404K used, 1141592K free, 17716K shrd, 113292K buff, 140024K cached
CPU: 0% usr 5% sys 0% nic 87% idle 0% io 0% irq 6% sirq
Load average: 2.57 2.48 2.44 6/184 22602
9 2 root RW 0 0% 2% [ksoftirqd/0]
21764 2 root IW 0 0% 1% [kworker/0:3-wg-]
21763 2 root RW 0 0% 1% [kworker/0:2-wg-]
4347 2 root IW 0 0% 1% [kworker/1:2-wg-]
28518 1 root S 12144 1% 1% /usr/bin/lua /usr/bin/gl_clients_update
578 2 root IW 0 0% 0% [kworker/1:5-wg-]
32751 2 root RW 0 0% 0% [kworker/0:0+wg-]
22143 2 root IW 0 0% 0% [kworker/1:3-wg-]
22194 2 root RW 0 0% 0% [kworker/3:3-wg-]
24172 22520 root S 30056 1% 0% nginx: worker process
32724 2 root IW 0 0% 0% [kworker/3:2-wg-]
22127 2 root IW 0 0% 0% [kworker/2:2-wg-]
24173 22520 root S 35444 2% 0% nginx: worker process
Mem: 892276K used, 1141720K free, 17716K shrd, 113292K buff, 140024K cached
CPU: 0% usr 10% sys 0% nic 75% idle 0% io 0% irq 13% sirq
Load average: 2.68 2.50 2.45 2/184 22607
9 2 root SW 0 0% 4% [ksoftirqd/0]
4347 2 root IW 0 0% 2% [kworker/1:2-eve]
25015 2 root IW 0 0% 2% [kworker/0:1-wg-]
21764 2 root IW 0 0% 2% [kworker/0:3-wg-]
21763 2 root IW 0 0% 2% [kworker/0:2-wg-]
32751 2 root IW 0 0% 1% [kworker/0:0-wg-]
22127 2 root IW 0 0% 1% [kworker/2:2-wg-]
22194 2 root IW 0 0% 1% [kworker/3:3-wg-]
28518 1 root S 12232 1% 0% /usr/bin/lua /usr/bin/gl_clients_update
21949 2 root IW 0 0% 0% [kworker/2:1-wg-]
21545 2 root SW 0 0% 0% [RtmpMlmeTask_01]
1271 2 root SW< 0 0% 0% [loop0]
Mem: 892496K used, 1141500K free, 17716K shrd, 113292K buff, 140024K cached
Load average: 2.63 2.50 2.44 2/182 22656
28518 1 root S 12660 1% 0% /usr/bin/lua /usr/bin/gl_clients_update
22143 2 root DW 0 0% 0% [kworker/1:3+eve]
4347 2 root IW 0 0% 0% [kworker/1:2-eve]
13313 2 root IW 0 0% 0% [kworker/u8:0-ev]
24173 22520 root S 35536 2% 0% nginx: worker process
22622 25506 root S 1260 0% 0% ping -c 3 -W 1 192.168.8.166
Quite long paste jobs :slight_smile: You are doing a review?
Just testing and make sure everything works as promised.
The problem only exist when over a wireguard connection with a mobile device the up/down speeds are half (Wifi 7) of what I get on my PC wired and over Wifi 7.
This is what I get over wireguard with the Flint 2 on OpenWrt snapshot :sweat_smile:
Without VPN
Thanks for your reaction.
But I only have the problems when connecting a mobile device over the Wireguard client in the Flint 4.
On my desktop I get nearly (i have a 1 Gbps symmetric fiber line) 900 Mbps up/down over the Wireguard as well as per cable (Ethernet) connected or over Wifi 7 or Wifi MLO.
On both mobile devices I only get half the speed connected to the Wireguard client as well over Wifi 7 or Wifi MLO.
So the question is why the mobile Android devices with both a Qualcomm Snapdragon Gen 3 SOC (they comply to the rules for Wifi 7 and MLO) I only get half the speed when connected to the same Wireguard client.
When I connect both mobile devices (Wireguard disabled so no tunnel active) via Wifi 7 and Wifi MLO then I get 1Gbps up/down without a problem.
So the culprit is somewhere in the firmware (my guess).
It could be a Mediatek/Android issue as I also don't see great speeds when the WiFi is routed via VPN on my S25 FE, Apple devices push the same speed as over ethernet
But the speed is ok (similar to the wired connection of my PC) when NOT using the Wireguard tunnel.
So the big question why it is halved on both mobile devices ( Xiaomi 14 Ultra and a Lenovo Tab-3 8.8 gen 3) when using the wireguard tunnel of the Flint 4?
I hope the helpdesk team can find an answer and hopefully a solution.
Thank you for providing the detailed test results.
We noticed one detail in the current results: the first WireGuard test shows the ISP as ProtonVPN, while the PC test over Wi-Fi with WireGuard enabled shows the ISP as NovoServe.
Therefore, could you please check the VPN policy/rules and confirm whether the PC is included in the VPN scope when it is connected through Wi-Fi?
And could you please run the speed test again, preferably using the same Speedtest server as the mobile phone test and the same VPN server/configuration?
  • PC over Wi-Fi, VPN disabled
  • PC over Wi-Fi, VPN enabled and confirmed to pass through the same VPN tunnel
Keeping the same Speedtest server and the same VPN server/configuration will allow us to compare the Wi-Fi performance of different devices more accurately with and without the VPN enabled.
Thank you again for your time and for helping us with these tests.
When Tunnel disabled it uses the IP from the provider.
When Tunnel active it uses the Proton VPN tunnel
PC over Wifi, VPN disabled:
PC over Wifi, VPN enabled over 1 tunnel only (same tunnel:
Mobile over Wifi, VPN disabled:
Mobile over Wifi, VPN enabled (over same tunnel as PC):
So all connections over the Wreguard tunnel are speedwise slashed in half.
For anyone having doubts about Flint4 wifi capabilities, here's my testing runing on my Fold8, ideal conditions, 3 meters away, the flint is on a high location, no vpn, connected to MLO (5 and 6Ghz).
Now running on the Flint directly (Maxed out Flints CPU capabilities since running here bypasses the HW acc and uses CPU)
Running on my Desktop (10Gb NIC card)
That’s nice, what chanel width are you using for each band?
I have 40mhz on the 25.GHz, 160mhz on 5GHz and 320mhz on 6GHZ but my Pixel 9 Pro XL will never connect to all three bands at once or on both the 5GHz and 6GHz bands simultaneously.
I have the same
I use the same, but I don’t use the 2.4Ghz on MLO.
I recommend you do some testing with different channels for each band.
Yes, that's is all well and good but I can't help remembering the bitter experience when all it took for other models was a firmware update that savagely slashed the radio transmission power of some of these routers rendering them useless for some users. People were boasting about the WiFi reach of these routers when they first bought them as one of their greatest selling points and then look at what happened since:
https://www.reddit.com/r/GlInet/comments/1ui3w21/poor_wifi_reception_on_the_flint_2_after_the_last/
Thanks, turning off 2.4GHz on MLO seemed to be trick to allow my phone to connect to both 2.4GHz and 6GHz. Unfortunately my phone just can’t take advantage of the extra bandwidth.
Seriously? Does Flint 4 run on the ancient OpenWrt 21.02 version?
I have Flint 2 running the same version, and glinet still hasn’t released a stable firmware for at least 22.05.
I’m expecting Flint 4 to come with a firmware based on OpenWrt 25.12.
If it’s shipped with such an ancient OpenWrt version, I don’t even see the point in buying it.
Is there hope that there will be an official glinet firmware for OpenWrt 25.12? I hope it will be vanilla...
