Flint 4 - compatibility with Zyxel PMG3000-D20B
I got my Flint 4 a couple of days ago. I want to use it as my main router and the SFP+ option to connect to my upcoming fiber ISP. As I have a private contract, speed will be limited to 1Gbit. So far that will be more than necessary - in particular when my kids will leave the house.
As I live in Germany, Deutsche Telekom is my ISP. They offer a compatible ONT SFP Stick in their shop: the Zyxel PMG3000-D20B.
Can anyone confirm that this SFP stick will work with the Flint 4 (unfortunately, the list of devices for this scenario is with 2 entries very limited).
Kind regrads,
Mario
PS If FW 4.10 with mesh support is coming, than I will have everything I need for my home network.
I’d imagine the number of users with your same scenario is minute to non-existent. That being the case, I’d try one yourself and see if it works. In my very limited experience, I’d imagine it will. I don’t think it will be plug and play though and some config will be required.
For example, I’m using an FS.com SFP BiDi, with generic FW in my Flint 4 to connect directly to my ISP. I needed to config a VLAN 100 on the SPF port to get it to work.
What I would suggest is that you research to find those using the Zyxel SFP module, with the same ISP you’re using, regardless of what router hardware they used, This will give you an understanding of what config they needed to use, to get it to work. That’s what I did originally and used the same SFP module and config on my previous Ubiquiti EdgeRouter, using information I found of someone using the same module and config with a Unifi UDM.
Neither we nor any community users have tested the Zyxel PMG3000-D20B, so its compatibility has not yet been confirmed.
For reference, the following page lists modules that have been tested by GL.iNet or community users:
The situation in the broader OpenWrt ecosystem looks promising, as a user has reported that the patch works and has submitted a pull request:
Could you share the exact purchase link or vendor for this module? We may be able to obtain one for testing.
The Flint 4 sees the Zyxel and with some changes I can access the sfp admin site. (10.10.1.1).
However, I don’t have a working connection. I get a signal, but the Zyxel stays in mode O1 and can not synchronize.
I am not able to understand or can apply the patch mentionend in the links provided. So do I have to wait or is there anything I can do?
(Building a way to the admin page was not so easy. Woudl be great if this could be added as an input feature for the GL inet admin page.)
Here is how far I got so far:
Test Result
Zyxel SFP detected :white_check_mark:
Ethernet connection :white_check_mark: 1 Gbit/s
Management via VLAN 2 :white_check_mark:
GPON modem ID matches :white_check_mark:
Optical receive power :white_check_mark: −15.73 dBm
Zyxel firmware V1.00(ABVJ.1)b1e
Flint 4 firmware 4.11.0 Beta 3
GPON connection :cross_mark: O1
I will double check if registration was done correctly.
