Flint 4 Firmware Roadmap
Dear GL Inet team, could we get a clear indication of lead time for next stable firmware update to resolve the many bugs reported since the router shipped?
Could you also confirm intentions regards to shipping stable firmware on either the openwrt 24 or 25 kernel and if there are likely to be the same issues with open source and proprietary driver performance that has plagued other GL Inet devices.
I'm sure everyone in the community would value transparency and clarification.
Thanks!
The current published plan is for Flint 4 to move to an OpenWrt 25-based firmware in the future; OpenWrt 24 and 25 are release branches rather than kernel versions. No verified release date or lead time for either the next stable bug-fix update or the OpenWrt 25 migration is currently available, so we cannot responsibly provide an estimate.
Whether the future firmware uses open-source or chipset-vendor wireless drivers—and the resulting performance trade-offs—also has not been publicly confirmed. That will require clarification from the product/firmware team; driver parity should not be assumed until the relevant builds are available and tested.
Admirable but tell us something we dont already know. Will wait for human to reply given you aren't privy to real world conversations around the office and slack channels Mr Bot.
You can find the beta firmware based on the MTK SDK OP25 here:
It should be released around the same time as the Slate 7 Pro update, although the precise schedule will depend on the testing results.
If you mean that you would prefer a vanilla OpenWrt version, please refer to the following:
Wow thanks will I wasn’t aware of the Op24 beta for the flint 4 being available
I will test this out when I get back home and report any issues.
thanks for answering all queries in sequence
The only thing you missed was, confirmation that, future main stable releases will be on this op24
or will the op24/25 branches continue to be only beta firmware and stable releases remain only on wrt21?
hopefully ambition for the gl Inet snapshots is to run on op24 and above for flint 4 going forward
To answer your question no I do not seek vanilla openwrt. I really like and value the Gl Inet gui and ease of configuration. Relying only on Luci and SSH commands for advanced config where unavoidable
There is a small typo: it is based on OP25.
Yes, future stable releases will also be built on OP25, unless this version encounters a major issue that significantly affects usability and neither we nor MTK can find a solution in the short term.
Awesome! Exactly what I hoped for! :+1:
Sorry Will one more Q.
Can I flash the new 4.11 OP25 beta 1 firmware and retain the existing configuration successfully via keep settings. Or should I assume need to reconfig?
Thanks!
I would reconfigure jumping from op21 to op25
Did think that thanks void. You running this snapshot now? Thoughts?
Yes I am running it. Very nice build. A few small cosmetic bugs but they will be fixed soon.
Cool am not home yet but going to flash it when I get back. Does it fix the rps_cpu issue?
Nope, was stills set to1.
Good to know. In fairness it was probably already compiled and being tested when we reported that. Roll on beta 2 then!
