is it normal that when running openvpn --version it says DCO version: N/A?:
$ openvpn --version
OpenVPN 2.6.12 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] [DCO]
library versions: OpenSSL 1.1.1v 1 Aug 2023, LZO 2.10
DCO version: N/A
Originally developed by James Yonan
Copyright (C) 2002-2024 OpenVPN Inc sales@openvpn.net
Also on the system logs when the openvpn server start it shows N/A:
Oct 31 19:11:57 flint4 ovpnserver[31605]: OpenVPN 2.6.12 aarch64-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] [DCO]
Oct 31 19:11:57 flint4 ovpnserver[31605]: DCO version: N/A
The module is loaded:
$ lsmod | grep dco
ip6_udp_tunnel 16384 2 ovpn_dco_v2,wireguard
ovpn_dco_v2 65536 0
$ modinfo ovpn_dco_v2
module: /lib/modules/5.4.281/ovpn-dco-v2.ko
alias: net-pf-16-proto-16-family-ovpn-dco-v2
alias: rtnl-link-ovpn-dco
license: GPL
depends: udp_tunnel,ip6_udp_tunnel
vermagic: 5.4.281 SMP mod_unload aarch64
And from the logs seem it's using it:
Oct 31 19:11:57 flint4 ovpnserver[31605]: net_iface_new: add ovpnserver type ovpn-dco
Oct 31 19:11:57 flint4 ovpnserver[31605]: DCO device ovpnserver opened
I'm just curious on why it doesn't show the version, but i guess is just a cosmetic thing right?
On my linux client it shows the version:
$ openvpn --version
OpenVPN 2.6.13 aarch64-unknown-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] [DCO]
library versions: OpenSSL 3.5.8 25 Aug 2026, LZO 2.10
DCO version: copr:0.2.20261029.1.el9
Compile time defines: enable_async_push=no enable_comp_stub=no enable_crypto_ofb_cfb=yes enable_dco=auto enable_dco_arg=auto enable_debug=yes enable_dlopen=unknown enable_dlopen_self=unknown enable_dlopen_self_static=unknown enable_fast_install=yes enable_fragment=yes enable_iproute2=no enable_libtool_lock=yes enable_lz4=yes enable_lzo=yes enable_management=yes enable_pam_dlopen=no enable_pedantic=no enable_pkcs11=no enable_plugin_auth_pam=yes enable_plugin_down_root=yes enable_plugins=yes enable_port_share=yes enable_selinux=no enable_shared=yes enable_shared_with_static_runtimes=no enable_small=no enable_static=yes enable_strict=no enable_strict_options=no enable_systemd=no enable_werror=no enable_win32_dll=yes enable_wolfssl_options_h=yes enable_x509_alt_username=no with_aix_soname=aix with_crypto_library=openssl with_gnu_ld=yes with_mem_check=no with_openssl_engine=auto with_sysroot=no
