Flint 4 - Wifi issues
Hi, i'm on the process of replacing my Negear R9000 by a Flint4, so far most things i need are working fine, but i noticed a few issue with WIFI:
1 - On my R9000 (DD-WRT v3.0-r63600) i was using for 5GHz wifi channel 100 (UU+6) 80MHz and i had good speeds around 600Mbs, but on the Flint 4 (v4.9.2) if i use channel 100 i get around 300Mbs, so i moved to channel 52 which is also totally empty in my area and i get between 800 to 1000 MBs.
The iperf bandwith tests were done from my PC (connected via LAN cable to the router) to my Samsung S24.
2 - I noticed my TV media player (odroid-c4 - coreelec) which uses a Realtek 8821CU usb dongle (https://www.amazon.de/-/en/dp/B0CFNY1269?ref=ppx_yo2ov_dt_b_fed_asin_title) connected to the Flint 4 sometimes looses connection. I noticed this while watching a movie on kodi (files are shared via nfs) and movie suddenly paused and then playback stopped. I also noticed one ore twice while streaming my PC desktop with Sunshine to kodi (moonlight addon). This never happens while connected to the R9000.
Flint 4 Settings:
GL.INET Wifi Settings:
TX Power: Max
Wi-Fi Mode: 11ac/ax/be
Bandwidth: 80 Mhz
Channel: 100 (DFS) / 52 (DFS)
And on LUCI i set the wifi country to US (option country 'US')
R9000 Settings:
Network Mode: AC / N Mixed
Channel Width: 80 MHz
Channel: 100
Extension Channel: UU (+6)
Allow Channel Overlapping: Disabled
Firmware Type: DD-WRT
Override Chipset Restrictions: Disable
TX Power: 30
Antenna Gain: 0
Cell Density: Disabled
U-APSD: Disabled
Disassoc Low ACK: Enabled
Noise Immunity: Disabled
QCA Q-Boost / TDMA: Disabled
SIFS Trigger Time: 0
Beacon TX Mode: Staggered
Protection Mode: None
RTS Threshold: Disabled
Airtime Policy: Disabled
Short Preamble: Enabled
Short GI: Enabled
Single User Beamforming: Enabled
Multi User Beamforming: Disabled
TX Antenna Chains: 1+2+3+4
RX Antenna Chains: 1+2+3+4
AP Isolation: Disabled
Beacon Interval: 100
DTIM Interval: 2
Airtime Fairness: Enabled
WMM Support: Enabled
Radar Detection: Disabled
ScanList: default
Sensitivity Range / ACK Timing: 500
Max Associated Clients: 256
Drop Clients with Low Signal:
Minimum Signal for authenticate: -128
Minimum Signal for connection: -128
Poll Time for signal lookup: 10
Amount of allowed low signals: 3
Web UI Access: Enabled
Multicast to Unicast: Disabled
Network Configuration: Bridged
Radio Time Restrictions:
Radio Scheduling: Disabled
Anyone has any clue what could be the cause for this 2 issues?
Could you help us with the following checks?
  1. Speed difference: Connect your Samsung S24 to the Flint 4 on channel 52, then repeat on channel 100.
    For each channel, check the Wi-Fi link speed reported by the phone and run the same iperf test.
  2. Connection drops: Do the interruptions occur on channel 52, channel 100, or both?
    Do other devices connected to the same 5 GHz Wi-Fi also lose connectivity at the same time?
  3. Could you please try a non-DFS 5 GHz channel available in your region, such as channel 36, while keeping the bandwidth at 80 MHz and all other settings unchanged.
    Test NFS video playback and Moonlight streaming again to see whether the interruptions improve.
If another interruption occurs, please note the time and export the router’s system logs before restarting the router or media player, then send the logs to us via private message.
Thank you for your support and understanding.
How to send private messages:
  1. Channel 52 / 100 Speed:
    Channel 52:
    Link Speed reported on the phone:
    Tx=1200 Mbps / Rx=1200 Mbps
    IPERF:
    iperf3 -f m -i 5 -t 60 -c 192.168.0.79  1
    Connecting to host 192.168.0.79, port 5201
    [ 4] local 192.168.0.6 port 39830 connected to 192.168.0.79 port 5201
    [ ID] Interval Transfer Bitrate Retr Cwnd
    [ 4] 0.00-5.00 sec 510 MBytes 855 Mbits/sec 157 2.30 MBytes
    [ 4] 5.00-10.00 sec 551 MBytes 924 Mbits/sec 7 2.13 MBytes
    [ 4] 10.00-15.01 sec 524 MBytes 879 Mbits/sec 118 1.89 MBytes
    [ 4] 15.01-20.00 sec 524 MBytes 880 Mbits/sec 0 2.08 MBytes
    [ 4] 20.00-25.00 sec 530 MBytes 889 Mbits/sec 0 2.16 MBytes
    [ 4] 25.00-30.00 sec 532 MBytes 892 Mbits/sec 0 2.37 MBytes
    [ 4] 30.00-35.00 sec 528 MBytes 887 Mbits/sec 33 2.27 MBytes
    [ 4] 35.00-40.00 sec 542 MBytes 909 Mbits/sec 0 2.42 MBytes
    [ 4] 40.00-45.00 sec 542 MBytes 910 Mbits/sec 0 2.44 MBytes
    [ 4] 45.00-50.01 sec 545 MBytes 914 Mbits/sec 1 2.63 MBytes
    [ 4] 50.01-55.01 sec 547 MBytes 918 Mbits/sec 0 2.78 MBytes
    [ 4] 55.01-60.01 sec 358 MBytes 600 Mbits/sec 114 2.57 MBytes
    1. [ ID] Interval Transfer Bitrate Retr
      [ 4] 0.00-60.01 sec 6.09 GBytes 872 Mbits/sec 430 sender
      [ 4] 0.00-60.01 sec 6.09 GBytes 871 Mbits/sec receiver
      iperf Done.
      Channel 100:
      IPERF:
      [ 4] local 192.168.0.6 port 60672 connected to 192.168.0.79 port 5201
      [ 4] 0.00-5.00 sec 300 MBytes 502 Mbits/sec 42 4.16 MBytes
      [ 4] 5.00-10.01 sec 253 MBytes 424 Mbits/sec 272 4.17 MBytes
      [ 4] 10.01-15.00 sec 270 MBytes 453 Mbits/sec 119 4.14 MBytes
      [ 4] 15.00-20.00 sec 256 MBytes 429 Mbits/sec 251 4.16 MBytes
      [ 4] 20.00-25.00 sec 278 MBytes 466 Mbits/sec 243 2.31 MBytes
      [ 4] 25.00-30.00 sec 263 MBytes 442 Mbits/sec 75 4.16 MBytes
      [ 4] 30.00-35.00 sec 289 MBytes 484 Mbits/sec 277 1.41 KBytes
      [ 4] 35.00-40.00 sec 340 MBytes 571 Mbits/sec 735 2.88 MBytes
      [ 4] 40.00-45.00 sec 293 MBytes 491 Mbits/sec 450 4.37 MBytes
      [ 4] 45.00-50.00 sec 268 MBytes 450 Mbits/sec 316 4.08 MBytes
      [ 4] 50.00-55.01 sec 267 MBytes 449 Mbits/sec 453 4.00 MBytes
      [ 4] 55.01-60.01 sec 524 MBytes 879 Mbits/sec 43 2.41 MBytes
      [ 4] 0.00-60.01 sec 3.52 GBytes 504 Mbits/sec 3276 sender
      [ 4] 0.00-60.01 sec 3.52 GBytes 504 Mbits/sec receiver
      iperf Done.
  2. / 3. - The interruptions on the odroid-c4 happen with any of the 3 channels 36 / 52 / 100
Thank you for the results and logs.
The ping test from the Flint 4 to the Odroid shows 48% packet loss. The PC-to-S24 iperf results also show lower throughput and significantly more TCP retransmissions on channel 100 compared with channel 52.
To investigate further, could you help us with these checks?
  1. Please run a continuous ping from the Flint 4 to the Odroid, first while the Odroid is idle for 3–5 minutes, then while playing an NFS video until the interruption occurs.
    Continue the ping for a few minutes after stopping playback, please save the ping output, with timestamps if possible, and note when playback starts, when the interruption occurs, and when playback stops.
  2. At the same time, please ping another device connected to the same 5 GHz Wi-Fi, such as your S24, to check whether it also experiences packet loss.
  3. Would you be able to use your R9000 to capture over-the-air Wi-Fi traffic between the Flint 4 and the Odroid while the issue occurs?
    Configure the R9000’s capture interface in monitor mode on the same 5 GHz channel and channel width as the Flint 4, and keep the channel fixed throughout the capture.
    Place the R9000 near the Flint 4 and Odroid so it can receive traffic from both devices, and start capturing before the ping and video playback tests.
    You can refer to the ath10k monitor-mode guide, which includes an example for channel 36 at 80 MHz.
Please share the ping test results and send any logs or capture files, if available, to us via private message.
Thank you for your patience and cooperation.
I suggest you return it. The 5ghz band on the Flint 4 is the most buggy of them all. Basically all IOT (non smartphone/laptop) devices that support 5ghz hate the Flint 4. My camera, my printer, my Google Home smart speakers, all had no issues on the 5ghz band on my previous router, an Asus AX86U, but they consistently have connection issues with my Flint 4.
This was one month ago. I still see no signs of any fixes for a basic function of a WiFi router, which is to to connect devices wirelessly to the internet and to each other. I see gl-inet prefer to release new products, dabble into new product categories and test and develop other less important features of their WiFi router while leaving WiFi itself basically broken. In fact, I have tested their betas and they only made it worse.
I decided when I faced these issues from a month ago, I would wait for firmware updates that would fix all these WiFi issues. I have regretted it so far and til today my IOT devices are not useable. Do not make the same mistake as me if you can return your Flint 4, or better still, if you live in a country with better consumer protection and complain to your government how you bought a device that doesn't work as advertised.
I have no problems with this using various devices, and good throughput; it works with every Wi-Fi band with different devices, smart home devices, laptops, etc.
But I've noticed one thing: iperf isn't the best choice for mobile devices here; for mobile devices like poco phone and tablet I use openspeedtest, which gives me about 1500Mbit/s with WiFi 6 devices, which is good.
Hi, regarding my issue with connection from my odroid-c4 to the Flint 4, i found the problem, and is now fixed.
I did a full reset, and after reset the odroid-c4 was not having any issues connecting to the Flint 4, i tested it for 24h, it was stable, no disconnects.
By default the Flint 4 txpower on all 3 wireless interfaces (2.4GHz / 5GHGz / 6GHz) is 3%:
uci get wireless.MT7990_1_1.txpower
3
uci get wireless.MT7990_1_2.txpower
3
uci get wireless.MT7990_1_3.txpower
3
This was not enought for the Flint 4 5GHz wireless signal to reach my bedroom on the upper floor of my house, so i changed it to 100%
uci set wireless.MT7990_1_1.txpower=100
uci set wireless.MT7990_1_2.txpower=100
uci set wireless.MT7990_1_3.txpower=100
uci commit wireless
wifi down; wifi up
After this the signal was fine on my room, but seems this is one of the settings that created some kind of issue with the connection from the odroid-c4 which is on the same room as the Flint 4,
as soon as i changed the txpower to 100% the issues with the odroid-c4 came back.
So now i have it as 15,70,3, and no issues with the odroid-c4, stable for the past 24h.
uci set wireless.MT7990_1_1.txpower=15
uci set wireless.MT7990_1_2.txpower=70
uci set wireless.MT7990_1_3.txpower=3
Btw, changing Transmit Power on the GL.Inet UI doesn't have any effect, txpower remains with value 3 no matter which Transmit power you select on the GL.Inet UI, so that's why i'm changing it via luci/uci.
One other thing i noticed, is that besides the txpower seems i might have another setting that i probably changed on luci that also interferes with the odroid-c4 connection,
because i restored my backup were i had all my custom settings applied, then changed the txpower to 15,70,3 and the problem on odroid-c4 came back,
so now i reseted again and i'm applying my settings in small batches to see if i can find out which other setting is creating problems.
Regarding the channel 100 issue, even with full reset it still performs badly compared with channel 52.
