Hello. I guess that the firmware for the Flint 4 is being written, would it be possible to add as feature the MLO for the WDS client/AP? By having 3 Flint 4 connected via wifi, one as WDS client, and the other 2 as WDS AP, it would help a lot in cases in which cables can’t be deployed to connect devices.
Yes, Flint 4 is in development, but it seems that MLO functionality is not yet supported in repeater or WDS mode.
It can support connecting to MLO WiFi, but in reality it can only connect to single-band WiFi and does not have MLO functionality.
However, I will document this issue and report it to see if the requirement can be met.
Thank you.
Hello @lucas2 , can the requirement of having MLO in WDS be met?
WDS connectivity to MLO WiFi is not currently in the plans, but repeater functionality is being developed.
