I’m running NORDVPN on my new Flint.
Also, I have enabled Adguard home which uses cloudflare as upstream.
When I’m doing dnsleaktest.com,
my DNS is leaking to NORDVPN, which should not happen, all my DNS queries should be going to cloudflare via ADGUARDHOME.
You need to change DNS settings in the adgaurd Home Settings page accessed in the Gl-iNet GUI. Then navigate to adgaurd Home DNS settings pull down tab and change upstream DNS to your preferred DNS.
Hi sorry if your answering another post but the 127.0.0.1#3053 is done by AdGuard normally just appears by default in the DNS on the internet page and custom DNS also in LuCI under WAN, but on my GL-MV1000 I have been trying to put it in manually but it won’t let me because of the #3053, my GL-AX1800 does show 127.0.0.1#3053 but it leaks 5 DNS settings turn off AdGuard and it shows one so a little lost which is the best way to go about it.
