Flint AX1800 in Access Point mode
Hi All,
I've been using a Flint as an AP for months now, simply by setting it up in Access Point Mode, nothing fancy. My main router is a Brume2 and the Flint connects to this via an ethernet connection to a Cisco switch.
I've been snooping around Luci and noticed that the Interface Configuration for wlan1 is set to "Access Point (WDS) ". Is that correct? "Access Point" is available on the drop-down list and I don't know why this isn't what it's been set to. Firmware v4.6.8. It's no biggie but I'm curious.
As an aside, I had upgraded to v4.7.0 but started getting errors from devices stating they couldn't get an IP address, so I reverted to the last stable version and it's been fine.
Cheers,
Ades
If it works on AP mode, the wireless interface radio0 / 1 will be set to the access point (WDS).
This is a normal behavior.
After upgrading to 4.7.0, clients cannot get IP, if you manually set up a static IP (within main router subnet), is the Internet access normal? Can it access SSH? I did not reproduce.
Thanks Bruce for clarifying. All good.
I did try putting a static on after I did a hardware reset and it was still in Router mode. This got overwritten when AP was switched on, as I would expect. I have reserved the DHCP address on the Brume2. Its working fine under the last stable firmware and I won't be upgrading until v4.7 is finally released
i have 2 flint ax1800, one router, one access point. All worked fine until 4.7 was applied to both a few days ago.
Router seems fine but access point won't connect to mobile device for several minutes.
Like above I set a static IP before switching to AP but was also overwritten by AP enable. I added IP reservation for AP. Same behavior, very bad.
When AP finally allows client connect internet is normal. I haven't tried SSH and not sure how I would. I'm using UI. Although if you hummed a few bars of Luci I could probably pick it up.
Solution above is not working for me. Please help 4.7 on ax1800 AP. TIA
Issue NOT resolved in iOS wifi connection settings. This behavior of taking several minutes for AP to connect continues and is new with 4.7.0 install. Sorry for reporting resolution prematurely.
Unresolved.
Still iOS 18.3.2 won't connect to AP for several minutes on 4.7.0 AX1800.
Connects instantly to 4.7.0 AX1800 router. Win 11 laptop connects immediately to 4.7.0 AP, but I don't usually connect laptop out there.
iOS connect fail on AP is NEW BEHAVIOR on 4.7.0. With there be an update soon?
I guess I can switch AP to router and check. Double NAT doesn't matter to me out there. But I don't like it.
I tested on the AX1800 with v4.7.0, AP mode (the primary router is MT2500), and iPhone with iOS 18, it connects to the AX1800 router without issue.
  1. Please try to reset the AX1800 and test again. If no luck, please also export the issue syslog and share with us to check.
  2. Please try downgrade the AX1800 firmware to v4.6.8.
  3. Please do not set the 2.4GHz and 5GHz WiFi of AX1800 are the same SSID.
I always ran same SSID on 2.4 and 5GHz without issue. This log still has same SSID, for now, hardware Reset multiple times, exact same behavior each time.
I'd be happy to revert to 4.6.8 but I couldn't find the download.
I hope to avoid renaming SSID but I will if you can't identify issue with this log. TIA
logread.tar (122.5 KB)
You can see that the wireless client is repeatedly connected in 2.4GHz WiFi and 5GHz WiFi.
However, the AX1800 does not support Band Steering, and the 2.4GHz and 5GHz SSIDs cannot be set to the same.
Find it on: GL.iNet download center
Thank you very much! I could not see or understand that repeated connection change between 2.4 and 5GHz without you.
Now I have to decide between three things: Rename one SSID, downgrade AP to 4.6.8 (which had no such connection issue -- but I expect contains issues resolved in 4.7.0) OR replace at least one router if i want to avoid identifying and reconnecting 2.4GHz devices.
Do you have any hardware that DOES support Band Steering?
None of your solutions worked: downgraded AP only to 4.6.8, same lag (+/- 2 minutes to receive ip) to connect iOS. Logs can tell that story.
Renamed SSID on ax1800 router and ap on 2.4, same behavior. Upgraded ap again to 4.7.0, both ax 1800, router and ap, same same behavior. Since long lag came about with upgrade to 4.7.0 and the lag was never present on 4.6.8 and your recommendations made no difference, hardware "band steering" does not seem to be at issue.
Thank you for the 4.6.8 download link.
I appreciate anything the logs may suggest and escalation.
logread-2.tar (119 KB)
Now I've rolled both router and ap back to 4.6.8, setup a normal roaming network with same SSID and PW on both 2.4 and 5GHz on both devices. Wifi connects to iPhone 13 iOS 18.4.1 as before, as always, perhaps under 2 seconds.
I hope logs help. Skipping this update.
Also I see I was lame in providing logs with only ap logs before. nI'm willing to upgrade both to 4.7.0 again and upload both logs if it helps. LMK
logread-AP.tar (134.5 KB)
logread-Router4-6-8.tar (136 KB)
I checked the v4.6.8 main router and AP syslog and also saw that device with the MAC ending ":79:6f" which jumps between the WiFi of AP and main router, but it seems that the client WiFi connection is more stable.
So if v4.6.8 is more suitable for your scenario, please keep this firmware version for the time being.
Thank you.
I have tried with different SSID it still results in the same issue.
I am having the same issue with mine after upgrading to 4.7.0. I have had the AX-1800 for over 4 years now and never had this issue before. I thought I was going crazy since that's what I mainly use it for too as an access point. Glad to hear I am not the only one
Could you please PM me the issue syslog of AX1800 v4.7.0?
Hi bruce,
Unfortunately I downgraded to 4.6.8 and I don't have the syslog for v4.7.0 but I can try to upgrade again and generate that. I want to confirm that I haven't had any issues since downgrading to 4.6.8
Thanks for your reply.
The v4.8.0 firmware is coming soon, may about next month.
I think we can wait for the v4.8.0 beta firmware to release and upgrade to v4.8.0 before testing. Currently, please use v4.6.8 first.
If the v4.8.0 firmware still reproduces the issue, please export the logs and share to us. Thanks.
