I’m notice that my flint router often Wi-Fi disconnect and reconnect on each day. Especially if the VPN server or VPN client is toggle on, each of 2 days the WIFI totally disconnected and need to reapply back the the connection for PPPOE as am used for my main router.
What is the problem pls? Here is my log : log.zip (65.3 KB)
$ cat system.log |grep PAP
Sun Dec 11 08:23:21 2022 daemon.err pppd[12859]: PAP authentication failed
Sun Dec 11 08:23:25 2022 daemon.err pppd[13823]: PAP authentication failed
Sun Dec 11 08:23:29 2022 daemon.err pppd[14850]: PAP authentication failed
Sun Dec 11 08:23:33 2022 daemon.err pppd[15845]: PAP authentication failed
Sun Dec 11 08:23:34 2022 daemon.err pppd[16867]: PAP authentication failed
Sun Dec 11 08:23:38 2022 daemon.err pppd[17527]: PAP authentication failed
Sun Dec 11 08:23:42 2022 daemon.err pppd[18652]: PAP authentication failed
Sun Dec 11 08:23:46 2022 daemon.err pppd[19664]: PAP authentication failed
Sun Dec 11 08:23:50 2022 daemon.notice pppd[20682]: PAP authentication succeeded
I guess if internet is not accessible, the station will try to disconnect wifi connection.
Could you check /etc/config/network config for pppoe username and password when issue happens?
