Just upgrade my Flint to beta firmware 3.213, any change/fix compares to last version ?
alzhao
2
Not a relase notes here, but some fix:
- fix usb samba share crash
- fix some wifi setting bug when using wireguard
- fix some bug related to firmware upgrade
- support unique wifi ssid and key
- fix mullvad config pull
VerZZX
3
When will OpenWRT 21 be released?
Yes exactly, when will the OpenWrt be upgraded to more recent version?
Check this thread and look under Blaze. You may find what you are looking for. Not a gl-Inet build, all questions should use OpenWrT forum. Enjoy
