Just wanted to check if there’s any updates on the Easytether Driver for the IPQ6000 CPU.
Else, what USB Modem would you recommend to purchase? My carrier has a very limited tethering data, so I can only use the regular data for it to work.
Thanks!
Thanks!
No. There is no easytether driver for IPQ6000
