It is normal Flint load 90% memory in use? I connected around 22 devices (few wireless, others trough a router connected via Ethernet).
Seeing some of you having the no internet at all connection when using VPN trough wifi but Ethernet works fine. Tried everything. I’m following up those threads to see anybody else curls find a fixing.
I’m also having intermittent internet loading stuck using wifi no VPN no IPv6. My devices suddenly stop surfing the web with webpage not loading. Some of my devices pop ups a “Not internet connection” note in network settings.
Yap, the memory on my Flint is always almost 90% even just few Wi-Fi devices connected.
If you enable AdGuard Home, it will eat up to 99% memory usage, sigh !
Anyway I ended resetting the router con configuring everything again, I discover problem is related to the VPN policies. Not sure the cause but without any policies configured, router works well. With policies not so much, sometime it hang the connection and only solution is a manual reboot.
Initial problem regarding no internet trough wifi but Ethernet only, is solved itself after resetting.
Btw love the speed. Really good for my taste and previous routers I was using lol.
