I would like to install the collectd system (an amazing tool, Google it if you’ve never heard of it…), but received the following error when I tried to install the luci-app-statistics package:
Collected errors:
satisfy_dependencies_for: Cannot satisfy the following dependencies for luci-app-statistics:
I understand this router is stuck on OpenWrt Chaos Calmer 15.05.1 due to the lack of Qualcomm drivers for the current distributions of OpenWrt, and that it uses the “ipq40xx” architecture, from the OPKG-Configuration:
Are you running the GL firmware, the one out of the box?
If yes, you should log into the UI and go to the Plugins page, click Update and then find the package you want to install. It should work then.
If you can’t install a package or you can’t find it, you can also download the IPK from the last URL you linked, and then use “opkg install <package_file_name>” from SSH.
It’s safe since it is directly from the GL site, but you might get some linkage errors if things aren’t compiled for the same kernel version. You will just have to give it a try.
