As in I cannot figure out why they both froze up when running together. The reason I posted this in the first place. Now that my NordVPN is runing pretty solid at the moment I am hesitant to add back Adguard until I fully test the ability to connect and disconnect a VPN. Both TCP and UDP… Also I want to be able to stay disconnected when I reboot. The issues I had before would not allow that. Only after I factory reset was I able to get out of the loop.
Once I can do that without issue I will introduce adguard back in and then test it for enable and disable… And retain that setting after a reboot…
