Hi there,
sorry for a lot of topic, but today bank holiday so i’m spending a lot of free time
Anyway. There is no more button uPnP with release 2 and firmware 4?
After I’ve connected the ps4 that seems it doesn’t work.
error with firewall.
Any ideas?
thanks a lot
Which Firmware you using??
You migh have to opkg install the luci app and miniupnpd to get it to work, else it is the issue i had with my compiles on my linksys where i had to do some symlinking for xtables-legacy to iptables and iptables6 for it to work.
That’s my system
Weird because on 2,4 instead 5gz ps4 working
Are you using my build, just clean OpenWRT or using GL-iNet’s?
Either way you can quickly find out what is going on.
Go to Services -> UPNP
the check the Enable additional logging
Box.
Then in the MiniUpnp ALC
section add a new line then put in a lable followed by the IP of the system in question for example 192.168.1.166/24
making sure the ports are set to 1024-65535
then make sure it is set to allow
. Then click save and apply.
Once done you can then check the system logs to see where the issue is, if it can not pick up the external IP then go to UPNP area again select advance tab and under STUN
add
STUN Host: stun.sipgate.net
STUN Port: 3478
Save and apply again.
thanks for your help,
now is available
but still i don’t understand why working only in 2,4gz my ps4 now…
Is both the 5Ghz and 2.4Ghz connecting to the same network aka br-lan?
If it works on 2.4Ghz it should work on 5Ghz.
You could always DM me you /etc/config/network config file and /etc/config/wireless config file just null out you said and psk info it any other sensitive info.
thanks for your help I’m not at home at the moment, I will in a few days. if still not working I will dm you:D
Thanks again
No problem, i find it puzzling that upnp only works on 2.4ghz myself.
Hi, you seem to be very knowledgeable about this stuff, so maybe you can help me, I have been struggling to get my PS4 to work with remote play which I think is not working as I have been using a mobile hotspot which has been stuck on NAT3 with no upnp I believe, it works for PS4 online gaming but I believe the NAT3 is limiting me from Remote play, I just purchased the Slate AX-1800 thinking this can hopefully fix this issue. I want to know how to open upnp and the ports maybe needed for PS4 derestrictions, I think I need to start with openwrt but I am not sure where is the best place to download from that is compatible with my device, I believe luci is already pre installed I am not sure if upnp is maybe already in here ? sorry for the long message I have just realised ive been typing away!
If you using a mobile hotspot you will struggle to get past stricted. Nat due to what networks they use. Look up port forwarding on CG-NAT.
