Yes, map_4-13 package online now, opkg update and install works.
Yes I am already in map-t… this evening I will test your settings… thanks
Ciao,
I am using a B1300 with OpenWRT 19.7 and MAP. I attached the ONT to the Glinet router, waited 1 hour but got no IP from Sky wifi
I am getting these messages in the log:
daemon.err odhcp6c[1911]: Failed to send RS (Address not available)
daemon.err odhcp6c[1911]: Failed to send SOLICIT message to ff02::1:2 (Address not available)
daemon.err odhcpd[1056]: Failed to send to ff02::1%lan@br-lan (Address not available)
but I see DISCOVERs and SOLICITs being sent via tcpdump.
What am I missing?
Can you share your conf?
Here it is:
config interface ‘loopback’
option ifname ‘lo’
option proto ‘static’
option ipaddr ‘127.0.0.1’
option netmask ‘255.0.0.0’
config globals ‘globals’
option ula_prefix auto
config switch ‘switch0’
option reset ‘1’
config interface ‘lan’
option ifname ‘eth0’
option force_link ‘1’
option type ‘bridge’
option netmask ‘255.255.255.0’
option multicast_querier ‘0’
option igmp_snooping ‘0’
option hostname ‘GL-B1300’
option ipaddr ‘192.168.1.1’
option ieee1905managed ‘1’
option ip6assign ‘64’
option ip6hint ‘0000’
option ip6ifaceid ‘::1’
config interface ‘wan’
option ifname ‘eth1.101’
option proto ‘dhcp’
option ipv6 ‘1’
config interface ‘wan6’
option proto ‘dhcpv6’
option reqaddress ‘try’
option reqprefix ‘auto’
option ipv6 ‘1’
option disabled ‘0’
Hi Guys, I 'd love to configure my new MT3000 Beryl with MAP-T and SKY WIFI in Italy does anyone can help?
Cheers
G.
