You’ll find it when you edit your WiFi within the wirless settings
Thankyou admon! That’s exactly what I meant but I can’t draw as good as you ![]()
Print screen key… But I’m on android and can take screen shots by holding buttons… I’m just a lazy bar steward to be honest…
I think you’re getting this on the main screen so you’re not deep enough in.
You need to go to Network->Wireless->Edit (on your main WiFi SSID).
thanks limbot
. Could not see the menu white text in the black background colored bar. That’s my excuse anyway ![]()
Hey shivadow, thanks for your last shot in the dark. My country code setting is Australia and that’s correct for me. Thanks for your suggestion anyway. cheers
Now you have the right area, you might want to look at and try this one too:
“1. I DID look at the wireless section on Luci. There is no place on my firmware revision (4.4.60) to “enable legacy 802.11b rates”. See attached pic”
Weirdly and coincidently, I’ve just had to turn on the “enable legacy 802.11b rates” to enable my Wii to connect to my router (Flint 2) ![]()
Not really weird. The Nintendo Wii is so old that it does not support modern WiFi standards.
Wanna hear something funny? I don’t know why but my Nintendo Wii can connect to my Beryl AX without 802.11b legacy enabled. But any other openwrt router I need to enable it. That’s a mystery.
That is funny. We can’t win ![]()
