Hi @alzhao
I have the same issues even with firmware 3.207
Hi @alzhao
Hi morcheba:
Memory is increased as the system runs. But will be freed when the system needs to use memory.
same issue . crashing or rebooing after 30 mins
What is the firmware version?
Please update latest firmware: GL.iNet download center
Then open ‘enable crash log’
i found my problem . whene DLNA or file sharing is ON my router memory going to 95% or higher . i most disable DLNA and file sharing for fix my issue
sry i asking on old thread. is this problem already fixed?
im on 3.214 my memory usage always 96%
i run your command and become 69%. is i need to execute this command regulary? is there negative effect?
im using adguard home too.
thanks
No negative effect. Can you try firmware 4.1?
got it. for now i stick with your script if the memory growing abnormaly again.
for the 4.xx fw will try the next weekend. thanks
