the Flint is my home router. I am trying a configuration with fireguard both as client and as vpn server.
The VPN client is configured for routing traffic only for a single device in the network.
At the beginning everything works fine, however once the VPN client is turned on I have consistent internet downtime in the whole LAN: every ‘x’ minutes (I would say random but difficult to say) all the network devices lose connectivity and their packets are not routed anymore. This happens both on device connected wirelessly and devices connected via a LAN cable to the Flint.
In the logs, I see frequently at random times (between 30 secs and 3 minutes) the following lines (always the same):
Sun Jan 22 15:13:58 2023 user.notice route_policy: default_policy=0 mac_list=LISTOFMYMACADDRtoUSEVPN
Sun Jan 22 15:13:58 2023 user.notice route_policy: vpn_dns_via= dns_via=192.168.1.1 manual_dns=127.0.0.1
Sun Jan 22 15:13:58 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Did anyone experience this?
As shown above, if this feature is turned on, your device will have access to devices in the upstream subnet, such as printer and NAS.The main scenario is to give clients access to devices in the upstream subnet, but there is no way for the router to distinguish between the upstream subnet and the Internet, so if the traffic in the client device is accessed directly through IP, there may be a risk of leakage, so this option and Block Non-VPN Traffic are mutually exclusive.
