alzhao
43
I got a case that this happens on ProtonVPN Wireguard. It does not come with a pre-shared key.
I am testing ProtonVPN Wireguard now.
Same issue here - works on the laptop itself, but can’t connect my router.
Tue Nov 29 13:26:32 2022 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Tue Nov 29 13:26:37 2022 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Serd
45
This is my endless loop
I have two wireguard VPN servers (created with pivpn) on two different raspberrys, but after updating to the last Flint version I can’t connect to them, but they are working as I can connect using MV1000 and using the android wireguard client
Any ideas ? Do you need any extra info?
Are you using GUI of LuCi for setup?
alzhao
48
It does not connect at all, or it connect and break?
If it is the first case, may need to verify the config once again on your phone etc.
If you can, send me one config in private message.
Serd
49
it doesn’t connect
it works in the MV1000 and in the phone
I am getting the same problem
tech333
52
Same. Did anyone figure this out? @alzhao @Serd
Update Uboot
Do a clean install to 4.x using Uboot
Setup.
Most of the issues is caused by keeping settings
Back ups that are created in LuCi seem to work (don’t reuse a backup config file generated in 3.x
tech333
54
Thanks for replying. Looks like it was a config file misconfiguration with the public key. I got it working, but now I keep getting this in the log, is it normal?
Mon Jan 16 16:45:47 2023 kern.info kernel: [ 1147.694386] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Mon Jan 16 16:45:47 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Mon Jan 16 16:47:47 2023 kern.info kernel: [ 1268.161091] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Mon Jan 16 16:47:47 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Mon Jan 16 16:49:47 2023 kern.info kernel: [ 1388.646300] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Mon Jan 16 16:49:48 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Mon Jan 16 16:51:48 2023 kern.info kernel: [ 1509.035397] wireguard: wireguard-hotplug IFNAME=wgclient ACTION=KEYPAIR-CREATED
Mon Jan 16 16:51:48 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=KEYPAIR-CREATED SHLVL=1 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/
Who is the VPN provider? alzhao I think did mention something about certain VPN that the keypair did not work. Also it might be a issue in you vpn config file.
Not sure if this is related:
tech333
56
It is my own wireguard server router on openwrt 23.03.03 at a different location setup using the wireguard server setup wiki on openwrt. The DNS is the main router IP address, which the openwrt server router is behind. Here is my config file for the client:
[Interface]
Address = 192.168.9.2/24
ListenPort = 51820
PrivateKey = yGzJjxxxxxxxxxxxxxxxxxxxx
DNS = 192.168.4.1
[Peer]
AllowedIPs = 0.0.0.0/0
Endpoint = exaxxxx.duckdns.org:51820
PersistentKeepalive = 25
PublicKey = Eorq+jDgkxxxxxxxxxxxxxxxxxxx
PresharedKey = es79xpyxxxxxxxxxxxxxxxx
alzhao
57
Pls check if your ddns resolves to the same IP everytime.
I also observe that your used 192.168.9.x and 192.168.4.x subnet. Pls make sure these are valid.
If you cannot make it work at all, it may be your server side set up.
I have the same issue. It stays in a loop trying to connect.
In my GL-MT300N-V2 everything works fine.
I just upgraded to a GL-MT2500A and I cannot connect to my Wireguard VPN.
I am using VPN Unlimited as a VPN provider.
And I have an additional issue that I do not know if it is related…
When I stop my failed wireguard connection, I lose connection to the internet. I need to restart the router in order to get connection to the internet.
Got it working! And found my problem…
When adding Manual configuration, it is ignoring Peer PresharedKey. I add in Item Mode and got it working.
alzhao
60
I remember this bug. It should have been fixed in latest firmware.
Up^ I have the same “issue” in my logs @alzhao is it OK?
alzhao
62
Log does not show the reason. But the latest snapshot should have fixed everything.
MELIM
63
i have same issue version 4.0.3 Release 7
wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Mar 31 09:32:39 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\nFri Mar 31 09:32:44 2023 user.notice wireguard-debug: USER=root ifname=wgclient ACTION=REKEY-TIMEOUT SHLVL=2 HOME=/ HOTPLUG_TYPE=wireguard LOGNAME=root DEVICENAME= TERM=linux SUBSYSTEM=wireguard PATH=/usr/sbin:/usr/bin:/sbin:/bin PWD=/\n"
