I have the mentioned Flint with 4.1.0 release3, configured an Open VPN client on it to connect to a VPN server. Also enabled DDNS but it detects the IP of the remote VPN server, not the router’s own external IP. It also says that local IP detected. “Services from GL.iNet don’t Use VPN” is turned on.
I won’t be able to upgrade the fw now to test it with the latest release unfortunately so I cannot confirm if this is still the same in those.
In the logs I can see this:
Detect local IP on 'web'
#> /usr/bin/curl -RsS -o /var/run/ddns/glddns.dat --stderr /var/run/ddns/glddns.err --noproxy '*' '[http://checkip.dyndns.com](http://checkip.dyndns.com/)'
Local IP 'REDACTED_VPN_SERVERS_PUBLIC_IP_HERE' detected on web at '[http://checkip.dyndns.com](http://checkip.dyndns.com/)'
Waiting 600 seconds (Check Interval)
Detect registered/public IP
#> /usr/bin/nslookup [REDACTED.glddns.com](http://redacted.glddns.com/) >/var/run/ddns/glddns.dat 2>/var/run/ddns/glddns.err
Registered IP 'REDACTED_VPN_SERVERS_PUBLIC_IP_HERE' detected
If I run the command I get the VPN server’s IP:
root@GL-AX1800:~# /usr/bin/curl -RsS --noproxy '*' '[http://checkip.dyndns.com](http://checkip.dyndns.com/)'
<html><head><title>Current IP Check</title></head><body>Current IP Address: REDACTED_VPN_SERVERS_PUBLIC_IP_HERE</body></html>
