Unfortunately unlike when I use the nordvpn app in my devices by connecting via flint the services “raiplay.it” and “mediasetplay.mediaset.it” do not work because they detect a “use of proxies”. I noticed a bug: by activating and disabling the vpn connection and / or vpn policies often the internet connection is blocked you have to restart
Have you tried using our smartphone app to configure Nord? It will select one server for you if you choose a country. I used for Netflix and it worked.
Do you mean when using Nord?
With netflix works. Sometime when i stop vpn the router block internet
