Hi, Strenge issue here for the last few days.
The 2.4 GHz wireless is not working anymore.
I try to explain, I have 5Ghz and 2.4Ghz wireless networks with different names, and a few days ago the 2.4Ghz was not visible, and even if I try to connect to it as a “hidden” network, it seems that it does not exist.
I checked in the control pannel and is seems that everything is in order, I also checked in LUCI, same thing.
I rebooted the network, the router, and I also updated to the newest available firmware.
Still the same issue.
Can someone suggest me some other test, or command to check what it going on, and in case, I can I solve the issue.
This evening I will try to reset completely the router.
regards
Just reset my flint using GUI, and still the 2.4Ghz network not present.
There is a way to restore the router in command line that will be more deeply?
Please let me know.
Could you please try this method the flash the firmware v4.4.6?
https://dl.gl-inet.com/?model=ax1800
If still this issue, please take a request here for the warranty.
Thank you.
Hi @rain ,
Thanks a million, after the flash with uboot method, the 2.4Ghr network works again.
the router is now back in place, and I will let you know in case of any other issues.
Cheers
Thank you for the kindly updates as well.
Have a nice day.
I have the same issue, running 4.4.6.
2.4Ghz wifi just stopped working.
I am going to try the reset via uboot, and report back.
It would be interesting to know why the problem occurs.
Is it a problem caused by upgrading firmware via web gui?
Should future firmware updates be avoided via the webgui?
EDIT: Followed steps advised for ethernet uboot firmware flash, and now 2.4g internet works. Bit of a pain to re-setup all the applications and samba fileshare users, but glad it’s fixed.
