Flint2 4.8.2-op24 IPV6 DHCP
Hey,
I cant get my IPV6 (DualStack) to work on LAN Clients. They dont receive IPV6 ips. My Wlan Clients work fine, so wan. I come from native stable op21 build firmwares, where everything worked from the beginning. I tried many things with the help of chatgpt but the clients dont want to get local ipv6 ips.
I also resetted firmware to stock 4.8.2op24 settings after upgraded from 4.7.7 (without keeping settings).
Also my clients in 2.4 guest network dont get ips via dhcp when im back to ipv4 only…..
Is this a known issue ?
Thank you.
…so what i found out:
My clients on wlan guest are not getting ips so i set ip manually on my phone wlan and it worked. I looked out under luci system→startup → odhcpd Service, stopped it,started it and rebootet, all with ipv6 disabled and after reboot my wlan clients on guest network got ip via dhcp. Then i enabled ipv6 with my manual ipv6 dns from adguard but that didnt work out. Then i cant get connection on my normal 5ghz wlan so i deleted it in my phone and reconnected with password which worked. before i had ipv6 on my wlan clients but after all this, even this is not working anymore. At this point i didnt change any settings at all ! Stable firmware 4.8.2 with op21 had also dnsmasq problems which 4.7.7 hadnt. Now problems again. Whats the point… i tried many settings and read whole evening what chatgpt advised but i cant get it to work. Weird Bugs.
I hope it is understandable, english is not my mother language and im not an it expert but i try to help and get some help here :stuck_out_tongue:
You seem to be setting up some complex configurations.
I assume your goal is to get IPv6 working properly.
Starting from the factory settings, try configuring the device through the GL UI to connect to the network and enable IPv6. Experiment with different modes—will that get it working?
IPv6 - GL.iNet Router Docs 4
If that doesn't work, please let us know your current firmware version and WAN & IPv6 configuration.
Im on 4.8.2 op24 fw. Started to enable ipv6 native and automatic. The wan interface is getting ips from isp but not the clients. Then i startet to deep dive into the luci settings and asked chatgpt and looked into Forums. Nothing worked. So stock fw settings in 4.7.7 op21 worked straight from the beginning with no issues at all. The must be something incorrect with this fw build / settings i guess.
May we know if you use the "Passthrough" mode on the 4.8.2-op24, will it work?
Regarding the availability of “native” mode in 4.8.2-op24, we may need some time to build a test environment for further confirmation.
Hey will.qiu, im so sorry, it was my fault with the lan client. please delete this topic, I'm embarrassed :smiley: thank you for your help !
