I face a very strange issue with my Flint 2 which started in the last few days, but I only noticed it today since I cannot work. The PPPoE on my Flint 2 disconnects completely randomly, even in less that 10 seconds uptime!
I have tried the previous versions of the firmware, or even the Beta. Nothing fixed it! Even this post took me a lot of time to write it due to the disconnections!
The log file (after a reboot) has the following entries:
Wed Mar 27 21:37:37 2024 daemon.info pppd[11912]: PPP session is 1
Wed Mar 27 21:37:37 2024 daemon.warn pppd[11912]: Connected to XX:YY:ZZ:XX:YY:ZZ via interface eth1
Wed Mar 27 21:37:37 2024 kern.info kernel: [ 109.620622] pppoe-wan: renamed from ppp0
Wed Mar 27 21:37:37 2024 daemon.info pppd[11912]: Renamed interface ppp0 to pppoe-wan
Wed Mar 27 21:37:37 2024 daemon.info pppd[11912]: Using interface pppoe-wan
Wed Mar 27 21:37:37 2024 daemon.notice pppd[11912]: Connect: pppoe-wan <--> eth1
Wed Mar 27 21:37:41 2024 daemon.notice pppd[11912]: PAP authentication succeeded
Wed Mar 27 21:37:41 2024 daemon.notice pppd[11912]: peer from calling number XX:YY:ZZ:XX:YY:ZZ authorized
Wed Mar 27 21:37:44 2024 daemon.notice pppd[11912]: local IP address 1.2.3.4
Wed Mar 27 21:37:44 2024 daemon.info avahi-daemon[5999]: Joining mDNS multicast group on interface pppoe-wan.IPv4 with address 1.2.3.4.
Wed Mar 27 21:37:44 2024 daemon.notice pppd[11912]: remote IP address 5.6.7.8
Wed Mar 27 21:37:44 2024 daemon.notice pppd[11912]: primary DNS address 10.10.10.10
Wed Mar 27 21:37:44 2024 daemon.info avahi-daemon[5999]: New relevant interface pppoe-wan.IPv4 for mDNS.
Wed Mar 27 21:37:44 2024 daemon.info avahi-daemon[5999]: Registering new address record for 1.2.3.4 on pppoe-wan.IPv4.
Wed Mar 27 21:37:44 2024 daemon.notice netifd: Network device 'pppoe-wan' link is up
Wed Mar 27 21:37:44 2024 user.notice firewall: Reloading firewall due to ifup of wan (pppoe-wan)
Wed Mar 27 21:37:51 2024 daemon.info pppd[11912]: No response to 5 echo-requests
Wed Mar 27 21:37:51 2024 daemon.notice pppd[11912]: Serial link appears to be disconnected.
Wed Mar 27 21:37:51 2024 daemon.info pppd[11912]: Connect time 0.2 minutes.
Wed Mar 27 21:37:51 2024 daemon.info pppd[11912]: Sent 113878 bytes, received 89466 bytes.
Wed Mar 27 21:37:51 2024 daemon.info avahi-daemon[5999]: Interface pppoe-wan.IPv4 no longer relevant for mDNS.
Wed Mar 27 21:37:51 2024 daemon.info avahi-daemon[5999]: Leaving mDNS multicast group on interface pppoe-wan.IPv4 with address 1.2.3.4.
Wed Mar 27 21:37:51 2024 daemon.info avahi-daemon[5999]: Withdrawing address record for 1.2.3.4 on pppoe-wan.
Wed Mar 27 21:37:51 2024 daemon.notice netifd: Network device 'pppoe-wan' link is down
Wed Mar 27 21:37:54 2024 daemon.notice pppd[11912]: Connection terminated.
Wed Mar 27 21:37:54 2024 daemon.info pppd[11912]: Sent PADT
Wed Mar 27 21:37:54 2024 daemon.info pppd[11912]: Exit.
Wed Mar 27 21:37:58 2024 daemon.err insmod: module is already loaded - ppp_generic
Wed Mar 27 21:37:58 2024 daemon.err insmod: module is already loaded - pppox
Wed Mar 27 21:37:58 2024 daemon.err insmod: module is already loaded - pppoe
Wed Mar 27 21:37:58 2024 daemon.info pppd[14012]: Plugin rp-pppoe.so loaded.
Wed Mar 27 21:37:58 2024 daemon.info pppd[14012]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Wed Mar 27 21:37:58 2024 daemon.notice pppd[14012]: pppd 2.4.8 started by root, uid 0
Wed Mar 27 21:38:05 2024 daemon.info pppd[14012]: PPP session is 1
Wed Mar 27 21:38:05 2024 daemon.warn pppd[14012]: Connected to XX:YY:ZZ:XX:YY:ZZ via interface eth1
Wed Mar 27 21:38:05 2024 kern.info kernel: [ 137.596007] pppoe-wan: renamed from ppp0
Wed Mar 27 21:38:05 2024 daemon.info pppd[14012]: Renamed interface ppp0 to pppoe-wan
Wed Mar 27 21:38:05 2024 daemon.info pppd[14012]: Using interface pppoe-wan
Wed Mar 27 21:38:05 2024 daemon.notice pppd[14012]: Connect: pppoe-wan <--> eth1
Wed Mar 27 21:38:06 2024 daemon.notice pppd[14012]: PAP authentication succeeded
Wed Mar 27 21:38:06 2024 daemon.notice pppd[14012]: peer from calling number XX:YY:ZZ:XX:YY:ZZ authorized
Wed Mar 27 21:38:07 2024 daemon.notice pppd[14012]: local IP address 1.2.3.4
Wed Mar 27 21:38:07 2024 daemon.notice pppd[14012]: remote IP address 5.6.7.8
Wed Mar 27 21:38:07 2024 daemon.notice pppd[14012]: primary DNS address 10.10.10.10
Wed Mar 27 21:38:07 2024 daemon.info avahi-daemon[5999]: Joining mDNS multicast group on interface pppoe-wan.IPv4 with address 1.2.3.4.
Wed Mar 27 21:38:07 2024 daemon.info avahi-daemon[5999]: New relevant interface pppoe-wan.IPv4 for mDNS.
Wed Mar 27 21:38:07 2024 daemon.info avahi-daemon[5999]: Registering new address record for 1.2.3.4 on pppoe-wan.IPv4.
Wed Mar 27 21:38:07 2024 daemon.notice netifd: Network device 'pppoe-wan' link is up
Wed Mar 27 21:38:07 2024 user.notice firewall: Reloading firewall due to ifup of wan (pppoe-wan)
Wed Mar 27 21:39:45 2024 daemon.info pppd[14012]: No response to 5 echo-requests
Wed Mar 27 21:39:45 2024 daemon.notice pppd[14012]: Serial link appears to be disconnected.
Wed Mar 27 21:39:45 2024 daemon.info pppd[14012]: Connect time 0.5 minutes.
Wed Mar 27 21:39:45 2024 daemon.info pppd[14012]: Sent 472754 bytes, received 443175 bytes.
Wed Mar 27 21:39:45 2024 daemon.info avahi-daemon[5999]: Interface pppoe-wan.IPv4 no longer relevant for mDNS.
Wed Mar 27 21:39:45 2024 daemon.info avahi-daemon[5999]: Leaving mDNS multicast group on interface pppoe-wan.IPv4 with address XXXXXXX
Wed Mar 27 21:39:45 2024 daemon.notice netifd: Network device 'pppoe-wan' link is down
Wed Mar 27 21:39:45 2024 daemon.info avahi-daemon[5999]: Withdrawing address record for 1.2.3.4 on pppoe-wan.
Wed Mar 27 21:39:45 2024 daemon.notice pppd[14012]: Connection terminated.
Wed Mar 27 21:39:45 2024 daemon.info pppd[14012]: Sent PADT
Wed Mar 27 21:39:45 2024 daemon.info pppd[14012]: Exit.
Wed Mar 27 21:39:49 2024 daemon.err insmod: module is already loaded - ppp_generic
Wed Mar 27 21:39:49 2024 daemon.err insmod: module is already loaded - pppox
Wed Mar 27 21:39:49 2024 daemon.err insmod: module is already loaded - pppoe
Wed Mar 27 21:39:49 2024 daemon.info pppd[15680]: Plugin rp-pppoe.so loaded.
Wed Mar 27 21:39:49 2024 daemon.info pppd[15680]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Wed Mar 27 21:39:49 2024 daemon.notice pppd[15680]: pppd 2.4.8 started by root, uid 0
Wed Mar 27 21:40:04 2024 daemon.warn pppd[15680]: Timeout waiting for PADO packets
Wed Mar 27 21:40:04 2024 daemon.err pppd[15680]: Unable to complete PPPoE Discovery
Wed Mar 27 21:40:04 2024 daemon.info pppd[15680]: Exit.
Wed Mar 27 21:40:07 2024 daemon.err insmod: module is already loaded - ppp_generic
Wed Mar 27 21:40:07 2024 daemon.err insmod: module is already loaded - pppox
Wed Mar 27 21:40:07 2024 daemon.err insmod: module is already loaded - pppoe
Wed Mar 27 21:40:07 2024 daemon.info pppd[16303]: Plugin rp-pppoe.so loaded.
Wed Mar 27 21:40:07 2024 daemon.info pppd[16303]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Wed Mar 27 21:40:08 2024 daemon.notice pppd[16303]: pppd 2.4.8 started by root, uid 0
Wed Mar 27 21:40:14 2024 daemon.info pppd[16303]: PPP session is 1
Wed Mar 27 21:40:14 2024 daemon.warn pppd[16303]: Connected to XXXXXX via interface eth1
Wed Mar 27 21:40:14 2024 kern.info kernel: [ 197.008622] pppoe-wan: renamed from ppp0
Wed Mar 27 21:40:14 2024 daemon.info pppd[16303]: Renamed interface ppp0 to pppoe-wan
Wed Mar 27 21:40:14 2024 daemon.info pppd[16303]: Using interface pppoe-wan
Wed Mar 27 21:40:14 2024 daemon.notice pppd[16303]: Connect: pppoe-wan <--> eth1
Wed Mar 27 21:40:15 2024 daemon.notice pppd[16303]: PAP authentication succeeded
Wed Mar 27 21:40:15 2024 daemon.notice pppd[16303]: peer from calling number XXXXX:D7:10 authorized
Wed Mar 27 21:40:18 2024 daemon.notice pppd[16303]: local IP address XXXXXX
Wed Mar 27 21:40:18 2024 daemon.info avahi-daemon[5999]: Joining mDNS multicast group on interface pppoe-wan.IPv4 with address XXXXXXX
Wed Mar 27 21:40:18 2024 daemon.notice pppd[16303]: remote IP address XXXXXX
Wed Mar 27 21:40:18 2024 daemon.notice pppd[16303]: primary DNS address XXXXXXX
Wed Mar 27 21:40:18 2024 daemon.info avahi-daemon[5999]: New relevant interface pppoe-wan.IPv4 for mDNS.
Wed Mar 27 21:40:18 2024 daemon.info avahi-daemon[5999]: Registering new address record for 1.2.3.4 on pppoe-wan.IPv4.
Wed Mar 27 21:40:18 2024 daemon.notice netifd: Network device 'pppoe-wan' link is up
Wed Mar 27 21:40:18 2024 user.notice firewall: Reloading firewall due to ifup of wan (pppoe-wan)
Wed Mar 27 21:40:37 2024 daemon.info pppd[16303]: No response to 5 echo-requests
Wed Mar 27 21:40:37 2024 daemon.notice pppd[16303]: Serial link appears to be disconnected.
Wed Mar 27 21:40:37 2024 daemon.info pppd[16303]: Connect time 0.3 minutes.
Wed Mar 27 21:40:37 2024 daemon.info pppd[16303]: Sent 265753 bytes, received 169943 bytes.
Wed Mar 27 21:40:37 2024 daemon.info avahi-daemon[5999]: Interface pppoe-wan.IPv4 no longer relevant for mDNS.
Wed Mar 27 21:40:37 2024 daemon.info avahi-daemon[5999]: Leaving mDNS multicast group on interface pppoe-wan.IPv4 with address XXXXXXX.
Wed Mar 27 21:40:37 2024 daemon.notice netifd: Network device 'pppoe-wan' link is down
Wed Mar 27 21:40:37 2024 daemon.info avahi-daemon[5999]: Withdrawing address record for 1.2.3.4 on pppoe-wan.
Wed Mar 27 21:40:40 2024 daemon.notice pppd[16303]: Connection terminated.
Wed Mar 27 21:40:40 2024 daemon.info pppd[16303]: Sent PADT
Wed Mar 27 21:40:40 2024 daemon.info pppd[16303]: Exit.
Wed Mar 27 21:40:44 2024 daemon.err insmod: module is already loaded - ppp_generic
Wed Mar 27 21:40:44 2024 daemon.err insmod: module is already loaded - pppox
Wed Mar 27 21:40:44 2024 daemon.err insmod: module is already loaded - pppoe
Wed Mar 27 21:40:44 2024 daemon.info pppd[17961]: Plugin rp-pppoe.so loaded.
Wed Mar 27 21:40:44 2024 daemon.info pppd[17961]: RP-PPPoE plugin version 3.8p compiled against pppd 2.4.8
Wed Mar 27 21:40:44 2024 daemon.notice pppd[17961]: pppd 2.4.8 started by root, uid 0
Wed Mar 27 21:40:51 2024 daemon.info pppd[17961]: PPP session is 1
Wed Mar 27 21:40:51 2024 daemon.warn pppd[17961]: Connected to XXXXX:b4:d7:10 via interface eth1
Wed Mar 27 21:40:51 2024 kern.info kernel: [ 233.610566] pppoe-wan: renamed from ppp0
Wed Mar 27 21:40:51 2024 daemon.info pppd[17961]: Renamed interface ppp0 to pppoe-wan
Wed Mar 27 21:40:51 2024 daemon.info pppd[17961]: Using interface pppoe-wan
Wed Mar 27 21:40:51 2024 daemon.notice pppd[17961]: Connect: pppoe-wan <--> eth1
Wed Mar 27 21:40:52 2024 daemon.notice pppd[17961]: PAP authentication succeeded
Wed Mar 27 21:40:52 2024 daemon.notice pppd[17961]: peer from calling number XXXXXX:B4:D7:10 authorized
Wed Mar 27 21:40:52 2024 daemon.notice pppd[17961]: local IP address XXXXXXX
Wed Mar 27 21:40:52 2024 daemon.notice pppd[17961]: remote IP address XXXXXX
Wed Mar 27 21:40:52 2024 daemon.info avahi-daemon[5999]: Joining mDNS multicast group on interface pppoe-wan.IPv4 with address XXXXXX
Wed Mar 27 21:40:52 2024 daemon.notice pppd[17961]: primary DNS address XXXXXXXXX
Wed Mar 27 21:40:52 2024 daemon.info avahi-daemon[5999]: New relevant interface pppoe-wan.IPv4 for mDNS.
Wed Mar 27 21:40:52 2024 daemon.info avahi-daemon[5999]: Registering new address record for 1.2.3.4 on pppoe-wan.IPv4.
Wed Mar 27 21:40:52 2024 daemon.notice netifd: Network device 'pppoe-wan' link is up
Wed Mar 27 21:40:52 2024 user.notice firewall: Reloading firewall due to ifup of wan (pppoe-wan)
Any help would be appreciated
