Flint2 error log
Hi there
I recently purchased flint2, updated to 4.9.0.
Set up pppoe with vlan.
Changed DNS server to a locally running Adguard home server.
Added nordvpn client with domain policy based routing.
Installed LuCI
Added a firewall rule for home assistant to access iot network.
I don't think I changed more settings.
In the logs I see the following multiple times.
kern.err kernel: [27039.388002] 7986@C14L1,PeerPublicAction() 944: Wrong Wcid:1023 !!! need to check the root
I don't know if it's related, but also having problem with wifi clients, after some time or when i leave and return home all devices (android/Ios) can not connect anymore. Either reboot or disabling/enabling wifi fixes it…
Sorry for the delayed reply.
Regarding your issue, could you please help clarify or test the following?
  1. When the issue occurs, are wired devices affected as well, or does it only affect Wi-Fi devices?
  2. When the issue occurs, please export the router logs and send them to us via private message so that we can investigate further.
  3. If you have an opportunity, could you also try v4.9.0-op24 and see whether the same issue occurs?
Download link:
Upgrade guide:
How to export logs:
How to send private messages:
i have disabled the wifi 5ghz and the policy based routing.
now wifi devices dont have problems connecting.
still seeing the error in the log.
i sent you the log file
EDIT / UPDATE:
i restored factory image, and tried to set up one by one and checked the logs.
it seems the problem is in the IoT WiFi.
When i disable the IoT WiFi the error logs are gone.
Thank you for providing the logs and sharing your findings.
We asked our R&D team to check the logs, and they confirmed that this error is caused by a compatibility issue between the 802.11 public action frames sent by some wireless client and the Flint 2 wireless driver.
Could you please confirm the following?
  1. Were any devices previously connected to the IoT network?
  2. After disabling the IoT network, do these devices work normally on the Main / Guest SSID?
  3. Have you previously edited any wireless-related settings via LuCI or SSH?
  4. If you encounter the same issue on the Main / Guest SSID, does switching to the OP24 / OP25 firmware help?
it happens on any wifi network. i found the device which is causing the erorrs, its a Sricam SH038
And thank you for identifying the device. We now know that the affected client is a Sricam SH038 and that the log can occur on any SSID, not only the IoT network.
Could you please test the camera with the v4.9.1-op25 firmware linked above? For a clean comparison, if possible, please do not keep the existing settings during the upgrade, and initially configure only the required Internet connection and a test Wi-Fi network.
Please check the following while the Sricam camera is connected:
  1. Whether the Wrong Wcid:1023 log entries still appear.
  2. Whether the camera or other Wi-Fi clients still experience connection problems.
If the issue does not occur with the OP firmware, this would strongly indicate a compatibility issue with the closed-source Wi-Fi driver used by the standard firmware.
Further investigation may then require obtaining the same camera model and capturing over-the-air wireless traffic in a test environment. This process may take some time, so we cannot provide a definite investigation or fix timeline at this stage. However, your OP firmware test result will help us determine the appropriate next step.
