Good afternoon. I connected the router to the Internet. The connection is established, the Internet is connected via a local network and wifi is working.I'm trying to install programs, but it doesn't work. Below are the error logs and different router responses.
Hostname GL-MT6000
Model GL.iNet GL-MT6000
Architecture ARMv8 Processor rev 4
OpenWrt Version OpenWrt 24.10.4 r28959-29397011cc
Kernel Version 6.6.110
root@GL-MT6000:~# opkg update
Downloading https://fw.gl-inet.com/releases/v24.x/24.10.4/mediatek/filogic/Packages.gz
*** Failed to download the package list from https://fw.gl-inet.com/releases/v24.x/24.10.4/mediatek/filogic/Packages.gz
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/base/Packages.gz
Updated list of available packages in /var/opkg-lists/base
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/luci/Packages.gz
Updated list of available packages in /var/opkg-lists/luci
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/packages/Packages.gz
Updated list of available packages in /var/opkg-lists/packages
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/routing/Packages.gz
Updated list of available packages in /var/opkg-lists/routing
Downloading https://downloads.openwrt.org/releases/24.10.4/packages/aarch64_cortex-a53/telephony/Packages.gz
Updated list of available packages in /var/opkg-lists/telephony
Updating database.
Database update completed.
Collected errors:
opkg_download: Failed to download https://fw.gl-inet.com/releases/v24.x/24.10.4/mediatek/filogic/Packages.gz, wget returned 4.
opkg_download: Check your network settings and connectivity.
root@GL-MT6000:~# ping www.google.com
PING www.google.com (142.251.154.119): 56 data bytes
64 bytes from 142.251.154.119: seq=0 ttl=108 time=119.874 ms
64 bytes from 142.251.154.119: seq=1 ttl=108 time=117.100 ms
64 bytes from 142.251.154.119: seq=2 ttl=108 time=116.911 ms
64 bytes from 142.251.154.119: seq=3 ttl=108 time=127.160 ms
^C
--- www.google.com ping statistics ---
4 packets transmitted, 4 packets received, 0% packet loss
round-trip min/avg/max = 116.911/120.261/127.160 ms
root@GL-MT6000:~# wget https://fw.gl-inet.com/releases/v24.x/24.10.4/mediatek/filogic/Packages.gz
Downloading 'https://fw.gl-inet.com/releases/v24.x/24.10.4/mediatek/filogic/Packages.gz'
Connecting to 188.114.97.3:443
Writing to 'Packages.gz'
Packages.gz 24% |******* | 25213 - stalled -Connection error: Connection timed out
root@GL-MT6000:~# ubus call system board
"kernel": "6.6.110",
"hostname": "GL-MT6000",
"system": "ARMv8 Processor rev 4",
"model": "GL.iNet GL-MT6000",
"board_name": "glinet,gl-mt6000",
"rootfs_type": "squashfs",
"release": {
"distribution": "OpenWrt",
"version": "24.10.4",
"revision": "",
"target": "mediatek/filogic",
"description": "OpenWrt 24.10.4 r28959-29397011cc",
"builddate": "1760891865"
root@GL-MT6000:~# cat /etc/config/firewall
config defaults
option syn_flood '1'
option input 'ACCEPT'
option output 'ACCEPT'
option forward 'REJECT'
option flow_offloading '1'
option flow_offloading_hw '1'
config rule 'wan_drop_leaked_adgdns'
option name 'wan_drop_leaked_adgdns'
option src 'wan'
option proto 'udp'
option dest_port '3053'
option mark '0x0/0xf000'
option target 'DROP'
option enabled '0'
config rule 'wan_drop_leaked_dns'
option name 'wan_drop_leaked_dns'
option src 'wan'
option proto 'udp'
option dest_port '53'
option mark '!0x8000/0xf000'
option enabled '0'
config rule 'guest_drop_leaked_dns'
option name 'guest_drop_leaked_dns'
option src 'guest'
option proto 'udp'
option enabled '0'
config rule 'guest_drop_leak_adgdns'
option name 'guest_drop_leak_adgdns'
option src 'guest'
option proto 'udp'
option enabled '0'
config zone
option name 'lan'
list network 'lan'
option forward 'ACCEPT'
config zone
option name 'wan'
list network 'wan'
list network 'wan6'
list network 'wwan'
list network 'secondwan'
option masq '1'
option mtu_fix '1'
option input 'DROP'
config forwarding
option src 'lan'
option dest 'wan'
option enabled '1'
config rule
option src 'wan'
option proto 'udp'
option dest_port '68'
option target 'ACCEPT'
option family 'ipv4'
config rule
option name 'Allow-IGMP'
option src 'wan'
option proto 'igmp'
config rule
option name 'Allow-DHCPv6'
option src 'wan'
option proto 'udp'
option dest_port '546'
option family 'ipv6'
config rule
option name 'Allow-MLD'
option src 'wan'
option proto 'icmp'
option src_ip 'fe80::/10'
list icmp_type '130/0'
list icmp_type '131/0'
list icmp_type '132/0'
list icmp_type '143/0'
config rule
option src 'wan'
option proto 'icmp'
option limit '1000/sec'
list icmp_type 'bad-header'
config rule
option src 'wan'
option dest '*'
option proto 'icmp'
list icmp_type 'echo-request'
list icmp_type 'echo-reply'
config rule
option name 'Allow-IPSec-ESP'
option src 'wan'
option dest 'lan'
option proto 'esp'
config rule
option name 'Allow-ISAKMP'
option src 'wan'
option dest 'lan'
option dest_port '500'
option proto 'udp'
config rule
option name 'Support-UDP-Traceroute'
option src 'wan'
option dest_port '33434:33689'
option proto 'udp'
option target 'REJECT'
option enabled 'false'
config include
config zone
option name 'guest'
option network 'guest'
option input 'REJECT'
config forwarding
option src 'guest'
option dest 'wan'
option enabled '1'
config rule
option name 'Allow-DHCP'
option src 'guest'
option proto 'udp'
option dest_port '67-68'
config rule
option name 'Allow-DNS'
option src 'guest'
option proto 'tcp udp'
config include 'nat6'
option path '/etc/firewall.nat6'
option reload '1'
config include 'dns_order'
option type 'script'
option path '/etc/firewall.dns_order'
option reload '1'
option enabled '1'
config include 'dmz_exclude'
option path '/etc/firewall.dmz.exclude'
option reload '1'
config include 'security'
option path '/etc/firewall.security'
option reload '0'
config rule 'lan_drop_leaked_dns'
option name 'lan_drop_leaked_dns'
option src 'lan'
option proto 'udp'
option enabled '1'
config rule 'lan_drop_leak_adgdns'
option name 'lan_drop_leak_adgdns'
option src 'lan'
option proto 'udp'
option enabled '1'
config rule 'wgserver_drop_leaked_dns'
option name 'wgserver_drop_leaked_dns'
option src 'wgserver'
option proto 'udp'
option enabled '1'
config rule 'ovpnserver_drop_leaked_dns'
option name 'ovpnserver_drop_leaked_dns'
option src 'ovpnserver'
option proto 'udp'
option enabled '1'
config rule 'wgserver_drop_leaked_adgdns'
option name 'wgserver_drop_leaked_adgdns'
option proto 'udp'
option enabled '1'
config rule 'ovpnserver_drop_leaked_adgdns'
option name 'ovpnserver_drop_leaked_adgdns'
option proto 'udp'
option enabled '1'
config include 'ethernet_ttl'
option reload '1'
option path '/etc/firewall.ethernet_ttl'
config include 'glblock'
option path '/usr/bin/gl_block.sh'
option reload '1'
root@GL-MT6000:~# ping 8.8.8.8
PING 8.8.8.8 (8.8.8.8): 56 data bytes
64 bytes from 8.8.8.8: seq=0 ttl=119 time=26.858 ms
64 bytes from 8.8.8.8: seq=1 ttl=119 time=26.399 ms
64 bytes from 8.8.8.8: seq=2 ttl=119 time=26.852 ms
64 bytes from 8.8.8.8: seq=3 ttl=119 time=26.484 ms
^C
--- 8.8.8.8 ping statistics ---
round-trip min/avg/max = 26.399/26.648/26.858 ms
root@GL-MT6000:~# ping fw.gl-inet.com
PING fw.gl-inet.com (188.114.96.3): 56 data bytes
64 bytes from 188.114.96.3: seq=0 ttl=56 time=138.585 ms
64 bytes from 188.114.96.3: seq=1 ttl=56 time=138.420 ms
64 bytes from 188.114.96.3: seq=2 ttl=56 time=138.150 ms
64 bytes from 188.114.96.3: seq=3 ttl=56 time=137.608 ms
64 bytes from 188.114.96.3: seq=4 ttl=56 time=137.473 ms
64 bytes from 188.114.96.3: seq=5 ttl=56 time=137.819 ms
64 bytes from 188.114.96.3: seq=6 ttl=56 time=137.487 ms
^C
--- fw.gl-inet.com ping statistics ---
7 packets transmitted, 7 packets received, 0% packet loss
round-trip min/avg/max = 137.473/137.934/138.585 ms
root@GL-MT6000:~# nslookup fw.gl-inet.com
Server: 127.0.0.1
Address: 127.0.0.1:53
Non-authoritative answer:
Address: 188.114.96.3
Address: 188.114.97.3
