Flint2: PPPD lost connectivity
Is there a way ti increase the number of echo before considering the connection as lost?
Thu Oct 17 16:56:08 2024 daemon.info pppd[7297]: No response to 5 echo-requests
Thu Oct 17 16:56:08 2024 daemon.notice pppd[7297]: Serial link appears to be disconnected.
Thu Oct 17 16:56:08 2024 daemon.info pppd[7297]: Connect time 1625.2 minutes.
Thu Oct 17 16:56:08 2024 daemon.info pppd[7297]: Sent 355938084 bytes, received 559233171 bytes.
Thu Oct 17 16:56:08 2024 daemon.info avahi-daemon[4397]: Interface pppoe-wan.IPv4 no longer relevant for mDNS.
Thu Oct 17 16:56:08 2024 daemon.info avahi-daemon[4397]: Leaving mDNS multicast group on interface pppoe-wan.IPv4 with address 94.33.190.246.
Thu Oct 17 16:56:08 2024 daemon.notice netifd: Network device 'pppoe-wan' link is down
Thu Oct 17 16:56:08 2024 daemon.info avahi-daemon[4397]: Withdrawing address record for 94.33.190.246 on pppoe-wan.
Thu Oct 17 16:56:08 2024 daemon.notice netifd: Interface 'wan' has lost the connection
Thu Oct 17 16:56:08 2024 daemon.warn dnsmasq[5398]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Thu Oct 17 16:56:08 2024 user.notice firewall: Reloading firewall due to ifdown of wan ()
Thu Oct 17 16:56:08 2024 user.notice kmwan: config json str={ "op": 3, "data": { "cells": [ "wan" ] } }
Thu Oct 17 16:56:08 2024 kern.debug kernel: [97539.607168] kmwan: Delete node:wan
Thu Oct 17 16:56:14 2024 daemon.notice pppd[7297]: Connection terminated.
Thu Oct 17 16:56:14 2024 daemon.info pppd[7297]: Sent PADT
Thu Oct 17 16:56:14 2024 daemon.notice pppd[7297]: Modem hangup
Thu Oct 17 16:56:14 2024 daemon.info pppd[7297]: Exit.
Thu Oct 17 16:56:14 2024 daemon.notice netifd: Interface 'wan' is now down
This happens to me quite a lot now
5 is the default parameter value of OpenWrt PPPoE, which it can be modified on the Luci.
thanks a lot
