FLINT2 - Problems with 2.5gbit between branch 21.02 and 24.10
Good Morning,
I'm experiencing some problems with GL-iNet openwrt 24.10 branch. Seems that the speediest chop around a gigabit, for example first 2 images are with 21.02, as you can see the Speed is around 2.1gbit:
but if I install 24.10 reconfiguring settings from scratch:
As you can see, there are 900mbit of difference.
Can you have an explanation for this? It can be fixed?
Any ideas?
Is this the official 4.7.0-op24?
Yes, absolutely. Nothing custom or simular. Official fw, installed, Speedtest installed and checked
Here with 2,5 Gbit Tim and 4.7.0-op24 Beta 2024-12-09 Flint2 Firmware
Are you using the WAN port or WAN/LAN1?
Try switching between these two
You're on Wan or Wan/Lan1?
I've tried, but nothing. Same result. Stucked on 1.3gbit
have you checked the setting of hardware acceleration between the 2 firmware branches?
It’s the same between the 2 branches, hardware acceleration on.
You’re using network acceleration setting?
Wan on ONT
Wan1/Lan on pc with 2,5 Gbit Realtek card (Realtek Gaming 2.5GbE Family Controller)
Hardware Acceleration ON
Thanks. I’m doing Speedtest directly from the router, so it’s much stranger…
