Flint2 - VPN Dashboard - Track Traffic
GL-MT6000
Version 4.8.1 beta
I currently have some policies setup on the router to redirect certain address through certain VPNs. This is working but Is there a way to get the a log of the addresses that are being sent through each VPN setting and what is going to the all other traffic part?
Thanks
Technically yes but I do offline analysis while this describes 'real time' packet capturing:
wg show should give you the WireGuard/VPN interfaces for targeting. Other than that perhaps GL staff/some one else can post some iptables rule or the like. That may be a different/easier route.
Thanks alot. I will check it out.
I was wondering was there some sort of plugin that may ahow the logs on the router Web GUI based on the point in time that the traffic is redirected.
Well, though I don't use it I'm to understand AdGuardHome at least partially shows what domains are being contacted. To what extent it shows/logs incoming/outgoing and/or just IPs IDK.
There's also 'Realtime Graphs' found under LuCI -> Status but those are quite basic. Beyond that it gets into increasing orders of complexity in configuring daemons to capture what you're seeking vs how it would be displayed. Eg: LuCI -> Network -> DHCP and DNS -> Log can 'log queries' to the devices system log but then it's a question of how you're going to store the resulting large text files (System -> System -> Logging -> Wire system log to file:). That's still ignoring this LuCI DNS logging requires separate analysis after the fact.
tcpdump & WireShark is how it's done for a professional network analysis. It may be overkill but it's not going to hide anything from you unless you specifically want it to.
