Flint3 and repeater/extender
Hi everyone,
I currently use a Flint 3 as my main home router and it works very well. I have configured a separate IoT network, and I do not use the guest network. My main network is also working fine.
I would like to add a repeater/extender to improve coverage. I am considering keeping the Flint 3 as the main router and adding either a Flint 2 or a Beryl AX as a repeater. Another option would be waiting for the Flint 4 and using the Flint 3 as the repeater, or even buying a second Flint 3.
I also do not really use Wi-Fi 7; I mostly use Wi-Fi 6 on 2.4 GHz and 5 GHz.
What would you recommend for a stable home setup?
Thank you!
Germán
If you can afford it wait for the flint4 and put the 3 as a dumb ap if not get the 2 and put it as main again (the flin3 always as a dumb ap)
