Received new sealed box Flint3 in India through DHL.
Findings
1> Temp is on higher side , average 71C~72C in our hot and humid weather
added a 140mm Corsair cabinet fan on top with double sided tape and temps down to 58~60
2> Wifi range is okay with me at low TX power on all 3 bands. Of course it is not same as my previous TPLink Archer BE800 , but its sufficient for me.
3> 6Ghz working fine on both home PC with MediaTek Wi-Fi 6E MT7922 (RZ616) 160MHz Wireless and on Office Laptop with Intel AX211
Both can connect 6Ghz without any issue.
4> MLO working with my OnePlus 12 with 2.4+5 band as Indian version OP12 not enable 6Ghz yet (India just now published draft 6Ghz rule)
5> Not using any VPN yet
6> How to enable UPNP function on this router , any help ?
Firmware came with v4.7.11 online upgrade to v4.7.14
Rgds
