Force 5G connection (X3000)
Hello again,
Is there any way to force the cellular modem to connect to 5G only?
Thank you.
Hello Tim,
I have tried, but it will eventually drop back to 3G after 10-20 mins of 5G usage.
Is there anyway we can disable WCDMA? so it will never fail into 3G again.
Thank you.
PS. I do have strong 5G coverage in this area.
Hi hkm:
Which carrier does your sim card belong to?
Hello Lizh,
I am using CSL in Hong Kong.
Please find the info below:
Thank you.
it's
AT+QENG="servingcell"
Notice " are different characters.
Any outcome on this topic?
I also have fallback from great stable 5G, usually in conference calls talking, with internet gone for 40sec. Gateway is not down, just stops working in important times.
5G NSA doesn't get connected when 5G NSA cell lock, needs 4G but is restricted then.
