Frequent WWAN disconnects (like many other people, it seems)
I use a GL-MT3000 as a repeater for travel. I typically connect my laptop and phone to it wirelessly and the router wirelessly connects to the router at the AirBnB or wherever I’m staying. I had the following problem at my last two locations (both in Thailand).
While I’m using the router my interet stops working for a few minutes, then comes back. During that time the laptop wifi doesn’t disconnect, and I can still log into the web interface. The router seems fine, just that it lost it’s WWAN connection. The front LED blinks for a while and eventually it reconnects.
Directly connecting the apartment’s wifi, bypassing the MT3000 altogether, I get a solid connection that doesn’t drop.
There are a bunch of topics here about the wan connection dropping, but I couldn’t find any that match my syptoms, and I didn’t find any answers. Apologies if I missed something.
To troubleshoot I did the following:
  • disabled my vpn
  • tried a different SSID (this apartment broadcasts separate SSIDs for 2.4 & 5)
  • downgraded the firmware per suggestions here on the forum (4.8.1 → 4.6.9)
  • factory reset
None of that helped. After a factory reset (on FW 4.6.9) I temporarily connected via ethernet and set up the wan and lan wifis with defaults and changed nothing else. Disconnections still happen.
The upstream router is a Huawei OptiXstar which I cannot access, but it looks like a basic home router, and there are no other access points. I’m on the 40th floor so there’s probably not much interference. I used WifiMan on my phone to check (I’m experienced with Ubiquiti systems) and it shows I have a -32db connection from my phone to the MT3000 and -57 to the apartment’s router (I’m sitting next to the MT3000 so its connection upstream should be about the same as my phone’s)
I looked through the system log but it’s…a lot. I’ll post the messages from a time when the connection dropped and came back in the next reply. I have lots of free time while I’m on vacation here in Thailand so I’m willing to put some time into figuring this out. Thanks y’all in advance.
Here's the system log from the last drop
(The apartment's SSID is "spywarevirus__5G", someone thought they were funny)
Thu Dec 18 10:49:56 2025 kern.notice kernel: [ 3528.503617] 7981@C09L3,sync_fsm_reset() 2705: (caller : rt28xx_sta_ioctl+0xadc/0x1ed8 [mt_wifi]) SYNC[apclix0, Band:1]: [JOIN_WAIT] =======================================
Thu Dec 18 10:49:56 2025 kern.notice kernel: [ 3528.504208] WiFi@C01L3,wifi_sys_close() 945: wdev idx = 5
Thu Dec 18 10:49:56 2025 kern.notice kernel: [ 3528.525194] 7981@C08L3,hw_ctrl_flow_v2_close() 41: wdev_idx=5
Thu Dec 18 10:49:56 2025 kern.warn kernel: [ 3528.531205] 7981@C01L2,RTMP_COM_IoctlHandle() 1528: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DEINIT
Thu Dec 18 10:49:56 2025 kern.info kernel: [ 3528.539479] extif_put_dev(apclix0)
Thu Dec 18 10:49:56 2025 kern.info kernel: [ 3528.542884] mtk_ppe_dev_unregister_hook : ineterface apclix0 set null (4)
Thu Dec 18 10:49:56 2025 daemon.notice netifd: Interface 'wwan' is disabled
Thu Dec 18 10:49:56 2025 daemon.info gl-repeater[3312]: (repeater.lua:1001) switch in 30 seconds...
Thu Dec 18 10:49:56 2025 daemon.info gl-repeater[3312]: (repeater.lua:406) check status exited
Thu Dec 18 10:49:56 2025 kern.err kernel: [ 3528.552857] 7981@C12L1,rt28xx_ap_ioctl() 894: interface is down, cmd [8be2] return!!!
Thu Dec 18 10:49:56 2025 kern.err kernel: [ 3528.623994] 7981@C13L1,MlmeEnqueueWithWdev() 5715: wdev(5) state: if down!
Thu Dec 18 10:49:56 2025 daemon.info gl-repeater[3312]: (repeater-mtk.lua:366) listen event exited
Thu Dec 18 10:50:26 2025 daemon.info gl-repeater[3312]: (repeater.lua:262) scanning...
Thu Dec 18 10:50:26 2025 kern.info kernel: [ 3558.548363] Set ScanSSID =
Thu Dec 18 10:50:26 2025 kern.debug kernel: [ 3558.551216] Number of channels to scan = 5
Thu Dec 18 10:50:26 2025 kern.debug kernel: [ 3558.555377] bScanning = 1
Thu Dec 18 10:50:26 2025 kern.info kernel: [ 3558.558614] Set ScanSSID =
Thu Dec 18 10:50:26 2025 kern.debug kernel: [ 3558.561525] Number of channels to scan = 5
Thu Dec 18 10:50:26 2025 kern.debug kernel: [ 3558.565698] bScanning = 1
Thu Dec 18 10:50:27 2025 kern.warn kernel: [ 3558.864336] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (d6:01:a4:03:d9:b4), Reason 0x10
Thu Dec 18 10:50:27 2025 kern.err kernel: [ 3558.873209] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:50:27 2025 kern.warn kernel: [ 3558.894568] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:50:27 2025 kern.err kernel: [ 3558.903435] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:50:28 2025 kern.notice kernel: [ 3559.747743] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:50:28 2025 kern.notice kernel: [ 3559.756010] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 347
Thu Dec 18 10:50:28 2025 kern.notice kernel: [ 3559.966855] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:50:28 2025 kern.notice kernel: [ 3559.975279] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 349
Thu Dec 18 10:50:28 2025 kern.debug kernel: [ 3559.995949] BcnCheck start after 4700 ms (ra0)
Thu Dec 18 10:50:28 2025 kern.debug kernel: [ 3560.000394] BcnCheck start after 4900 ms (ra0)
Thu Dec 18 10:50:28 2025 kern.warn kernel: [ 3560.017550] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (d6:01:a4:03:d9:b4), Reason 0x10
Thu Dec 18 10:50:28 2025 kern.err kernel: [ 3560.026422] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:50:28 2025 kern.warn kernel: [ 3560.225825] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:50:28 2025 kern.err kernel: [ 3560.234699] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:50:29 2025 kern.notice kernel: [ 3560.892963] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:50:29 2025 kern.notice kernel: [ 3560.901236] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 358
Thu Dec 18 10:50:29 2025 kern.notice kernel: [ 3561.277138] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:50:29 2025 kern.notice kernel: [ 3561.285501] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 362
Thu Dec 18 10:50:29 2025 kern.warn kernel: [ 3561.303931] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (d6:01:a4:03:d9:b4), Reason 0x10
Thu Dec 18 10:50:29 2025 kern.err kernel: [ 3561.312800] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:50:29 2025 kern.notice kernel: [ 3561.572784] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:50:29 2025 kern.notice kernel: [ 3561.581058] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 365
Thu Dec 18 10:50:29 2025 kern.notice kernel: [ 3561.588123] 7981@C23L3,cntl_scan_conf() 625: reset scan fsm, current status is 0x0
Thu Dec 18 10:50:29 2025 kern.notice kernel: [ 3561.595710] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:50:29 2025 kern.notice kernel: [ 3561.603970] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 365
Thu Dec 18 10:50:29 2025 kern.debug kernel: [ 3561.611015] SCAN DONE, Reset FSM/CNTL IDLE.
Thu Dec 18 10:50:29 2025 daemon.info gl-repeater[3312]: (repeater.lua:230) apcli0: found 20 networks
Thu Dec 18 10:50:29 2025 kern.warn kernel: [ 3561.629249] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:50:29 2025 kern.err kernel: [ 3561.638121] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:50:30 2025 kern.debug kernel: [ 3562.603282] BcnCheck start after 4000 ms (ra0)
Thu Dec 18 10:50:30 2025 kern.notice kernel: [ 3562.619987] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:50:30 2025 kern.notice kernel: [ 3562.628346] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 375
Thu Dec 18 10:50:31 2025 kern.warn kernel: [ 3562.933324] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:50:31 2025 kern.err kernel: [ 3562.942193] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:50:32 2025 kern.notice kernel: [ 3563.927123] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:50:32 2025 kern.notice kernel: [ 3563.935491] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 387
Thu Dec 18 10:50:32 2025 kern.warn kernel: [ 3564.182614] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:50:32 2025 kern.err kernel: [ 3564.191485] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:50:33 2025 kern.notice kernel: [ 3565.159452] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:50:33 2025 kern.notice kernel: [ 3565.167809] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 399
Thu Dec 18 10:50:33 2025 kern.notice kernel: [ 3565.174875] 7981@C23L3,cntl_scan_conf() 625: reset scan fsm, current status is 0x0
Thu Dec 18 10:50:33 2025 kern.notice kernel: [ 3565.183818] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:50:33 2025 kern.notice kernel: [ 3565.192168] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 399
Thu Dec 18 10:50:33 2025 kern.debug kernel: [ 3565.199216] SCAN DONE, Reset FSM/CNTL IDLE.
Thu Dec 18 10:50:33 2025 kern.debug kernel: [ 3565.206668] BcnCheck start after 1500 ms (ra0)
Thu Dec 18 10:50:33 2025 daemon.info gl-repeater[3312]: (repeater.lua:230) apclix0: found 14 networks
Thu Dec 18 10:50:33 2025 daemon.info gl-repeater[3312]: (repeater.lua:677) switch to any...
Thu Dec 18 10:50:33 2025 daemon.info gl-repeater[3312]: (repeater.lua:683) not found matched bss
Thu Dec 18 10:50:33 2025 daemon.info gl-repeater[3312]: (repeater.lua:1001) switch in 30 seconds...
Thu Dec 18 10:50:33 2025 kern.debug kernel: [ 3565.211120] BcnCheck start after 4900 ms (ra0)
Thu Dec 18 10:50:36 2025 kern.debug kernel: [ 3567.813967] BcnCheck start after 2400 ms (ra0)
There’s a 27-second gap here, I’ll continue in the next reply, this one is over the size limit
Thu Dec 18 10:52:07 2025 kern.debug kernel: [ 3658.744491] bScanning = 1
Thu Dec 18 10:52:07 2025 kern.warn kernel: [ 3659.043404] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (d6:01:a4:03:d9:b4), Reason 0x10
Thu Dec 18 10:52:07 2025 kern.err kernel: [ 3659.052280] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:52:07 2025 kern.warn kernel: [ 3659.059361] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:52:07 2025 kern.err kernel: [ 3659.068224] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:52:08 2025 kern.notice kernel: [ 3659.904668] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:52:08 2025 kern.notice kernel: [ 3659.912942] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 1308
Thu Dec 18 10:52:08 2025 kern.notice kernel: [ 3660.134064] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:52:08 2025 kern.notice kernel: [ 3660.142428] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 1310
Thu Dec 18 10:52:08 2025 kern.warn kernel: [ 3660.170070] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (d6:01:a4:03:d9:b4), Reason 0x10
Thu Dec 18 10:52:08 2025 kern.err kernel: [ 3660.178940] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:52:08 2025 kern.warn kernel: [ 3660.368250] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:52:08 2025 kern.err kernel: [ 3660.377120] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:52:09 2025 kern.notice kernel: [ 3661.062174] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:52:09 2025 kern.notice kernel: [ 3661.070440] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 1319
Thu Dec 18 10:52:09 2025 kern.notice kernel: [ 3661.447330] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:52:09 2025 kern.notice kernel: [ 3661.455697] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 1323
Thu Dec 18 10:52:09 2025 kern.warn kernel: [ 3661.474171] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (d6:01:a4:03:d9:b4), Reason 0x10
Thu Dec 18 10:52:09 2025 kern.err kernel: [ 3661.483035] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:52:09 2025 kern.debug kernel: [ 3661.614752] BcnCheck start after 4800 ms (ra0)
Thu Dec 18 10:52:10 2025 kern.notice kernel: [ 3661.748791] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:52:10 2025 kern.notice kernel: [ 3661.757064] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 1326
Thu Dec 18 10:52:10 2025 kern.notice kernel: [ 3661.764214] 7981@C23L3,cntl_scan_conf() 625: reset scan fsm, current status is 0x0
Thu Dec 18 10:52:10 2025 kern.notice kernel: [ 3661.771800] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:52:10 2025 kern.notice kernel: [ 3661.780064] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 1326
Thu Dec 18 10:52:10 2025 kern.debug kernel: [ 3661.787198] SCAN DONE, Reset FSM/CNTL IDLE.
Thu Dec 18 10:52:10 2025 daemon.info gl-repeater[3312]: (repeater.lua:230) apcli0: found 19 networks
Thu Dec 18 10:52:10 2025 kern.warn kernel: [ 3661.805435] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:52:10 2025 kern.err kernel: [ 3661.814303] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:52:11 2025 kern.notice kernel: [ 3662.803138] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:52:11 2025 kern.notice kernel: [ 3662.811497] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 1336
Thu Dec 18 10:52:11 2025 kern.warn kernel: [ 3663.088440] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:52:11 2025 kern.err kernel: [ 3663.097310] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:52:12 2025 kern.notice kernel: [ 3664.083184] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:52:12 2025 kern.notice kernel: [ 3664.091552] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 1348
Thu Dec 18 10:52:12 2025 kern.debug kernel: [ 3664.218118] BcnCheck start after 2600 ms (ra0)
Thu Dec 18 10:52:12 2025 kern.debug kernel: [ 3664.222557] BcnCheck start after 4800 ms (ra0)
Thu Dec 18 10:52:12 2025 kern.warn kernel: [ 3664.331079] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:52:12 2025 kern.err kernel: [ 3664.339949] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.323638] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.332034] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 1360
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.339237] 7981@C23L3,cntl_scan_conf() 625: reset scan fsm, current status is 0x0
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.348293] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.356679] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 1360
Thu Dec 18 10:52:13 2025 kern.debug kernel: [ 3665.363863] SCAN DONE, Reset FSM/CNTL IDLE.
Thu Dec 18 10:52:13 2025 daemon.info gl-repeater[3312]: (repeater.lua:230) apclix0: found 14 networks
Thu Dec 18 10:52:13 2025 daemon.info gl-repeater[3312]: (repeater.lua:677) switch to any...
Thu Dec 18 10:52:13 2025 kern.debug kernel: [ 3665.386505] SetApCliEnableByWdev: I/F(apcli0) (enable = 0)
Thu Dec 18 10:52:13 2025 kern.warn kernel: [ 3665.396227] 7981@C01L2,RTMP_COM_IoctlHandle() 1517: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Thu Dec 18 10:52:13 2025 kern.warn kernel: [ 3665.404373] 7981@C01L2,RTMP_COM_IoctlHandle() 1494:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.412433] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 5
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.418120] 7981@C18L3,BuildChannelList() 507:
Thu Dec 18 10:52:13 2025 kern.debug kernel: [ 3665.424312] wdev_attr_update(): wdevId5 = 9e:83:c4:4c:92:71
Thu Dec 18 10:52:13 2025 kern.info kernel: [ 3665.429995] apclix0: update addr to: 8a:d5:83:81:ef:be
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.435402] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=5
Thu Dec 18 10:52:13 2025 kern.info kernel: [ 3665.449962] extif_set_dev(apclix0)
Thu Dec 18 10:52:13 2025 kern.info kernel: [ 3665.453362] mtk_ppe_dev_register_hook : ineterface apclix0 register (4)
Thu Dec 18 10:52:13 2025 kern.debug kernel: [ 3665.461213] SetApCliEnableByWdev: I/F(apcli1) (enable = 0)
Thu Dec 18 10:52:13 2025 kern.err kernel: [ 3665.467478] 7981@C12L1,Set_ApCliPMFMFPC_Proc() 2003: [PMF]: MFPC=1, MFPR=0, SHA256=0
Thu Dec 18 10:52:13 2025 kern.debug kernel: [ 3665.477647] SetApCliEnableByWdev: I/F(apcli1) (enable = 1)
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.487235] 7981@C23L3,Set_Channel_Proc() 1665: Channel(44), Cert(0), Quick(1)
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.494752] 7981@C23L3,rtmp_set_channel() 2892: (caller:Set_Channel_Proc+0x128/0x618 [mt_wifi]), Channel(44), quick_ch_change:1.
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.506580] 7981@C23L3,perform_channel_change() 2529: (caller:rtmp_set_channel+0x260/0x500 [mt_wifi]), Channel(44), quick_ch_change:1.
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.518721] WiFi@C00L3,NotifyChSwAnnToPeerAPs() 1490: Send CSA NewChannel:44
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.525812] 7981@C23L3,HcUpdateCsaCntByChannel() 599: Channel(48).
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.532033] 7981@C00L3,HcUpdateCsaCntByChannel() 651: CSAEventTimer start(wdev_counter=1)
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.540244] 7981@C23L3,perform_channel_change() 2848: (Channel=44)
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.546479] 7981@C23L3,DfsBuildChannelList() 4114: Done
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.551878] 7981@C23L3,zero_wait_dfs_switch_ch() 1215: outband ch 0, ch_stat 0
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.559146] 7981@C23L3,zero_wait_dfs_switch_ch() 1222: bDedicatedZeroWaitDefault == 0
Thu Dec 18 10:52:13 2025 kern.notice kernel: [ 3665.567500] 7981@C23L3,MakeChSwitchAnnounceIEandExtend() 667: Channel=44, bw=2
Thu Dec 18 10:52:14 2025 kern.notice kernel: [ 3666.621280] 7981@C14L3,ExtEventCswNotifyHandler() 2367: wdev:rax0, wdev->csa_count:0
Thu Dec 18 10:52:14 2025 kern.notice kernel: [ 3666.629029] 7981@C23L3,ChannelSwitchingCountDownProc() 500:  CSAEventTimer normal end!!
Thu Dec 18 10:52:14 2025 kern.notice kernel: [ 3666.637039] 7981@C23L3,Dot11HCntDownTimeoutAction() 607: [RDM]e[1;33m Change to RD_SILENCE_MODEe[m
Thu Dec 18 10:52:14 2025 kern.notice kernel: [ 3666.646005] 7981@C23L3,Dot11HCntDownTimeoutAction() 621: wdev name(rax0), quick 1 ,ch 44
Thu Dec 18 10:52:14 2025 kern.notice kernel: [ 3666.654092] 7981@C23L3,Dot11HCntDownTimeoutAction() 624: cacreq 0
Thu Dec 18 10:52:14 2025 kern.notice kernel: [ 3666.660185] 7981@C13L3,Dot11HCntDownTimeoutAction() 643: CSA done and Disable Beacon: rax0
Thu Dec 18 10:52:14 2025 kern.notice kernel: [ 3666.668671] 7981@C23L3,ap_phy_rrm_init_byRf() 1900: (caller:Dot11HCntDownTimeoutAction+0x284/0xa90 [mt_wifi]), wdev_idx:2.
Thu Dec 18 10:52:14 2025 kern.warn kernel: [ 3666.668735] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:52:14 2025 kern.err kernel: [ 3666.688557] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:52:14 2025 kern.notice kernel: [ 3666.689766] 7981@C13L3,ap_phy_rrm_init_byRf() 2017: Wlan_operate_init and switch channel for : rax0
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.704474] 7981@C23L3,RadarStateCheck() 322: e[1;33m RD_NORMAL_MODE e[m
Thu Dec 18 10:52:15 2025 kern.debug kernel: [ 3666.825487] BcnCheck start after 100 ms (ra0)
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.924486] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.932840] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 1375
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.939995] 7981@C13L3,ap_phy_rrm_init_byRf() 2017: Wlan_operate_init and switch channel for : apclix0
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.950792] 7981@C13L3,Dot11HCntDownTimeoutAction() 714: channel switch diff: 282 msec
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.958743] 7981@C23L3,DfsBuildChannelList() 4114: Done
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.963986] 7981@C23L3,zero_wait_dfs_switch_ch() 1215: outband ch 0, ch_stat 0
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.971212] 7981@C23L3,zero_wait_dfs_switch_ch() 1222: bDedicatedZeroWaitDefault == 0
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.979362] 7981@C23L3,Dot11HCntDownTimeoutAction() 809: cac not req 0
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.986100] 7981@C23L3,Set_Channel_Proc() 1697: wait channel setting success.
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3666.994455] 7981@C03L3,MtCmdTxPwrShowInfo() 13944: ucTxPowerInfoCatg: 2, BandIdx: 1
Thu Dec 18 10:52:15 2025 kern.notice kernel: [ 3667.002354] 7981@C03L3,MtCmdTxPwrShowInfo() 13973: (ret = 0)
Thu Dec 18 10:52:15 2025 kern.debug kernel: [ 3667.008072] [mtf_txpower_all_rate_info] band_idx:1 pwr:42 ChBand:5G ePAGain:0
Thu Dec 18 10:52:15 2025 kern.debug kernel: [ 3667.015703] Set_ByPassCac_Proc(): set CAC value to 1
Thu Dec 18 10:52:15 2025 daemon.notice netifd: Interface 'wwan' is enabled
Thu Dec 18 10:52:15 2025 daemon.info gl-repeater[3312]: (repeater.lua:639) connecting to bss: spywarevirus__5G 5a:ae:a8:8a:63:54 44 psk2
Thu Dec 18 10:52:16 2025 kern.warn kernel: [ 3668.393519] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:52:16 2025 kern.debug kernel: [ 3668.457220] entrytb_aid_aquire(): found non-occupied aid:5, allocated from:4
Thu Dec 18 10:52:16 2025 kern.notice kernel: [ 3668.603270] 7981@C09L3,sta_mlme_auth_req_action() 201: wdev(type=2,wdev_idx=5,wdev_func_idx=1
Thu Dec 18 10:52:16 2025 kern.notice kernel: [ 3668.611791] 7981@C09L3,sta_send_auth_req() 68: STA Start send Auth req
Thu Dec 18 10:52:16 2025 kern.err kernel: [ 3668.618321] 7981@C09L1,sta_send_auth_req() 107: AUTH - Send AUTH request seq#1 (Alg=0)...
Thu Dec 18 10:52:16 2025 kern.notice kernel: [ 3668.627970] 7981@C09L3,sta_mlme_assoc_req_action() 783: ASSOC - Send ASSOC request...
Thu Dec 18 10:52:16 2025 kern.debug kernel: [ 3668.635847] ======================================> check WPA2PSK :1
Thu Dec 18 10:52:16 2025 kern.warn kernel: [ 3668.644856] 7981@C09L2,LinkUp() 3099: !!! LINK UP !!! wdev(name=apclix0,type=2,func_idx=1,PortSecured=22)
Thu Dec 18 10:52:16 2025 kern.warn kernel: [ 3668.654440] 7981@C09L2,LinkUp() 3102: BssType=1, AID=5, ssid=spywarevirus__5G, Channel=44, CentralChannel = 42
Thu Dec 18 10:52:16 2025 kern.notice kernel: [ 3668.664804] 7981@C01L3,wifi_sys_linkup() 1231: wdev idx = 5
Thu Dec 18 10:52:16 2025 kern.notice kernel: [ 3668.671204] 7981@C00L3,wtc_acquire_groupkey_wcid() 84:  Found a non-occupied wtbl_idx:286 for WDEV_TYPE:2
Thu Dec 18 10:52:16 2025 kern.notice kernel: [ 3668.671204]  LinkToOmacIdx = 1, LinkToWdevType = 2
Thu Dec 18 10:52:16 2025 kern.notice kernel: [ 3668.685738] 7981@C08L3,hw_ctrl_flow_v2_link_up() 72: wdev_idx=5
Thu Dec 18 10:52:17 2025 kern.notice kernel: [ 3668.704577] 7981@C01L3,wifi_sys_conn_act() 1115: wdev idx = 5
Thu Dec 18 10:52:17 2025 kern.notice kernel: [ 3668.710954] 7981@C08L3,hw_ctrl_flow_v2_connt_act() 215: wdev_idx=5
Thu Dec 18 10:52:17 2025 kern.notice kernel: [ 3668.736915] 7981@C15L3,PeerPairMsg1Action() 6120: ===>Receive msg 1
Thu Dec 18 10:52:17 2025 kern.notice kernel: [ 3668.750052] 7981@C15L3,WPABuildPairMsg2() 5367: <=== send Msg2 of 4-way
Thu Dec 18 10:52:17 2025 kern.notice kernel: [ 3668.756719] 7981@C15L3,PeerPairMsg3Action() 6640: ===>Receive msg 3
Thu Dec 18 10:52:17 2025 kern.err kernel: [ 3668.763323] WiFi@C15L1,RTMPCheckRSNIE() 4543: WPA/WPAPSK IE mis-matched
Thu Dec 18 10:52:17 2025 kern.info kernel: [ 3668.770037] IPv6: ADDRCONF(NETDEV_CHANGE): apclix0: link becomes ready
Thu Dec 18 10:52:17 2025 daemon.notice netifd: Network device 'apclix0' link is up
Thu Dec 18 10:52:17 2025 daemon.notice netifd: Interface 'wwan' has link connectivity
Thu Dec 18 10:52:17 2025 daemon.notice netifd: Interface 'wwan' is setting up now
Thu Dec 18 10:52:17 2025 kern.notice kernel: [ 3668.783761] 7981@C15L3,WPABuildPairMsg4() 5840: <=== send Msg4 of 4-way
Thu Dec 18 10:52:17 2025 kern.debug kernel: [ 3668.790974] add link apclix0, blk_mc:0, link_tbl_cnt=1
Thu Dec 18 10:52:17 2025 kern.debug kernel: [ 3668.796211] nf_register_hooks()
Thu Dec 18 10:52:17 2025 kern.debug kernel: [ 3668.801285] add new: rax0(UP)->apclix0(UP), active path:1
Thu Dec 18 10:52:17 2025 kern.debug kernel: [ 3668.812438] add new: rax1(UP)->apclix0(UP), active path:2
Thu Dec 18 10:52:17 2025 kern.debug kernel: [ 3668.818866] add new: eth1(UP)->apclix0(UP), active path:3
Thu Dec 18 10:52:17 2025 daemon.info gl-repeater[3312]: (repeater.lua:380) connected to spywarevirus__5G
Thu Dec 18 10:52:17 2025 daemon.notice netifd: wwan (27095): udhcpc: started, v1.33.2
Thu Dec 18 10:52:17 2025 daemon.notice netifd: wwan (27095): udhcpc: sending discover
Thu Dec 18 10:52:18 2025 daemon.info avahi-daemon[5272]: Joining mDNS multicast group on interface apclix0.IPv6 with address fe80::88d5:83ff:fe81:efbe.
Thu Dec 18 10:52:18 2025 daemon.info avahi-daemon[5272]: New relevant interface apclix0.IPv6 for mDNS.
Thu Dec 18 10:52:18 2025 daemon.info avahi-daemon[5272]: Registering new address record for fe80::88d5:83ff:fe81:efbe on apclix0.*.
Thu Dec 18 10:52:19 2025 daemon.notice netifd: wwan (27095): udhcpc: sending select for 192.168.1.176
Thu Dec 18 10:52:19 2025 daemon.notice netifd: wwan (27095): udhcpc: lease of 192.168.1.176 obtained, lease time 86400
Thu Dec 18 10:52:19 2025 daemon.info avahi-daemon[5272]: Joining mDNS multicast group on interface apclix0.IPv4 with address 192.168.1.176.
Thu Dec 18 10:52:19 2025 daemon.info avahi-daemon[5272]: New relevant interface apclix0.IPv4 for mDNS.
Thu Dec 18 10:52:19 2025 daemon.info avahi-daemon[5272]: Registering new address record for 192.168.1.176 on apclix0.IPv4.
Thu Dec 18 10:52:19 2025 daemon.info gl-repeater[3312]: (repeater.lua:1207) interface "wwan" up
Thu Dec 18 10:52:19 2025 daemon.notice netifd: Interface 'wwan' is now up
Thu Dec 18 10:52:19 2025 daemon.info dnsmasq[8948]: reading /tmp/resolv.conf.d/resolv.conf.auto
Thu Dec 18 10:52:19 2025 daemon.info dnsmasq[8948]: using only locally-known addresses for domain test
Thu Dec 18 10:52:19 2025 daemon.info dnsmasq[8948]: using only locally-known addresses for domain onion
Thu Dec 18 10:52:19 2025 daemon.info dnsmasq[8948]: using only locally-known addresses for domain localhost
Thu Dec 18 10:52:19 2025 daemon.info dnsmasq[8948]: using only locally-known addresses for domain invalid
Thu Dec 18 10:52:19 2025 daemon.info dnsmasq[8948]: using only locally-known addresses for domain bind
Thu Dec 18 10:52:19 2025 daemon.info dnsmasq[8948]: using only locally-known addresses for domain lan
Thu Dec 18 10:52:19 2025 daemon.info dnsmasq[8948]: using nameserver 192.168.1.1#53
Thu Dec 18 10:52:19 2025 user.notice firewall: Reloading firewall due to ifup of wwan (apclix0)
Thu Dec 18 10:52:19 2025 kern.debug kernel: [ 3671.320447] BcnCheck start after 2500 ms (ra0)
Thu Dec 18 10:52:19 2025 kern.debug kernel: [ 3671.324904] BcnCheck start after 2500 ms (ra0)
Thu Dec 18 10:52:19 2025 user.notice kmwan: config json str={ "op": 2, "data": { "cells": [ { "interface": "wwan", "netdev": "apclix0", "track_mode": "force", "addr_type": 4, "tracks": [ { "type": "ping", "ip": "1.1.1.1" }, { "type": "ping", "ip": "8.8.8.8" }, { "type": "ping", "ip": "208.67.222.222" }, { "type": "ping", "ip": "208.67.220.220" } ] } ] } }
Thu Dec 18 10:52:19 2025 kern.debug kernel: [ 3671.362698] [add_dev_config 287]add node success. iface:wwan, dev:apclix0, ifindex:10
Thu Dec 18 10:52:19 2025 user.notice kmwan: config json str={ "op": 5, "data": { "cells": [ "wwan" ] } }
Thu Dec 18 10:52:19 2025 user.notice kmwan: config json str={ "op": 4, "data": { "cells": [ "wwan" ] } }
Thu Dec 18 10:52:20 2025 daemon.info gl-repeater[3312]: (repeater-portal.lua:269) disable kmwan track wwan
Thu Dec 18 10:52:21 2025 daemon.info gl-repeater[3312]: (repeater-portal.lua:451) portal detecting...
Thu Dec 18 10:52:21 2025 daemon.info gl-repeater[3312]: (repeater-portal.lua:269) enable kmwan track wwan
Thu Dec 18 10:52:22 2025 daemon.info gl-repeater[3312]: (repeater-portal.lua:473) not found portal
Thu Dec 18 10:51:03 2025 daemon.info gl-repeater[3312]: (repeater.lua:262) scanning...
Thu Dec 18 10:51:03 2025 kern.info kernel: [ 3595.202821] Set ScanSSID =
Thu Dec 18 10:51:03 2025 kern.debug kernel: [ 3595.205700] Number of channels to scan = 5
Thu Dec 18 10:51:03 2025 kern.debug kernel: [ 3595.209864] bScanning = 1
Thu Dec 18 10:51:03 2025 kern.info kernel: [ 3595.213173] Set ScanSSID =
Thu Dec 18 10:51:03 2025 kern.debug kernel: [ 3595.216060] Number of channels to scan = 5
Thu Dec 18 10:51:03 2025 kern.debug kernel: [ 3595.220218] bScanning = 1
Thu Dec 18 10:51:03 2025 kern.warn kernel: [ 3595.490748] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (d6:01:a4:03:d9:b4), Reason 0x10
Thu Dec 18 10:51:03 2025 kern.err kernel: [ 3595.499619] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:03 2025 kern.warn kernel: [ 3595.521039] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:51:03 2025 kern.err kernel: [ 3595.529905] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:04 2025 kern.notice kernel: [ 3596.380711] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:51:04 2025 kern.notice kernel: [ 3596.388982] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 699
Thu Dec 18 10:51:04 2025 kern.debug kernel: [ 3596.414776] BcnCheck start after 4900 ms (ra0)
Thu Dec 18 10:51:04 2025 kern.notice kernel: [ 3596.601826] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:51:04 2025 kern.warn kernel: [ 3596.603373] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:51:04 2025 kern.notice kernel: [ 3596.610191] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 701
Thu Dec 18 10:51:04 2025 kern.err kernel: [ 3596.619035] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:04 2025 kern.warn kernel: [ 3596.638143] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (d6:01:a4:03:d9:b4), Reason 0x10
Thu Dec 18 10:51:04 2025 kern.err kernel: [ 3596.647014] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:05 2025 kern.warn kernel: [ 3596.848597] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:51:05 2025 kern.err kernel: [ 3596.857467] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:05 2025 kern.notice kernel: [ 3597.512036] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:51:05 2025 kern.notice kernel: [ 3597.520311] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 710
Thu Dec 18 10:51:06 2025 kern.notice kernel: [ 3597.889018] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:51:06 2025 kern.notice kernel: [ 3597.897376] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 714
Thu Dec 18 10:51:06 2025 kern.warn kernel: [ 3597.915759] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (d6:01:a4:03:d9:b4), Reason 0x10
Thu Dec 18 10:51:06 2025 kern.err kernel: [ 3597.924628] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:06 2025 kern.notice kernel: [ 3598.181972] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:51:06 2025 kern.notice kernel: [ 3598.190262] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 717
Thu Dec 18 10:51:06 2025 kern.notice kernel: [ 3598.197326] 7981@C23L3,cntl_scan_conf() 625: reset scan fsm, current status is 0x0
Thu Dec 18 10:51:06 2025 kern.notice kernel: [ 3598.204945] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (ra0)
Thu Dec 18 10:51:06 2025 kern.notice kernel: [ 3598.213244] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band0 BcnInitedRnd = 717
Thu Dec 18 10:51:06 2025 kern.debug kernel: [ 3598.220293] SCAN DONE, Reset FSM/CNTL IDLE.
Thu Dec 18 10:51:06 2025 daemon.info gl-repeater[3312]: (repeater.lua:230) apcli0: found 23 networks
Thu Dec 18 10:51:06 2025 kern.warn kernel: [ 3598.238572] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:51:06 2025 kern.err kernel: [ 3598.247441] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:07 2025 kern.debug kernel: [ 3599.018130] BcnCheck start after 4200 ms (ra0)
Thu Dec 18 10:51:07 2025 kern.notice kernel: [ 3599.233962] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:51:07 2025 kern.notice kernel: [ 3599.242320] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 727
Thu Dec 18 10:51:07 2025 kern.warn kernel: [ 3599.557176] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:51:07 2025 kern.err kernel: [ 3599.566045] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:08 2025 kern.notice kernel: [ 3600.525396] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:51:08 2025 kern.notice kernel: [ 3600.533759] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 739
Thu Dec 18 10:51:09 2025 kern.warn kernel: [ 3600.790728] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:51:09 2025 kern.err kernel: [ 3600.799598] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:09 2025 kern.debug kernel: [ 3601.621482] BcnCheck start after 1700 ms (ra0)
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.777052] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:51:10 2025 kern.warn kernel: [ 3601.778741] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.785420] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 751
Thu Dec 18 10:51:10 2025 kern.err kernel: [ 3601.794255] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.801300] 7981@C23L3,cntl_scan_conf() 625: reset scan fsm, current status is 0x0
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.817084] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.825447] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 751
Thu Dec 18 10:51:10 2025 kern.debug kernel: [ 3601.832498] SCAN DONE, Reset FSM/CNTL IDLE.
Thu Dec 18 10:51:10 2025 daemon.info gl-repeater[3312]: (repeater.lua:230) apclix0: found 15 networks
Thu Dec 18 10:51:10 2025 daemon.info gl-repeater[3312]: (repeater.lua:677) switch to any...
Thu Dec 18 10:51:10 2025 kern.debug kernel: [ 3601.855132] SetApCliEnableByWdev: I/F(apcli0) (enable = 0)
Thu Dec 18 10:51:10 2025 kern.warn kernel: [ 3601.864416] 7981@C01L2,RTMP_COM_IoctlHandle() 1517: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Thu Dec 18 10:51:10 2025 kern.warn kernel: [ 3601.872559] 7981@C01L2,RTMP_COM_IoctlHandle() 1494:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.880596] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 5
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.886261] 7981@C18L3,BuildChannelList() 507:
Thu Dec 18 10:51:10 2025 kern.debug kernel: [ 3601.892421] wdev_attr_update(): wdevId5 = 9e:83:c4:4c:92:71
Thu Dec 18 10:51:10 2025 kern.info kernel: [ 3601.898108] apclix0: update addr to: 8a:d5:83:81:ef:be
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.903415] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=5
Thu Dec 18 10:51:10 2025 kern.info kernel: [ 3601.918468] extif_set_dev(apclix0)
Thu Dec 18 10:51:10 2025 kern.info kernel: [ 3601.921903] mtk_ppe_dev_register_hook : ineterface apclix0 register (4)
Thu Dec 18 10:51:10 2025 kern.debug kernel: [ 3601.930557] SetApCliEnableByWdev: I/F(apcli1) (enable = 0)
Thu Dec 18 10:51:10 2025 kern.err kernel: [ 3601.936524] 7981@C12L1,Set_ApCliPMFMFPC_Proc() 2003: [PMF]: MFPC=1, MFPR=0, SHA256=0
Thu Dec 18 10:51:10 2025 kern.debug kernel: [ 3601.952298] SetApCliEnableByWdev: I/F(apcli1) (enable = 1)
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.962343] 7981@C23L3,Set_Channel_Proc() 1665: Channel(48), Cert(0), Quick(1)
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.969871] 7981@C23L3,rtmp_set_channel() 2892: (caller:Set_Channel_Proc+0x128/0x618 [mt_wifi]), Channel(48), quick_ch_change:1.
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.981794] 7981@C23L3,perform_channel_change() 2529: (caller:rtmp_set_channel+0x260/0x500 [mt_wifi]), Channel(48), quick_ch_change:1.
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3601.994122] WiFi@C00L3,NotifyChSwAnnToPeerAPs() 1490: Send CSA NewChannel:48
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3602.001343] 7981@C23L3,HcUpdateCsaCntByChannel() 599: Channel(44).
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3602.007783] 7981@C00L3,HcUpdateCsaCntByChannel() 651: CSAEventTimer start(wdev_counter=1)
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3602.011446] 7981@C23L3,MakeChSwitchAnnounceIEandExtend() 667: Channel=48, bw=2
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3602.015982] 7981@C23L3,perform_channel_change() 2848: (Channel=48)
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3602.029470] 7981@C23L3,DfsBuildChannelList() 4114: Done
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3602.034781] 7981@C23L3,zero_wait_dfs_switch_ch() 1215: outband ch 0, ch_stat 0
Thu Dec 18 10:51:10 2025 kern.notice kernel: [ 3602.042110] 7981@C23L3,zero_wait_dfs_switch_ch() 1222: bDedicatedZeroWaitDefault == 0
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.148708] 7981@C14L3,ExtEventCswNotifyHandler() 2367: wdev:rax0, wdev->csa_count:0
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.156455] 7981@C23L3,ChannelSwitchingCountDownProc() 500:  CSAEventTimer normal end!!
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.164469] 7981@C23L3,Dot11HCntDownTimeoutAction() 607: [RDM]e[1;33m Change to RD_SILENCE_MODEe[m
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.173428] 7981@C23L3,Dot11HCntDownTimeoutAction() 621: wdev name(rax0), quick 1 ,ch 48
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.181516] 7981@C23L3,Dot11HCntDownTimeoutAction() 624: cacreq 0
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.187609] 7981@C13L3,Dot11HCntDownTimeoutAction() 643: CSA done and Disable Beacon: rax0
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.196100] 7981@C23L3,ap_phy_rrm_init_byRf() 1900: (caller:Dot11HCntDownTimeoutAction+0x284/0xa90 [mt_wifi]), wdev_idx:2.
Thu Dec 18 10:51:11 2025 kern.warn kernel: [ 3603.196895] 7981@C03L2,ExtEventBeaconLostHandler() 170: FW EVENT (be:8c:a4:a4:71:de), Reason 0x10
Thu Dec 18 10:51:11 2025 kern.err kernel: [ 3603.216005] 7981@C03L1,ExtEventBeaconLostHandler() 176:   AP Beacon OFF!!!
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.217195] 7981@C13L3,ap_phy_rrm_init_byRf() 2017: Wlan_operate_init and switch channel for : rax0
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.231926] 7981@C23L3,RadarStateCheck() 322: e[1;33m RD_NORMAL_MODE e[m
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.449081] 7981@C08L3,UpdateBeaconHandler() 2087: BCN_UPDATE_ENABLE_TX, OmacIdx = 0 (rax0)
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.457457] 7981@C08L3,UpdateBeaconHandler() 2092: 	Band1 BcnInitedRnd = 767
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.464529] 7981@C13L3,ap_phy_rrm_init_byRf() 2017: Wlan_operate_init and switch channel for : apclix0
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.475225] 7981@C13L3,Dot11HCntDownTimeoutAction() 714: channel switch diff: 279 msec
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.483231] 7981@C23L3,DfsBuildChannelList() 4114: Done
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.488468] 7981@C23L3,zero_wait_dfs_switch_ch() 1215: outband ch 0, ch_stat 0
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.495689] 7981@C23L3,zero_wait_dfs_switch_ch() 1222: bDedicatedZeroWaitDefault == 0
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.503926] 7981@C23L3,Dot11HCntDownTimeoutAction() 809: cac not req 0
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.510498] 7981@C23L3,Set_Channel_Proc() 1697: wait channel setting success.
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.517772] 7981@C03L3,MtCmdTxPwrShowInfo() 13944: ucTxPowerInfoCatg: 2, BandIdx: 1
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.525597] 7981@C03L3,MtCmdTxPwrShowInfo() 13973: (ret = 0)
Thu Dec 18 10:51:11 2025 kern.debug kernel: [ 3603.531306] [mtf_txpower_all_rate_info] band_idx:1 pwr:42 ChBand:5G ePAGain:0
Thu Dec 18 10:51:11 2025 kern.debug kernel: [ 3603.539036] Set_ByPassCac_Proc(): set CAC value to 1
Thu Dec 18 10:51:11 2025 kern.warn kernel: [ 3603.545929] 7981@C01L2,RTMP_COM_IoctlHandle() 1505:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DOWN
Thu Dec 18 10:51:11 2025 kern.debug kernel: [ 3603.554491] mtwf_dbg_prt: vsnprintf error
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.558580] 7981@C09L3,sync_fsm_reset() 2705: (caller : rt28xx_sta_ioctl+0xadc/0x1ed8 [mt_wifi]) SYNC[apclix0, Band:1]: [IDLE] =========================================> [
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.559143] WiFi@C01L3,wifi_sys_close() 945: wdev idx = 5
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.580118] 7981@C08L3,hw_ctrl_flow_v2_close() 41: wdev_idx=5
Thu Dec 18 10:51:11 2025 kern.warn kernel: [ 3603.586200] 7981@C01L2,RTMP_COM_IoctlHandle() 1528: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DEINIT
Thu Dec 18 10:51:11 2025 kern.info kernel: [ 3603.594566] extif_put_dev(apclix0)
Thu Dec 18 10:51:11 2025 kern.info kernel: [ 3603.598268] mtk_ppe_dev_unregister_hook : ineterface apclix0 set null (4)
Thu Dec 18 10:51:11 2025 kern.warn kernel: [ 3603.608579] 7981@C01L2,RTMP_COM_IoctlHandle() 1517: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_INIT
Thu Dec 18 10:51:11 2025 kern.warn kernel: [ 3603.616749] 7981@C01L2,RTMP_COM_IoctlHandle() 1494:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_UP
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.624811] WiFi@C01L3,wifi_sys_open() 856: wdev idx = 5
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.630451] 7981@C18L3,BuildChannelList() 507:
Thu Dec 18 10:51:11 2025 kern.debug kernel: [ 3603.636584] wdev_attr_update(): wdevId5 = 9e:83:c4:4c:92:71
Thu Dec 18 10:51:11 2025 kern.info kernel: [ 3603.642211] apclix0: update addr to: 8a:d5:83:81:ef:be
Thu Dec 18 10:51:11 2025 kern.notice kernel: [ 3603.647442] 7981@C08L3,hw_ctrl_flow_v2_open() 13: wdev_idx=5
Thu Dec 18 10:51:11 2025 kern.info kernel: [ 3603.654408] extif_set_dev(apclix0)
Thu Dec 18 10:51:11 2025 kern.info kernel: [ 3603.657842] mtk_ppe_dev_register_hook : ineterface apclix0 register (4)
Thu Dec 18 10:51:11 2025 daemon.notice netifd: Interface 'wwan' is enabled
Thu Dec 18 10:51:11 2025 daemon.info gl-repeater[3312]: (repeater.lua:639) connecting to bss: spywarevirus__5G 5a:ae:a8:8a:63:54 48 psk2
Thu Dec 18 10:51:12 2025 kern.warn kernel: [ 3603.721458] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:12 2025 kern.debug kernel: [ 3604.248830] BcnCheck start after 4200 ms (ra0)
Thu Dec 18 10:51:14 2025 kern.warn kernel: [ 3605.756482] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:14 2025 kern.warn kernel: [ 3605.808834] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:14 2025 kern.err kernel: [ 3605.818149] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Thu Dec 18 10:51:15 2025 kern.debug kernel: [ 3606.864186] BcnCheck start after 1700 ms (ra0)
Thu Dec 18 10:51:16 2025 kern.warn kernel: [ 3607.771966] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:16 2025 kern.warn kernel: [ 3607.908330] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:16 2025 kern.err kernel: [ 3607.917647] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Thu Dec 18 10:51:18 2025 kern.warn kernel: [ 3609.787467] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:18 2025 kern.warn kernel: [ 3610.003817] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:18 2025 kern.err kernel: [ 3610.013141] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Thu Dec 18 10:51:20 2025 kern.warn kernel: [ 3611.802982] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:20 2025 kern.warn kernel: [ 3612.103284] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:20 2025 kern.err kernel: [ 3612.112602] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Thu Dec 18 10:51:22 2025 kern.warn kernel: [ 3613.818501] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:22 2025 kern.warn kernel: [ 3614.182766] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:24 2025 kern.warn kernel: [ 3616.217877] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:24 2025 kern.warn kernel: [ 3616.270244] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:24 2025 kern.err kernel: [ 3616.279561] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Thu Dec 18 10:51:26 2025 kern.warn kernel: [ 3618.233382] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:26 2025 kern.warn kernel: [ 3618.361801] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:26 2025 kern.err kernel: [ 3618.371126] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Thu Dec 18 10:51:28 2025 kern.warn kernel: [ 3620.248878] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:28 2025 kern.warn kernel: [ 3620.461223] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:28 2025 kern.err kernel: [ 3620.470548] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Thu Dec 18 10:51:30 2025 kern.warn kernel: [ 3622.264421] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:30 2025 kern.warn kernel: [ 3622.556715] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:30 2025 kern.err kernel: [ 3622.566040] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Thu Dec 18 10:51:32 2025 kern.warn kernel: [ 3624.279908] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:32 2025 kern.warn kernel: [ 3624.652187] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:32 2025 kern.err kernel: [ 3624.661510] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Thu Dec 18 10:51:34 2025 kern.warn kernel: [ 3626.295394] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:35 2025 kern.warn kernel: [ 3626.751674] 7981@C09L2,cntl_connect_request() 395: type=2,len=0,caller:ApCliIfUp+0x184/0x358 [mt_wifi]
Thu Dec 18 10:51:35 2025 kern.err kernel: [ 3626.760998] 7981@C09L1,cntl_connect_request() 412: Return since CNTL not IDLE,CNTL(1),SYNC(2),AUTH(0),ASSOC(0)
Thu Dec 18 10:51:36 2025 kern.warn kernel: [ 3628.310895] 7981@C09L2,sync_fsm_join_timeout_action() 1091: ProbeTimeoutAtJoinAction
Thu Dec 18 10:51:36 2025 daemon.err gl-repeater[3312]: (repeater.lua:322) connect timeout
Thu Dec 18 10:51:36 2025 daemon.info gl-repeater[3312]: (repeater-mtk.lua:470) remove "apclix0" from wwan
Thu Dec 18 10:51:36 2025 kern.warn kernel: [ 3628.672347] 7981@C01L2,RTMP_COM_IoctlHandle() 1505:  -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DOWN
Thu Dec 18 10:51:36 2025 kern.debug kernel: [ 3628.680798] mtwf_dbg_prt: vsnprintf error
Thu Dec 18 10:51:36 2025 kern.notice kernel: [ 3628.684830] 7981@C09L3,sync_fsm_reset() 2705: (caller : rt28xx_sta_ioctl+0xadc/0x1ed8 [mt_wifi]) SYNC[apclix0, Band:1]: [JOIN_WAIT] =======================================
Thu Dec 18 10:51:36 2025 kern.notice kernel: [ 3628.685385] WiFi@C01L3,wifi_sys_close() 945: wdev idx = 5
Thu Dec 18 10:51:36 2025 kern.notice kernel: [ 3628.706338] 7981@C08L3,hw_ctrl_flow_v2_close() 41: wdev_idx=5
Thu Dec 18 10:51:36 2025 kern.warn kernel: [ 3628.712359] 7981@C01L2,RTMP_COM_IoctlHandle() 1528: -> CMD_RTPRIV_IOCTL_VIRTUAL_INF_DEINIT
Thu Dec 18 10:51:37 2025 kern.info kernel: [ 3628.720756] extif_put_dev(apclix0)
Thu Dec 18 10:51:37 2025 kern.info kernel: [ 3628.724161] mtk_ppe_dev_unregister_hook : ineterface apclix0 set null (4)
Thu Dec 18 10:51:37 2025 daemon.notice netifd: Interface 'wwan' is disabled
Thu Dec 18 10:51:37 2025 kern.err kernel: [ 3628.732405] 7981@C12L1,rt28xx_ap_ioctl() 894: interface is down, cmd [8be2] return!!!
Thu Dec 18 10:51:37 2025 daemon.info gl-repeater[3312]: (repeater.lua:1001) switch in 30 seconds...
Thu Dec 18 10:51:37 2025 daemon.info gl-repeater[3312]: (repeater.lua:406) check status exited
Thu Dec 18 10:51:37 2025 daemon.info gl-repeater[3312]: (repeater-mtk.lua:366) listen event exited
Thu Dec 18 10:51:38 2025 kern.err kernel: [ 3630.326391] 7981@C13L1,MlmeEnqueueWithWdev() 5715: wdev(5) state: if down!
Thu Dec 18 10:52:07 2025 daemon.info gl-repeater[3312]: (repeater.lua:262) scanning...
Thu Dec 18 10:52:07 2025 kern.info kernel: [ 3658.727042] Set ScanSSID =
Thu Dec 18 10:52:07 2025 kern.debug kernel: [ 3658.729914] Number of channels to scan = 5
Thu Dec 18 10:52:07 2025 kern.debug kernel: [ 3658.734157] bScanning = 1
Thu Dec 18 10:52:07 2025 kern.info kernel: [ 3658.737457] Set ScanSSID =
Thu Dec 18 10:52:07 2025 kern.debug kernel: [ 3658.740336] Number of channels to scan = 5
From the snippet you shared, it looks like the log was captured after the disconnect happened, so it doesn’t show the actual reason the link dropped. The lines shown afterwards look like a normal recovery flow (interface reset / reconnect).
Could you please check the following:
  1. Are you using the original power adapter, or another supply that reliably meets 5V/3A?
  2. Please try updating to v4.8.2 beta or v4.8.3 Snapshot and see whether the issue still occurs.
  3. If it continues, please export the full system log and send it to us via PM so we can review it in detail.
  4. If convenient, it’s also worth testing the 4.8.3-op24 firmware.
Download link: GL.iNet download center
Upgrade guide: Upgrade - GL.iNet Router Docs 4
How to export logs:
How to send private messages:
Thanks for the quick reply.
I’m using an Anker 65w 4-port power adapter to power the router and my laptop. Unfortunately I don’t have any other USB power supply with me to test with.
I've upgraded to 4.8.2 beta and we'll see.
Meanwhile, I’ll send you the full logs but when I cick your initial I don’t get a ‘message’ button, just the text:
This user's public profile is hidden.
Is this because of my newbie trust level?
We've raised your trust level, so you should now be able to send private messages normally.
Missing beacons is a reason for 802.11/wifi to disconnect.
Beacons are send differently from normal unicast packages. (Unicast packages require ACK when received, if not ACKed they are retransmitted , and if that fails mutiple times the interface rate is shifted down, and transmission retried.) Multicasts/beacons are not ACKed. First attempt must be succesfull. Therefore it is sent at the “basic rate” , typical 6Mbps unless configured otherwise in the AP. Because basic rate is so slow (6Mbps versus 433 or 866Mbps), some people set this basic rate to 9,12 even 24Mbps and higher. This can cause missed beacons and multicasts , in a busy or (electromagnetic) noisy environment. (obstacles and reflections can cause extra interference also, just as too strong or nearby AP)
It looks like I may owe everyone an apology. I assumed the uplink router was fine because my friend was using it the whole time. Turns out he didn’t mention to me that it had been dropping periodically; the fault is there, not in the MT-3000.
I hadn’t thought that was likely because I was getting disconnections at the last place I stayed as well, and that seemed like too much of a coincidence. But I never really investigated those disconnections, so who knows.
Thanks everyone, I’ll come back here if I still have problems at my next destination.
