I am sorry if this question has been already answered, I found nothing.
I am a big fan of MC (Midnight Commander) but in the remote SSH sessions the keys F1-F5 don’t work (they just generate letters) but F6 for example works as expected. Is there a way to fix that and make the keys F1-F5 usable?
I don’t think the issue is on the routers side. I would take a look on what the SSH client is sending.
On a Linux SSH client, start with the setting echo $TERM …
Depending on the used terminal emulator (xterm, terminal, term, …) There are different ways of ‘correct’ the command, send by keypress.
Wait a second, I am talking about the remote SSH session initiated by GoodCloud.
There are no any problems with running mc from ssh sessions opened from Linux/Windows using putty / remmina with SSH plugin.
Now, to answer the second question:
a) when the remote session (initiated by goodcloud) is opened I am getting the error message:
