I’m having an issue with my GL-X1200 disconnecting from or not being able to connect to my phones 5G hotspot… I’m using the latest beta firmware 3.203… The hot spots I’m having issues with are both on Samsung Galaxy phones (Note 20 & 9) using Tmobile… Have tried to change the hotspot band on the phones but it appears that you can’t? Other devices have no issues connecting to the phone 5G hotspot… Appreciate any suggestions!
Is there any settings like compatibilty in your phone’s hotspot settings?
Are you able to connect to the Galaxy 5G hotspot from a PC, tablet, computer or even from 1 Galaxy phone to the other Galaxy phone?
No problems connecting the Galaxy Note20 5G to my laptop… It connects and stays connected… The disconnect issues are only occurring between the phone and the GL-X1200 .
The only change that I can make is the band (5Ghz or 2.4Ghz)… The issue appears to be related to distance… When the phone is within 3’ of the GL-X1200 I stay connected… As soon as I move the phone away it disconnects from the router… I’ve tried both max power and high power on the GL-x1200 and the issue remains… I have no issues connecting other devices to the phones hotspot.
Can you reboot, then post the System Log (logread in SSH) and Kernel Log (dmesg in SSH) after you get disconnects?
Here’s the sys log:
Thu Dec 30 10:26:55 2021 user.info : gl_health start->
Thu Dec 30 10:26:55 2021 user.info mwan3rtmon[2661]: Detect rtchange event.
Thu Dec 30 10:26:58 2021 daemon.notice procd: /etc/rc.d/S99lighttpd: sed: /etc/lighttpd/conf.d/10-port.conf: No such file or directory
Thu Dec 30 10:26:58 2021 daemon.notice procd: /etc/rc.d/S99lighttpd: netstat: showing only processes with your user ID
Thu Dec 30 10:27:04 2021 user.notice wireguard: wireguard client start
Thu Dec 30 10:27:05 2021 daemon.info procd: - init complete -
Thu Dec 30 10:28:53 2021 user.info : saved ssid ignore: JimsHotSpot 0
Thu Dec 30 10:28:53 2021 user.info : [ 810] gl-sdk>> bIsSaved=0, ssid=JimsHotSpot, encryption=psk2, bssid=5A:D5:0A:F6:37:C6, wds=0, device=radio0, identity=, channel=149
Thu Dec 30 10:28:54 2021 user.info : [ 2888] gl-wifi-core>> bIsStaEnabled=1
Thu Dec 30 10:28:54 2021 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Thu Dec 30 10:28:54 2021 daemon.notice hostapd: wlan0: AP-DISABLED
Thu Dec 30 10:28:54 2021 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Thu Dec 30 10:28:54 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Thu Dec 30 10:28:54 2021 daemon.notice netifd: Network device ‘wlan0’ link is down
Thu Dec 30 10:28:54 2021 kern.info kernel: [ 198.716207] device wlan0 left promiscuous mode
Thu Dec 30 10:28:54 2021 kern.info kernel: [ 198.720948] br-lan: port 2(wlan0) entered disabled state
Thu Dec 30 10:28:54 2021 kern.warn kernel: [ 198.730879] ath10k_pci 0000:00:00.0: peer-unmap-event: unknown peer id 0
Thu Dec 30 10:28:54 2021 kern.warn kernel: [ 198.737845] ath10k_pci 0000:00:00.0: peer-unmap-event: unknown peer id 0
Thu Dec 30 10:28:55 2021 daemon.notice netifd: radio0 (7598): command failed: Not supported (-122)
Thu Dec 30 10:28:55 2021 user.notice mac80211: Failed command: iw phy phy0 set distance 0
Thu Dec 30 10:28:55 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Thu Dec 30 10:28:57 2021 kern.warn kernel: [ 202.340587] ath10k_pci 0000:00:00.0: 10.4 wmi init: vdevs: 4 peers: 100 tid: 256
Thu Dec 30 10:28:57 2021 kern.info kernel: [ 202.348470] ath10k_pci 0000:00:00.0: using 7 firmware rate-ctrl objects
Thu Dec 30 10:28:57 2021 kern.warn kernel: [ 202.355345] ath10k_pci 0000:00:00.0: msdu-desc: 2200 skid: 360
Thu Dec 30 10:28:58 2021 kern.info kernel: [ 202.407190] ath10k_pci 0000:00:00.0: wmi print ‘P 100/100 V 4 K 300 PH 308 T 374 msdu-desc: 2200 sw-crypt: 0 ct-sta: 0’
Thu Dec 30 10:28:58 2021 kern.info kernel: [ 202.418655] ath10k_pci 0000:00:00.0: wmi print ‘free: 77164 iram: 14036 sram: 21840’
Thu Dec 30 10:28:58 2021 kern.warn kernel: [ 202.720067] ath10k_pci 0000:00:00.0: Firmware lacks feature flag indicating a retry limit of > 2 is OK, requested limit: 4
Thu Dec 30 10:28:58 2021 daemon.notice netifd: radio0 (7598): sh: /usr/bin/ovs-vsctl: not found
Thu Dec 30 10:28:58 2021 kern.info kernel: [ 202.812768] br-lan: port 2(wlan0) entered blocking state
Thu Dec 30 10:28:58 2021 kern.info kernel: [ 202.818283] br-lan: port 2(wlan0) entered disabled state
Thu Dec 30 10:28:58 2021 kern.info kernel: [ 202.824122] device wlan0 entered promiscuous mode
Thu Dec 30 10:28:58 2021 daemon.err hostapd: Using interface wlan0 with hwaddr 10:34:56:78:90:12 and ssid “SeaLaVie-5G”
Thu Dec 30 10:28:58 2021 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->ENABLED
Thu Dec 30 10:28:58 2021 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Dec 30 10:28:58 2021 daemon.notice wpa_supplicant[7847]: Successfully initialized wpa_supplicant
Thu Dec 30 10:28:59 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Thu Dec 30 10:29:02 2021 daemon.notice wpa_supplicant[7848]: wlan-sta: SME: Trying to authenticate with 5a:d5:0a:f6:37:c6 (SSID=‘JimsHotSpot’ freq=5745 MHz)
Thu Dec 30 10:29:02 2021 kern.info kernel: [ 206.602337] wlan-sta: authenticate with 5a:d5:0a:f6:37:c6
Thu Dec 30 10:29:02 2021 kern.info kernel: [ 206.823228] wlan-sta: send auth to 5a:d5:0a:f6:37:c6 (try 1/3)
Thu Dec 30 10:29:02 2021 daemon.notice wpa_supplicant[7848]: wlan-sta: Trying to associate with 5a:d5:0a:f6:37:c6 (SSID=‘JimsHotSpot’ freq=5745 MHz)
Thu Dec 30 10:29:02 2021 kern.info kernel: [ 206.831942] wlan-sta: authenticated
Thu Dec 30 10:29:02 2021 kern.info kernel: [ 206.839848] wlan-sta: associate with 5a:d5:0a:f6:37:c6 (try 1/3)
Thu Dec 30 10:29:02 2021 kern.info kernel: [ 206.848215] wlan-sta: RX AssocResp from 5a:d5:0a:f6:37:c6 (capab=0x11 status=0 aid=1)
Thu Dec 30 10:29:02 2021 kern.info kernel: [ 206.858215] wlan-sta: associated
Thu Dec 30 10:29:02 2021 daemon.notice netifd: Network device ‘wlan-sta’ link is up
Thu Dec 30 10:29:02 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Thu Dec 30 10:29:02 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Thu Dec 30 10:29:02 2021 daemon.notice wpa_supplicant[7848]: wlan-sta: Associated with 5a:d5:0a:f6:37:c6
Thu Dec 30 10:29:02 2021 daemon.notice wpa_supplicant[7848]: wlan-sta: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Thu Dec 30 10:29:02 2021 kern.debug kernel: [ 206.937515] wlan-sta: Limiting TX power to 0 (-128 - 0) dBm as advertised by 5a:d5:0a:f6:37:c6
Thu Dec 30 10:29:02 2021 daemon.notice wpa_supplicant[7848]: wlan-sta: WPA: Key negotiation completed with 5a:d5:0a:f6:37:c6 [PTK=CCMP GTK=CCMP]
Thu Dec 30 10:29:02 2021 daemon.notice wpa_supplicant[7848]: wlan-sta: CTRL-EVENT-CONNECTED - Connection to 5a:d5:0a:f6:37:c6 completed [id=0 id_str=]
Thu Dec 30 10:29:02 2021 kern.warn kernel: [ 206.991695] ath10k_pci 0000:00:00.0: Invalid peer id 0 or peer stats buffer, peer: 84ede000 sta: (null)
Thu Dec 30 10:29:02 2021 daemon.notice netifd: wwan (7967): udhcpc: started, v1.30.1
Thu Dec 30 10:29:02 2021 daemon.notice netifd: wwan (7967): udhcpc: sending discover
Thu Dec 30 10:29:02 2021 daemon.notice netifd: Network device ‘wlan0’ link is up
Thu Dec 30 10:29:02 2021 kern.info kernel: [ 207.164560] br-lan: port 2(wlan0) entered blocking state
Thu Dec 30 10:29:02 2021 kern.info kernel: [ 207.170107] br-lan: port 2(wlan0) entered forwarding state
Thu Dec 30 10:29:03 2021 user.info : [ 817] gl-sdk>> wifi_join return=0, channel=149
Thu Dec 30 10:29:05 2021 daemon.notice netifd: wwan (7967): udhcpc: sending discover
Thu Dec 30 10:29:05 2021 daemon.notice netifd: wwan (7967): udhcpc: sending select for 192.168.228.182
Thu Dec 30 10:29:05 2021 daemon.notice netifd: wwan (7967): udhcpc: lease of 192.168.228.182 obtained, lease time 3599
Thu Dec 30 10:29:05 2021 daemon.notice netifd: Interface ‘wwan’ is now up
Thu Dec 30 10:29:05 2021 daemon.info dnsmasq[2824]: reading /tmp/resolv.conf.auto
Thu Dec 30 10:29:05 2021 daemon.info dnsmasq[2824]: using local addresses only for domain test
Thu Dec 30 10:29:05 2021 daemon.info dnsmasq[2824]: using local addresses only for domain onion
Thu Dec 30 10:29:05 2021 daemon.info dnsmasq[2824]: using local addresses only for domain localhost
Thu Dec 30 10:29:05 2021 daemon.info dnsmasq[2824]: using local addresses only for domain invalid
Thu Dec 30 10:29:05 2021 daemon.info dnsmasq[2824]: using local addresses only for domain bind
Thu Dec 30 10:29:05 2021 daemon.info dnsmasq[2824]: using local addresses only for domain lan
Thu Dec 30 10:29:05 2021 daemon.info dnsmasq[2824]: using nameserver 192.168.228.122#53
Thu Dec 30 10:29:13 2021 user.info mwan3rtmon[2661]: Detect rtchange event.
Thu Dec 30 10:29:14 2021 user.notice firewall: Reloading firewall due to ifup of wwan (wlan-sta)
Thu Dec 30 10:30:57 2021 user.info : gl_health start->
Thu Dec 30 10:34:54 2021 daemon.notice netifd: Network device ‘wlan0’ link is down
Thu Dec 30 10:34:54 2021 kern.info kernel: [ 506.099522] br-lan: port 2(wlan0) entered disabled state
Thu Dec 30 10:34:54 2021 kern.info kernel: [ 506.107311] wlan-sta: deauthenticating from 5a:d5:0a:f6:37:c6 by local choice (Reason: 3=DEAUTH_LEAVING)
Thu Dec 30 10:34:54 2021 daemon.notice netifd: Network device ‘wlan-sta’ link is down
Thu Dec 30 10:34:54 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity loss
Thu Dec 30 10:34:54 2021 kern.warn kernel: [ 506.129130] ath10k_pci 0000:00:00.0: peer-unmap-event: unknown peer id 2
Thu Dec 30 10:34:54 2021 kern.warn kernel: [ 506.136114] ath10k_pci 0000:00:00.0: peer-unmap-event: unknown peer id 2
Thu Dec 30 10:34:54 2021 daemon.notice wpa_supplicant[7848]: wlan-sta: CTRL-EVENT-DISCONNECTED bssid=5a:d5:0a:f6:37:c6 reason=3 locally_generated=1
Thu Dec 30 10:34:54 2021 daemon.notice netifd: wwan (7967): udhcpc: received SIGTERM
Thu Dec 30 10:34:54 2021 daemon.notice netifd: Interface ‘wwan’ is now down
Thu Dec 30 10:34:54 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Thu Dec 30 10:34:54 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Thu Dec 30 10:34:54 2021 daemon.warn dnsmasq[2824]: no servers found in /tmp/resolv.conf.auto, will retry
Thu Dec 30 10:34:57 2021 daemon.notice netifd: Network device ‘wlan0’ link is up
Thu Dec 30 10:34:57 2021 kern.info kernel: [ 509.194582] br-lan: port 2(wlan0) entered blocking state
Thu Dec 30 10:34:57 2021 kern.info kernel: [ 509.200157] br-lan: port 2(wlan0) entered forwarding state
Thu Dec 30 10:35:28 2021 daemon.notice netifd: Interface ‘wwan’ is disabled
Thu Dec 30 10:35:28 2021 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Thu Dec 30 10:35:28 2021 daemon.notice hostapd: wlan0: AP-DISABLED
Thu Dec 30 10:35:28 2021 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Thu Dec 30 10:35:28 2021 daemon.err wpa_supplicant[7848]: Failed to stop hostapd AP interfaces
Thu Dec 30 10:35:28 2021 daemon.notice wpa_supplicant[7848]: nl80211: deinit ifname=wlan-sta disabled_11b_rates=0
Thu Dec 30 10:35:28 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Thu Dec 30 10:35:28 2021 daemon.notice wpa_supplicant[7848]: wlan-sta: CTRL-EVENT-TERMINATING
Thu Dec 30 10:35:28 2021 kern.info kernel: [ 540.794718] device wlan0 left promiscuous mode
Thu Dec 30 10:35:28 2021 kern.info kernel: [ 540.799551] br-lan: port 2(wlan0) entered disabled state
Thu Dec 30 10:35:28 2021 daemon.notice netifd: Network device ‘wlan0’ link is down
Thu Dec 30 10:35:28 2021 kern.warn kernel: [ 540.812808] ath10k_pci 0000:00:00.0: peer-unmap-event: unknown peer id 0
Thu Dec 30 10:35:28 2021 kern.warn kernel: [ 540.819833] ath10k_pci 0000:00:00.0: peer-unmap-event: unknown peer id 0
Thu Dec 30 10:35:29 2021 daemon.notice netifd: radio0 (20990): command failed: Not supported (-122)
Thu Dec 30 10:35:29 2021 user.notice mac80211: Failed command: iw phy phy0 set distance 0
Thu Dec 30 10:35:30 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Thu Dec 30 10:35:32 2021 kern.warn kernel: [ 544.642360] ath10k_pci 0000:00:00.0: 10.4 wmi init: vdevs: 4 peers: 100 tid: 256
Thu Dec 30 10:35:32 2021 kern.info kernel: [ 544.650346] ath10k_pci 0000:00:00.0: using 7 firmware rate-ctrl objects
Thu Dec 30 10:35:32 2021 kern.warn kernel: [ 544.657177] ath10k_pci 0000:00:00.0: msdu-desc: 2200 skid: 360
Thu Dec 30 10:35:32 2021 kern.info kernel: [ 544.709146] ath10k_pci 0000:00:00.0: wmi print ‘P 100/100 V 4 K 300 PH 308 T 374 msdu-desc: 2200 sw-crypt: 0 ct-sta: 0’
Thu Dec 30 10:35:32 2021 kern.info kernel: [ 544.720646] ath10k_pci 0000:00:00.0: wmi print ‘free: 77164 iram: 14036 sram: 21840’
Thu Dec 30 10:35:32 2021 kern.warn kernel: [ 545.020871] ath10k_pci 0000:00:00.0: Firmware lacks feature flag indicating a retry limit of > 2 is OK, requested limit: 4
Thu Dec 30 10:35:33 2021 daemon.notice netifd: radio0 (20990): sh: /usr/bin/ovs-vsctl: not found
Thu Dec 30 10:35:33 2021 kern.info kernel: [ 545.148037] br-lan: port 2(wlan0) entered blocking state
Thu Dec 30 10:35:33 2021 kern.info kernel: [ 545.153581] br-lan: port 2(wlan0) entered disabled state
Thu Dec 30 10:35:33 2021 kern.info kernel: [ 545.159552] device wlan0 entered promiscuous mode
Thu Dec 30 10:35:33 2021 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->HT_SCAN
Thu Dec 30 10:35:33 2021 daemon.err hostapd: Using interface wlan0 with hwaddr 12:34:56:78:90:12 and ssid “SeaLaVie-5G”
Thu Dec 30 10:35:33 2021 kern.info kernel: [ 545.961589] br-lan: port 2(wlan0) entered blocking state
Thu Dec 30 10:35:33 2021 kern.info kernel: [ 545.967130] br-lan: port 2(wlan0) entered forwarding state
Thu Dec 30 10:35:33 2021 daemon.notice hostapd: wlan0: interface state HT_SCAN->ENABLED
Thu Dec 30 10:35:33 2021 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Dec 30 10:35:34 2021 daemon.notice netifd: Network device ‘wlan0’ link is up
Thu Dec 30 10:35:46 2021 user.info : [ 2888] gl-wifi-core>> bIsStaEnabled=1
Thu Dec 30 10:35:47 2021 daemon.notice hostapd: wlan0: interface state ENABLED->DISABLED
Thu Dec 30 10:35:47 2021 daemon.notice hostapd: wlan0: AP-DISABLED
Thu Dec 30 10:35:47 2021 daemon.notice hostapd: wlan0: CTRL-EVENT-TERMINATING
Thu Dec 30 10:35:47 2021 daemon.notice hostapd: nl80211: deinit ifname=wlan0 disabled_11b_rates=0
Thu Dec 30 10:35:47 2021 kern.info kernel: [ 559.290829] device wlan0 left promiscuous mode
Thu Dec 30 10:35:47 2021 kern.info kernel: [ 559.295915] br-lan: port 2(wlan0) entered disabled state
Thu Dec 30 10:35:47 2021 daemon.notice netifd: Network device ‘wlan0’ link is down
Thu Dec 30 10:35:47 2021 kern.warn kernel: [ 559.305935] ath10k_pci 0000:00:00.0: peer-unmap-event: unknown peer id 0
Thu Dec 30 10:35:47 2021 kern.warn kernel: [ 559.313002] ath10k_pci 0000:00:00.0: peer-unmap-event: unknown peer id 0
Thu Dec 30 10:35:48 2021 daemon.notice netifd: radio0 (21713): command failed: Not supported (-122)
Thu Dec 30 10:35:48 2021 user.notice mac80211: Failed command: iw phy phy0 set distance 0
Thu Dec 30 10:35:48 2021 daemon.err hostapd: Configuration file: /var/run/hostapd-phy0.conf
Thu Dec 30 10:35:51 2021 kern.warn kernel: [ 563.224407] ath10k_pci 0000:00:00.0: 10.4 wmi init: vdevs: 4 peers: 100 tid: 256
Thu Dec 30 10:35:51 2021 kern.info kernel: [ 563.232408] ath10k_pci 0000:00:00.0: using 7 firmware rate-ctrl objects
Thu Dec 30 10:35:51 2021 kern.warn kernel: [ 563.239268] ath10k_pci 0000:00:00.0: msdu-desc: 2200 skid: 360
Thu Dec 30 10:35:51 2021 kern.info kernel: [ 563.290934] ath10k_pci 0000:00:00.0: wmi print ‘P 100/100 V 4 K 300 PH 308 T 374 msdu-desc: 2200 sw-crypt: 0 ct-sta: 0’
Thu Dec 30 10:35:51 2021 kern.info kernel: [ 563.302409] ath10k_pci 0000:00:00.0: wmi print ‘free: 77164 iram: 14036 sram: 21840’
Thu Dec 30 10:35:51 2021 kern.warn kernel: [ 563.600421] ath10k_pci 0000:00:00.0: Firmware lacks feature flag indicating a retry limit of > 2 is OK, requested limit: 4
Thu Dec 30 10:35:51 2021 daemon.notice netifd: radio0 (21713): sh: /usr/bin/ovs-vsctl: not found
Thu Dec 30 10:35:51 2021 kern.info kernel: [ 563.820575] br-lan: port 2(wlan0) entered blocking state
Thu Dec 30 10:35:51 2021 kern.info kernel: [ 563.826099] br-lan: port 2(wlan0) entered disabled state
Thu Dec 30 10:35:51 2021 kern.info kernel: [ 563.831918] device wlan0 entered promiscuous mode
Thu Dec 30 10:35:51 2021 daemon.err hostapd: Using interface wlan0 with hwaddr 10:34:56:78:90:12 and ssid “SeaLaVie-5G”
Thu Dec 30 10:35:52 2021 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->ENABLED
Thu Dec 30 10:35:52 2021 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Dec 30 10:35:52 2021 daemon.notice wpa_supplicant[22071]: Successfully initialized wpa_supplicant
Thu Dec 30 10:35:53 2021 daemon.notice netifd: Interface ‘wwan’ is enabled
Thu Dec 30 10:35:56 2021 daemon.notice wpa_supplicant[22073]: wlan-sta: SME: Trying to authenticate with 5a:d5:0a:f6:37:c6 (SSID=‘JimsHotSpot’ freq=5745 MHz)
Thu Dec 30 10:35:56 2021 kern.info kernel: [ 568.199425] wlan-sta: authenticate with 5a:d5:0a:f6:37:c6
Thu Dec 30 10:35:56 2021 kern.info kernel: [ 568.420782] wlan-sta: send auth to 5a:d5:0a:f6:37:c6 (try 1/3)
Thu Dec 30 10:35:56 2021 kern.info kernel: [ 568.428418] wlan-sta: authenticated
Thu Dec 30 10:35:56 2021 daemon.notice wpa_supplicant[22073]: wlan-sta: Trying to associate with 5a:d5:0a:f6:37:c6 (SSID=‘JimsHotSpot’ freq=5745 MHz)
Thu Dec 30 10:35:56 2021 kern.info kernel: [ 568.439253] wlan-sta: associate with 5a:d5:0a:f6:37:c6 (try 1/3)
Thu Dec 30 10:35:56 2021 kern.info kernel: [ 568.447741] wlan-sta: RX AssocResp from 5a:d5:0a:f6:37:c6 (capab=0x11 status=0 aid=1)
Thu Dec 30 10:35:56 2021 kern.info kernel: [ 568.458756] wlan-sta: associated
Thu Dec 30 10:35:56 2021 daemon.notice netifd: Network device ‘wlan-sta’ link is up
Thu Dec 30 10:35:56 2021 daemon.notice netifd: Interface ‘wwan’ has link connectivity
Thu Dec 30 10:35:56 2021 daemon.notice netifd: Interface ‘wwan’ is setting up now
Thu Dec 30 10:35:56 2021 daemon.notice wpa_supplicant[22073]: wlan-sta: Associated with 5a:d5:0a:f6:37:c6
Thu Dec 30 10:35:56 2021 daemon.notice wpa_supplicant[22073]: wlan-sta: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Thu Dec 30 10:35:56 2021 daemon.notice wpa_supplicant[22073]: wlan-sta: WPA: Key negotiation completed with 5a:d5:0a:f6:37:c6 [PTK=CCMP GTK=CCMP]
Thu Dec 30 10:35:56 2021 daemon.notice wpa_supplicant[22073]: wlan-sta: CTRL-EVENT-CONNECTED - Connection to 5a:d5:0a:f6:37:c6 completed [id=0 id_str=]
Thu Dec 30 10:35:56 2021 kern.debug kernel: [ 568.508397] wlan-sta: Limiting TX power to 0 (-128 - 0) dBm as advertised by 5a:d5:0a:f6:37:c6
Thu Dec 30 10:35:56 2021 daemon.notice netifd: Network device ‘wlan0’ link is up
Thu Dec 30 10:35:56 2021 kern.info kernel: [ 568.704626] br-lan: port 2(wlan0) entered blocking state
Thu Dec 30 10:35:56 2021 kern.info kernel: [ 568.710184] br-lan: port 2(wlan0) entered forwarding state
Thu Dec 30 10:35:56 2021 daemon.notice netifd: wwan (22200): udhcpc: started, v1.30.1
Thu Dec 30 10:35:56 2021 daemon.notice netifd: wwan (22200): udhcpc: sending discover
Thu Dec 30 10:35:59 2021 daemon.notice netifd: wwan (22200): udhcpc: sending discover
Thu Dec 30 10:36:02 2021 daemon.notice netifd: wwan (22200): udhcpc: sending discover
Thu Dec 30 10:36:02 2021 daemon.notice netifd: wwan (22200): udhcpc: sending select for 192.168.228.182
Thu Dec 30 10:36:05 2021 daemon.notice netifd: wwan (22200): udhcpc: sending select for 192.168.228.182
Thu Dec 30 10:36:08 2021 daemon.notice netifd: wwan (22200): udhcpc: sending select for 192.168.228.182
And the kernal -
[ 0.000000] Linux version 4.14.241 (glinet@ubuntu) (gcc version 7.5.0 (OpenWrt GCC 7.5.0 r11257-5090152ae3)) #0 Thu Jul 29 19:50:28 2021
[ 0.000000] bootconsole [early0] enabled
[ 0.000000] CPU0 revision is: 00019750 (MIPS 74Kc)
[ 0.000000] MIPS: machine is GL.iNet GL-X1200 (NOR/NAND)
[ 0.000000] SoC: Qualcomm Atheros QCA956X ver 1 rev 0
[ 0.000000] Determined physical RAM map:
[ 0.000000] memory: 08000000 @ 00000000 (usable)
[ 0.000000] Initrd not found or empty - disabling initrd
[ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
[ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
[ 0.000000] On node 0 totalpages: 32768
[ 0.000000] free_area_init_node: node 0, pgdat 805e7ca0, node_mem_map 81008a40
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 32768 pages, LIFO batch:7
[ 0.000000] random: get_random_bytes called from start_kernel+0x98/0x494 with crng_init=0
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rootfstype=squashfs,jffs2
[ 0.000000] PID hash table entries: 512 (order: -1, 2048 bytes)
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.000000] Writing ErrCtl register=00000000
[ 0.000000] Readback ErrCtl register=00000000
[ 0.000000] Memory: 122336K/131072K available (4485K kernel code, 155K rwdata, 1016K rodata, 1244K init, 218K bss, 8736K reserved, 0K cma-reserved)
[ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] NR_IRQS: 51
[ 0.000000] CPU clock: 775.000 MHz
[ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 4932285024 ns
[ 0.000007] sched_clock: 32 bits at 387MHz, resolution 2ns, wraps every 5541893118ns
[ 0.008228] Calibrating delay loop… 385.84 BogoMIPS (lpj=1929216)
[ 0.074761] pid_max: default: 32768 minimum: 301
[ 0.079784] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.086770] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.097987] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.108389] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.114897] pinctrl core: initialized pinctrl subsystem
[ 0.121448] NET: Registered protocol family 16
[ 0.132884] PCI host bridge /ahb/pcie-controller@18250000 ranges:
[ 0.139313] MEM 0x0000000012000000…0x0000000013ffffff
[ 0.144854] IO 0x0000000000000000…0x0000000000000000
[ 0.166122] PCI host bridge to bus 0000:00
[ 0.170447] pci_bus 0000:00: root bus resource [mem 0x12000000-0x13ffffff]
[ 0.177730] pci_bus 0000:00: root bus resource [io 0x0000]
[ 0.183602] pci_bus 0000:00: root bus resource [??? 0x00000000 flags 0x0]
[ 0.190762] pci_bus 0000:00: No busn resource found for root bus, will use [bus 00-ff]
[ 0.199137] pci 0000:00:00.0: [168c:0056] type 00 class 0x028000
[ 0.199194] pci 0000:00:00.0: reg 0x10: [mem 0x00000000-0x001fffff 64bit]
[ 0.199317] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 0.199487] pci_bus 0000:00: busn_res: [bus 00-ff] end is updated to 00
[ 0.199511] pci 0000:00:00.0: BAR 0: assigned [mem 0x12000000-0x121fffff 64bit]
[ 0.209614] clocksource: Switched to clocksource MIPS
[ 0.215852] NET: Registered protocol family 2
[ 0.220652] IP idents hash table entries: 2048 (order: 2, 16384 bytes)
[ 0.228106] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.235508] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.242226] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.249045] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.255248] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.262111] NET: Registered protocol family 1
[ 0.266736] PCI: CLS 0 bytes, default 32
[ 0.269327] Crashlog allocated RAM at address 0x3f00000
[ 0.276036] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.286985] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.293174] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
[ 0.313041] io scheduler noop registered
[ 0.317176] io scheduler deadline registered (default)
[ 0.324169] pinctrl-single 1804002c.pinmux: 544 pins at pa b804002c size 68
[ 0.332295] gpio-export gpio-export: 5 gpio(s) exported
[ 0.338548] Serial: 8250/16550 driver, 16 ports, IRQ sharing enabled
[ 0.347272] console [ttyS0] disabled
[ 0.351116] 18020000.uart: ttyS0 at MMIO 0x18020000 (irq = 9, base_baud = 1562500) is a 16550A
[ 0.360223] console [ttyS0] enabled
[ 0.367768] bootconsole [early0] disabled
[ 0.393822] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.398729] 5 fixed-partitions partitions found on MTD device spi0.0
[ 0.405307] Creating 5 MTD partitions on “spi0.0”:
[ 0.410273] 0x000000000000-0x000000040000 : “u-boot”
[ 0.416103] 0x000000040000-0x000000050000 : “u-boot-env”
[ 0.422260] 0x000000050000-0x000000060000 : “art”
[ 0.427771] 0x000000060000-0x000000460000 : “kernel”
[ 0.433572] 0x000000460000-0x000001000000 : “nor_reserved”
[ 0.443128] spi-nand: Giga SPI NAND was found.
[ 0.447722] spi-nand: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 128
[ 0.455670] 1 fixed-partitions partitions found on MTD device spi0.1
[ 0.462248] Creating 1 MTD partitions on “spi0.1”:
[ 0.467199] 0x000000000000-0x000008000000 : “ubi”
[ 0.925366] found bad block 7fe0000
[ 0.929594] libphy: Fixed MDIO Bus: probed
[ 1.609964] libphy: ag71xx_mdio: probed
[ 1.616939] switch0: Atheros AR8337 rev. 2 switch registered on mdio-bus.0
[ 2.271083] ag71xx 19000000.eth: connected to PHY at mdio-bus.0:00 [uid=004dd036, driver=Atheros AR8216/AR8236/AR8316]
[ 2.282669] eth0: Atheros AG71xx at 0xb9000000, irq 4, mode: mii
[ 2.290677] NET: Registered protocol family 10
[ 2.299208] Segment Routing with IPv6
[ 2.303129] NET: Registered protocol family 17
[ 2.307769] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 2.321170] 8021q: 802.1Q VLAN Support v1.8
[ 2.331102] UBI: auto-attach mtd5
[ 2.334559] ubi0: attaching mtd5
[ 2.589616] random: fast init done
[ 7.187228] ubi0: scanning is finished
[ 7.244371] ubi0: attached mtd5 (name “ubi”, size 128 MiB)
[ 7.250091] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 7.257185] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 7.264204] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 7.271398] ubi0: good PEBs: 1023, bad PEBs: 1, corrupted PEBs: 0
[ 7.277686] ubi0: user volume: 2, internal volumes: 1, max. volumes count: 128
[ 7.285155] ubi0: max/mean erase counter: 6/4, WL threshold: 4096, image sequence number: 1192488578
[ 7.294597] ubi0: available PEBs: 0, total reserved PEBs: 1023, PEBs reserved for bad PEB handling: 19
[ 7.304281] ubi0: background thread “ubi_bgt0d” started, PID 324
[ 7.313831] block ubiblock0_0: created from ubi0:0(rootfs)
[ 7.319504] ubiblock: device ubiblock0_0 (rootfs) set to be root filesystem
[ 7.346857] VFS: Mounted root (squashfs filesystem) readonly on device 254:0.
[ 7.361017] Freeing unused kernel memory: 1244K
[ 7.365698] This architecture does not have kernel memory protection.
[ 8.304546] init: Console is alive
[ 8.308254] init: - watchdog -
[ 11.793625] kmodloader: loading kernel modules from /etc/modules-boot.d/
[ 12.198638] usbcore: registered new interface driver usbfs
[ 12.204420] usbcore: registered new interface driver hub
[ 12.210018] usbcore: registered new device driver usb
[ 12.223995] exFAT: Version 1.2.9
[ 12.260250] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
[ 12.275236] SCSI subsystem initialized
[ 12.284082] ehci-platform: EHCI generic platform driver
[ 12.289765] ehci-platform 1b000000.usb: EHCI Host Controller
[ 12.295630] ehci-platform 1b000000.usb: new USB bus registered, assigned bus number 1
[ 12.303826] ehci-platform 1b000000.usb: irq 13, io mem 0x1b000000
[ 12.339653] ehci-platform 1b000000.usb: USB 2.0 started, EHCI 1.00
[ 12.346800] hub 1-0:1.0: USB hub found
[ 12.351035] hub 1-0:1.0: 1 port detected
[ 12.355649] ehci-platform 1b400000.usb: EHCI Host Controller
[ 12.361578] ehci-platform 1b400000.usb: new USB bus registered, assigned bus number 2
[ 12.369791] ehci-platform 1b400000.usb: irq 14, io mem 0x1b400000
[ 12.399653] ehci-platform 1b400000.usb: USB 2.0 started, EHCI 1.00
[ 12.406789] hub 2-0:1.0: USB hub found
[ 12.411021] hub 2-0:1.0: 1 port detected
[ 12.418614] ohci_hcd: USB 1.1 ‘Open’ Host Controller (OHCI) Driver
[ 12.426558] ohci-platform: OHCI generic platform driver
[ 12.434340] uhci_hcd: USB Universal Host Controller Interface driver
[ 12.445321] usbcore: registered new interface driver usb-storage
[ 12.453696] usbcore: registered new interface driver uas
[ 12.459553] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
[ 12.477608] init: - preinit -
[ 13.069683] usb 1-1: new high-speed USB device number 2 using ehci-platform
[ 13.117846] usb 2-1: new high-speed USB device number 2 using ehci-platform
[ 13.365797] random: procd: uninitialized urandom read (4 bytes read)
[ 13.372865] hub 1-1:1.0: USB hub found
[ 13.377164] hub 2-1:1.0: USB hub found
[ 13.386426] hub 1-1:1.0: 4 ports detected
[ 13.390706] hub 2-1:1.0: 4 ports detected
[ 13.848814] random: jshn: uninitialized urandom read (4 bytes read)
[ 13.939695] usb 1-1.1: new high-speed USB device number 3 using ehci-platform
[ 13.947143] usb 2-1.1: new high-speed USB device number 3 using ehci-platform
[ 14.037358] random: jshn: uninitialized urandom read (4 bytes read)
[ 14.125613] usb-storage 1-1.1:1.0: USB Mass Storage device detected
[ 14.132768] usb-storage 2-1.1:1.0: USB Mass Storage device detected
[ 14.150506] scsi host1: usb-storage 2-1.1:1.0
[ 14.156251] scsi host0: usb-storage 1-1.1:1.0
[ 14.259692] usb 1-1.2: new full-speed USB device number 4 using ehci-platform
[ 14.267122] usb 2-1.2: new full-speed USB device number 4 using ehci-platform
[ 14.407544] urandom_read: 3 callbacks suppressed
[ 14.407551] random: jshn: uninitialized urandom read (4 bytes read)
[ 14.479681] usb 1-1.2: new high-speed USB device number 5 using ehci-platform
[ 14.487108] usb 2-1.2: new high-speed USB device number 5 using ehci-platform
[ 14.511712] random: jshn: uninitialized urandom read (4 bytes read)
[ 14.869661] usb 1-1.3: new full-speed USB device number 6 using ehci-platform
[ 14.877088] usb 2-1.3: new full-speed USB device number 6 using ehci-platform
[ 15.231370] scsi 0:0:0:0: Direct-Access Generic STORAGE DEVICE 0233 PQ: 0 ANSI: 0
[ 15.241489] scsi 1:0:0:0: Direct-Access Generic STORAGE DEVICE 0233 PQ: 0 ANSI: 0
[ 15.253704] sd 0:0:0:0: [sda] Attached SCSI removable disk
[ 15.503390] sd 1:0:0:0: [sdb] 3862528 512-byte logical blocks: (1.98 GB/1.84 GiB)
[ 15.517568] sd 1:0:0:0: [sdb] Write Protect is off
[ 15.522585] sd 1:0:0:0: [sdb] Mode Sense: 0b 00 00 08
[ 15.529774] sd 1:0:0:0: [sdb] No Caching mode page found
[ 15.535271] sd 1:0:0:0: [sdb] Assuming drive cache: write through
[ 15.582117] sdb: sdb1
[ 15.609004] sd 1:0:0:0: [sdb] Attached SCSI removable disk
[ 16.170776] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 16.176868] IPv6: ADDRCONF(NETDEV_UP): eth0.1: link is not ready
[ 17.230943] eth0: link up (1000Mbps/Full duplex)
[ 17.235805] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 17.242622] IPv6: ADDRCONF(NETDEV_CHANGE): eth0.1: link becomes ready
[ 19.390390] mount_root: loading kmods from internal overlay
[ 19.464131] kmodloader: loading kernel modules from //etc/modules-boot.d/*
[ 19.475402] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
[ 20.710027] UBIFS (ubi0:1): background thread “ubifs_bgt0_1” started, PID 554
[ 20.990881] UBIFS (ubi0:1): recovery needed
[ 21.730480] UBIFS (ubi0:1): recovery completed
[ 21.735152] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name “rootfs_data”
[ 21.743288] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 21.753541] UBIFS (ubi0:1): FS size: 111992832 bytes (106 MiB, 882 LEBs), journal size 5586944 bytes (5 MiB, 44 LEBs)
[ 21.764504] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
[ 21.771344] UBIFS (ubi0:1): media format: w4/r0 (latest is w5/r0), UUID EA2372E4-8EE8-4D5B-B2A5-0B354E1C3DB2, small LPT model
[ 21.801185] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 21.854636] block: extroot: not configured
[ 21.859071] UBIFS (ubi0:1): un-mount UBI device 0
[ 21.863986] UBIFS (ubi0:1): background thread “ubifs_bgt0_1” stops
[ 21.889977] UBIFS (ubi0:1): background thread “ubifs_bgt0_1” started, PID 557
[ 22.407650] UBIFS (ubi0:1): UBIFS: mounted UBI device 0, volume 1, name “rootfs_data”
[ 22.415795] UBIFS (ubi0:1): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 22.426047] UBIFS (ubi0:1): FS size: 111992832 bytes (106 MiB, 882 LEBs), journal size 5586944 bytes (5 MiB, 44 LEBs)
[ 22.437008] UBIFS (ubi0:1): reserved for root: 4952683 bytes (4836 KiB)
[ 22.443847] UBIFS (ubi0:1): media format: w4/r0 (latest is w5/r0), UUID EA2372E4-8EE8-4D5B-B2A5-0B354E1C3DB2, small LPT model
[ 22.499279] mount_root: loading kmods from internal overlay
[ 22.568214] kmodloader: loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 22.588876] kmodloader: done loading kernel modules from /tmp/overlay/upper/etc/modules-boot.d/*
[ 23.618276] block: attempting to load /tmp/ubifs_cfg/upper/etc/config/fstab
[ 23.653675] block: extroot: not configured
[ 23.670190] mount_root: switching to ubifs overlay
[ 23.788144] urandom-seed: Seeding with /etc/urandom.seed
[ 24.002644] eth0: link down
[ 24.024146] procd: - early -
[ 24.027218] procd: - watchdog -
[ 24.780251] random: jshn: uninitialized urandom read (4 bytes read)
[ 24.862610] procd: - watchdog -
[ 24.866106] procd: - ubus -
[ 25.108004] random: ubusd: uninitialized urandom read (4 bytes read)
[ 25.161020] procd: - init -
[ 29.561859] kmodloader: loading kernel modules from /etc/modules.d/*
[ 29.847534] urngd: v1.0.2 started.
[ 29.965999] ntfs: driver 2.1.32 [Flags: R/O MODULE].
[ 30.052139] tun: Universal TUN/TAP device driver, 1.6
[ 30.128950] GobiNet: 2018-12-21/SWI_2.55
[ 30.134494] usbcore: registered new interface driver GobiNet
[ 30.207504] usbcore: registered new interface driver usbserial
[ 30.213671] usbcore: registered new interface driver usbserial_generic
[ 30.220518] usbserial: USB Serial support registered for generic
[ 30.290840] usbcore: registered new interface driver GobiSerial
[ 30.297013] usbserial: USB Serial support registered for GobiSerial
[ 30.303570] GobiSerial: 2015-08-27/SWI_2.25:GobiSerial
[ 30.336053] random: crng init done
[ 30.361354] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 30.400239] nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
[ 30.713491] Netfilter messages via NETLINK v0.30.
[ 30.721007] ip_set: protocol 6
[ 30.911224] Mirror/redirect action on
[ 30.949994] u32 classifier
[ 30.952800] input device check on
[ 30.956579] Actions configured
[ 31.033889] GACT probability on
[ 31.060855] Simple TC action Loaded
[ 31.140670] fuse init (API version 7.26)
[ 31.179728] usbcore: registered new interface driver cdc_acm
[ 31.185581] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 31.251810] usbcore: registered new interface driver cdc_ether
[ 31.283224] usbcore: registered new interface driver cdc_ncm
[ 31.301535] usbcore: registered new interface driver cdc_wdm
[ 31.331487] Loading modules backported from Linux version v4.19.193-0-g1722257b8ece
[ 31.339397] Backport generated by backports.git v4.19.193-1-0-gaa2cc8ea
[ 31.382202] usbcore: registered new interface driver cp210x
[ 31.388022] usbserial: USB Serial support registered for cp210x
[ 31.394435] cp210x 2-1.3:1.0: cp210x converter detected
[ 31.437157] usb 2-1.3: cp210x converter now attached to ttyUSB0
[ 31.443548] cp210x 1-1.3:1.0: cp210x converter detected
[ 31.471106] usb 1-1.3: cp210x converter now attached to ttyUSB1
[ 31.523860] Ebtables v2.0 registered
[ 31.540930] usbcore: registered new interface driver huawei_cdc_ncm
[ 31.562590] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 31.585724] usbcore: registered new interface driver ipheth
[ 31.832062] ctnetlink v0.93: registering with nfnetlink.
[ 32.199478] qmi_wwan 1-1.2:1.4: cdc-wdm0: USB WDM device
[ 32.205040] qmi_wwan 1-1.2:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
[ 32.240449] qmi_wwan 1-1.2:1.4 wwan0: register ‘qmi_wwan’ at usb-1b000000.usb-1.2, WWAN/QMI device, 9e:83:61:76:a4:5b
[ 32.279820] qmi_wwan 2-1.2:1.4: cdc-wdm1: USB WDM device
[ 32.285320] qmi_wwan 2-1.2:1.4: QuectelEC25&EC21&EG91&EG95&EG06&EP06&EM06&BG96&AG35 work on RawIP mode
[ 32.325478] qmi_wwan 2-1.2:1.4 wwan1: register ‘qmi_wwan’ at usb-1b400000.usb-1.2, WWAN/QMI device, 9e:83:61:76:a4:5b
[ 32.336756] usbcore: registered new interface driver qmi_wwan
[ 32.392849] usbcore: registered new interface driver rndis_host
[ 32.422229] usbcore: registered new interface driver sierra
[ 32.428062] usbserial: USB Serial support registered for Sierra USB modem
[ 32.461005] usbcore: registered new interface driver sierra_net
[ 32.515599] wireguard: WireGuard 1.0.20200611 loaded. See www.wireguard.com for information.
[ 32.524383] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld [email protected]. All Rights Reserved.
[ 32.720625] xt_time: kernel timezone is -0000
[ 32.958765] usbcore: registered new interface driver option
[ 32.964669] usbserial: USB Serial support registered for GSM modem (1-port)
[ 32.972528] option 1-1.2:1.0: GSM modem (1-port) converter detected
[ 32.979254] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB2
[ 32.986659] option 1-1.2:1.1: GSM modem (1-port) converter detected
[ 32.993404] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB3
[ 33.000809] option 1-1.2:1.2: GSM modem (1-port) converter detected
[ 33.007522] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB4
[ 33.014938] option 1-1.2:1.3: GSM modem (1-port) converter detected
[ 33.021707] usb 1-1.2: GSM modem (1-port) converter now attached to ttyUSB5
[ 33.029041] option 2-1.2:1.0: GSM modem (1-port) converter detected
[ 33.035804] usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB6
[ 33.043198] option 2-1.2:1.1: GSM modem (1-port) converter detected
[ 33.049972] usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB7
[ 33.057313] option 2-1.2:1.2: GSM modem (1-port) converter detected
[ 33.064090] usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB8
[ 33.071482] option 2-1.2:1.3: GSM modem (1-port) converter detected
[ 33.078227] usb 2-1.2: GSM modem (1-port) converter now attached to ttyUSB9
[ 33.233610] PPP generic driver version 2.4.2
[ 33.251183] PPP MPPE Compression module registered
[ 33.265494] NET: Registered protocol family 24
[ 33.382983] ath10k 4.19 driver, optimized for CT firmware, probing pci device: 0x56.
[ 33.410655] PCI: Enabling device 0000:00:00.0 (0000 → 0002)
[ 33.416809] ath10k_pci 0000:00:00.0: pci irq legacy oper_irq_mode 1 irq_mode 0 reset_mode 0
[ 33.662230] ath10k_pci 0000:00:00.0: fwcfg key: vdevs val: 4
[ 33.668181] ath10k_pci 0000:00:00.0: fwcfg key: peers val: 100
[ 33.674357] ath10k_pci 0000:00:00.0: fwcfg key: active_peers val: 100
[ 33.681118] ath10k_pci 0000:00:00.0: fwcfg key: stations val: 100
[ 33.687514] ath10k_pci 0000:00:00.0: fwcfg key: rate_ctrl_objs val: 7
[ 33.694269] ath10k_pci 0000:00:00.0: fwcfg key: regdom val: 840
[ 33.700483] ath10k_pci 0000:00:00.0: fwcfg key: fwver val: 5
[ 33.706417] ath10k_pci 0000:00:00.0: fwcfg key: nohwcrypt val: 0
[ 33.712721] ath10k_pci 0000:00:00.0: fwcfg key: ct_sta_mode val: 0
[ 33.719195] ath10k_pci 0000:00:00.0: fwcfg key: tx_desc val: 2200
[ 33.725587] ath10k_pci 0000:00:00.0: fwcfg key: tids val: 256
[ 33.731622] ath10k_pci 0000:00:00.0: fwcfg key: skid_limit val: 360
[ 33.738181] ath10k_pci 0000:00:00.0: fwcfg key: max_amsdus val: 3
[ 35.140179] ath10k_pci 0000:00:00.0: qca9888 hw2.0 target 0x01000000 chip_id 0x00000000 sub 0000:0000
[ 35.149736] ath10k_pci 0000:00:00.0: kconfig debug 0 debugfs 1 tracing 0 dfs 1 testmode 0
[ 35.169717] ath10k_pci 0000:00:00.0: firmware ver 10.4b-ct-9888-fH-13-8c5b2baa2 api 5 features mfp,peer-flow-ctrl,txstatus-noack,wmi-10.x-CT,ratemask-CT,regdump-CT,txrate-CT,flush-all-CT,pingpong-CT,ch-regs-CT,nop-CT,htt-mgt-CT,set-special-CT,tx-rc-CT,cust-stats-CT,txrate2-CT,beacon-cb-CT,wmi-block-ack-CT,wmi-bcn-rc-CT crc32 4600ee9a
[ 35.506905] ath10k_pci 0000:00:00.0: board_file api 2 bmi_id 0:16 crc32 f228337a
[ 37.541687] ath10k_pci 0000:00:00.0: DANGER! You’re overriding EEPROM-defined regulatory domain
[ 37.550721] ath10k_pci 0000:00:00.0: from: 0x0 to 0x348 (svc-ready-work)
[ 37.557640] ath10k_pci 0000:00:00.0: Your card was not certified to operate in the domain you chose.
[ 37.567253] ath10k_pci 0000:00:00.0: This might result in a violation of your local regulatory rules.
[ 37.576800] ath10k_pci 0000:00:00.0: Do not ever do this unless you really know what you are doing!
[ 37.593100] ath10k_pci 0000:00:00.0: 10.4 wmi init: vdevs: 4 peers: 100 tid: 256
[ 37.600964] ath10k_pci 0000:00:00.0: using 7 firmware rate-ctrl objects
[ 37.607790] ath10k_pci 0000:00:00.0: msdu-desc: 2200 skid: 360
[ 37.659309] ath10k_pci 0000:00:00.0: wmi print ‘P 100/100 V 4 K 300 PH 308 T 374 msdu-desc: 2200 sw-crypt: 0 ct-sta: 0’
[ 37.670734] ath10k_pci 0000:00:00.0: wmi print ‘free: 77164 iram: 14036 sram: 21840’
[ 37.885892] ath10k_pci 0000:00:00.0: htt-ver 2.2 wmi-op 6 htt-op 4 cal pre-cal-file max-sta 100 raw 0 hwcrypto 1
[ 38.002409] ath: EEPROM regdomain: 0x8348
[ 38.002415] ath: EEPROM indicates we should expect a country code
[ 38.002427] ath: doing EEPROM country->regdmn map search
[ 38.002433] ath: country maps to regdmn code: 0x3a
[ 38.002438] ath: Country alpha2 being used: US
[ 38.002441] ath: Regpair used: 0x3a
[ 38.065454] usbcore: registered new interface driver rt2800usb
[ 38.094395] ath: EEPROM regdomain: 0x0
[ 38.094403] ath: EEPROM indicates default country code should be used
[ 38.094405] ath: doing EEPROM country->regdmn map search
[ 38.094418] ath: country maps to regdmn code: 0x3a
[ 38.094423] ath: Country alpha2 being used: US
[ 38.094425] ath: Regpair used: 0x3a
[ 38.106102] ieee80211 phy1: Selected rate control algorithm ‘minstrel_ht’
[ 38.107614] ieee80211 phy1: Atheros AR9561 Rev:0 mem=0xb8100000, irq=2
[ 38.118401] kmodloader: done loading kernel modules from /etc/modules.d/*
[ 47.660499] FAT-fs (sdb1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 57.077005] IPv6: ADDRCONF(NETDEV_UP): lo: link is not ready
[ 57.370503] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 58.482531] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 58.503150] br-lan: port 1(eth0.1) entered blocking state
[ 58.508737] br-lan: port 1(eth0.1) entered disabled state
[ 58.514644] device eth0.1 entered promiscuous mode
[ 58.519647] device eth0 entered promiscuous mode
[ 59.568877] eth0: link up (1000Mbps/Full duplex)
[ 59.596443] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 59.654676] br-lan: port 1(eth0.1) entered blocking state
[ 59.660311] br-lan: port 1(eth0.1) entered forwarding state
[ 60.415667] fast-classifier: starting up
[ 60.419946] fast-classifier: registered
[ 69.563006] ath10k_pci 0000:00:00.0: 10.4 wmi init: vdevs: 4 peers: 100 tid: 256
[ 69.570892] ath10k_pci 0000:00:00.0: using 7 firmware rate-ctrl objects
[ 69.577724] ath10k_pci 0000:00:00.0: msdu-desc: 2200 skid: 360
[ 69.629479] ath10k_pci 0000:00:00.0: wmi print ‘P 100/100 V 4 K 300 PH 308 T 374 msdu-desc: 2200 sw-crypt: 0 ct-sta: 0’
[ 69.640993] ath10k_pci 0000:00:00.0: wmi print ‘free: 77164 iram: 14036 sram: 21840’
[ 69.941553] ath10k_pci 0000:00:00.0: Firmware lacks feature flag indicating a retry limit of > 2 is OK, requested limit: 4
[ 70.208422] br-lan: port 2(wlan0) entered blocking state
[ 70.214008] br-lan: port 2(wlan0) entered disabled state
[ 70.219847] device wlan0 entered promiscuous mode
[ 70.226740] br-lan: port 3(wlan1) entered blocking state
[ 70.232307] br-lan: port 3(wlan1) entered disabled state
[ 70.238053] device wlan1 entered promiscuous mode
[ 70.559207] ath10k_pci 0000:00:00.0: NOTE: Firmware DBGLOG output disabled in debug_mask: 0x10000000
[ 72.041434] br-lan: port 3(wlan1) entered blocking state
[ 72.046945] br-lan: port 3(wlan1) entered forwarding state
[ 72.676082] br-lan: port 2(wlan0) entered blocking state
[ 72.681642] br-lan: port 2(wlan0) entered forwarding state
The logs show wifi disconnect on 5GHz band. As a test, can you also try connecting to hotspot on 2.4GHz band to see if it has the same problem?
To eliminate other variables, turn off the 5GHz band and LTE on the router if they are on. Also, update to latest firmware if not already done so.
Followed your recommendations and I still get disconnects on the 2.4 band… The GL-X1200 is no more than 20’ from my PC and the signal strength is only one bar?
I noticed the following line in both your logs, associated with disconnects:
5a:d5:0a:f6:37:c6 is the MAC of your smartphone hotspot. If it means to reduce the GL-X1200’s transmit power (?), then it may explain why your phone has to be close to the router and the signal is weak between PC and the router.
Do you have home wifi that you can test connecting the GL-X1200 to, instead of your smartphone?
