Get disconnected from Beryl AX if no internet connection
It’s always so hard to get the initial wifi set up for my Beryl AX router whenever I travel. Whenever I try to connect to the router with my Windows 11 laptop or Android phone, I’ll constantly get disconnected from the wifi router as there is no internet connection available. I always have to keep manually reconnecting to my Beryl AX wifi SSID and hopefully get to the router settings to scan and connect it to internet before I get disconnected.
Any ideas on on how to fix this? I don’t remember having this issue when I had my Beryl before. Is this an Beryl AX issue?
You can try to set the bandwidth to 40M in the WIRELESS page of the web, or change it to another WIFI channel.
I will try that. Thank you!
