hello, thanks
how to get the cpu temperature, chipset temperature, any temperature on the router?
or
a tool/script to force a temperature via cpu throttling?
i searched the forum, could not find out.
any suggestions?
root@GL-AR750S:~# sensors
No sensors found!
Make sure you loaded all the kernel drivers you need.
Try sensors-detect to find out which these are.
root@GL-AR750S:~# sensors-detect
No i2c device files found.
