Running AdGuard on my travelrouter GL-A1300 gives issues since the last firmware update to version 4.5.16.
Adguard is running but not loading the default AdGuard DNS filter list. Count stays at “0”. Also adding a new blocklist, does not work. I get a time out error in the right corner.
Resetting device to factory settings, enabling just AdGuard does not fix the issue. Still not able to update/add blocklists…
I’m not that familiar with SSH. Just running commands I can, but this is something you created for GL.Inet? Or why are these routers not updated to the latest AdGuard version?
Yep, I created that for the community because the firmware does not contain the newest AGH version. That’s because AGH is a 3rd-party-plugin and you would need to build the fw every time they push some update.
I can’t promise that updating AGH will solve your problem, but it’s worth a try.
