My GL-A1300 only sees my wireless network/ssid at 2.4GHz. My Mac and Windows connect fine to the same SSID at 5 GHz. What is the issue and solution?
Which setting does the 5 GHz Wi-Fi use? 160 MHz for example?
Not all type of network settings are supported.
I guess that the GL-A1300 does not support 802.11ac
(Just a wild guess, don’t own one)
If that is the case, these will not be any good soon.
Just a wild guess.
It could be another issue as well. Which country did you buy the device?
Which country code is selected in luci?
Purchased in USA.
No country code that I can see in LUCI.
Could you try to set the country code to US for testing?
Sure, where is that set exactly?
Choose the 5 GHz one.
